Yes, it’s SPI1,
Did you connect the MOSI to MISO as loopback?
I use an oscilloscope to connect the two pins of MoSi and miso, but the oscilloscope does not display anything data.
@ShaneCCC
I tried to open SPI in 40 pin directly through Jetson io.py, and / dev / spide0.0 appeared directly after startup. However, after sending data with spidev_test, the oscilloscope still could not get any data phenomenon.
oh, I found the problem. There is a problem with this device. I can get the data by using the same steps after I change a device.
hi dingjie :
have you resolve your question?
