SPI2 - Jestson AGX orin Not retaining the values which is set in Pinmux
I have a similar problem to the following
my tegra234-mb1-bct-pinmux-p3701-0000-a04.dtsi setting
spi2_sck_pcc0 {
	nvidia,pins = "spi2_sck_pcc0";
	nvidia,function = "spi2";
	nvidia,pull = <TEGRA_PIN_PULL_NONE>;
	nvidia,tristate = <TEGRA_PIN_DISABLE>;
	nvidia,enable-input = <TEGRA_PIN_ENABLE>;
	nvidia,io-high-voltage = <TEGRA_PIN_DISABLE>;
	nvidia,lpdr = <TEGRA_PIN_DISABLE>;
spi2_miso_pcc1 {
	nvidia,pins = "spi2_miso_pcc1";
spi2_mosi_pcc2 {
	nvidia,pins = "spi2_mosi_pcc2";
spi2_cs0_pcc3 {
	nvidia,pins = "spi2_cs0_pcc3";
	nvidia,pull = <TEGRA_PIN_PULL_UP>;
But something wrong with 0x0c302028
root@Jetson:/home/nvidia# busybox devmem 0x0c302048 32
0x00001440
root@Jetson:/home/nvidia# busybox devmem 0x0c302050 32
0x00000440
root@Jetson:/home/nvidia# busybox devmem 0x0c302028 32
0x00000000
root@Jetson:/home/nvidia# busybox devmem 0x0c302038 32
0x00000448
Try writing the value manually
root@Jetson:/home/nvidia# busybox devmem 0x0c302028 32 0x00000448
0x00000448
Execute normally
root@Jetson:/home/nvidia# spidev_test -s 4000000 -p “\x01\x33” -o spi.out -v -D /dev/spidev1.0
spi mode: 0x0
bits per word: 8
max speed: 4000000 Hz (4000 kHz)
TX | 01 33 __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ |.3|
RX | AA AA __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ |…|
spi mode: 0x0
bits per word: 8
RX | 01 33 __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ |.3|
we flashed by connecting the module in recovery mode and executed
./flash.sh jetson-agx-orin-devkit mmcblk0p1
[flash.log|attachment](upload://agRbtIbzpnM0JLo53AorcVBIrmt.log) (91.9 KB)
Hi channinglan,
For 0x0c302028, it is determined by the following node.
Please configure it as the following.
spi2_mosi_pcc2 {
-	nvidia,enable-input = <TEGRA_PIN_ENABLE>;
+	nvidia,enable-input = <TEGRA_PIN_DISABLE>;
Do you flash the board to apply the change?
I have the same problem using the jestson-agx-orin evk
root@Jetson:/home/nvidia# cat /etc/nv_tegra_release
R35 (release), REVISION: 4.1, GCID: 33958178, BOARD: t186ref, EABI: aarch64, DATE: Tue Aug 1 19:57:35 UTC 2023
Could you share the steps how you enable spi2 on the AGX Orin devkit?
1.use AGX Orin devkit the steps are the same!
How to set bit 10 SFIO ?
I can’t find it in tegra234-mb1-bct-pinmux-p3701-0000-a04.dtsi
Which steps are you referring to ?
If the nvidia,function is configured as spi2, then the bit 10 should be configured as SFIO.
			spi2_mosi_pcc2 {
				nvidia,function = "spi2";						//PM       1:0  0 spi2
				nvidia,pull = <TEGRA_PIN_PULL_NONE>;			//PUPD     3:2  0 none    1 down 2 up
				nvidia,tristate = <TEGRA_PIN_ENABLE>;			//TRISTATE 4    0 pass    1 tristate
				nvidia,io-high-voltage = <TEGRA_PIN_ENABLE>;	//E_IO_HV  5    0 disable 1 enable
				nvidia,enable-input = <TEGRA_PIN_ENABLE>;		//E_INPUT  6    0 disable 1 enable
				nvidia,lpdr = <TEGRA_PIN_ENABLE>;				//E_LPBK   7    0 disable 1 enable
0x00000120
Test register is not as expected! Unable to set to SPI2!
nvidia,function = “spi2”;
How did you apply the pinmux change?
Please share the full steps how you enable SPI2 on the AGX Orin devkit.
修改
後使用命令 完整更新
ORIN_EVB_FLASH.log (95.8 KB)
確認
tegra234-mb1-bct-pinmux-p3701-0000-a04_cpp.dts
tegra234-mb1-bct-pinmux-p3701-0000-a04_cpp.dts.txt (49.4 KB)
   spi2_mosi_pcc2 {
    nvidia,pull = <0>;
    nvidia,tristate = <0>;
    nvidia,io-high-voltage = <0>;
    nvidia,enable-input = <0>;
    nvidia,lpdr = <0>;
測試 nvidia,function = “spi2”; 這個無法寫入正確的值
0x00000000
SPI2 is from SPE and I think something else is also configuring this pin.
May I know what’s your use case for SPI2?
1.我也覺得其他地方有設定到
但只有設定到 SPI2_MOSI 很奇怪
其他 SPI2 的暫存器都是正常的,
  1. spi2 將會使用在 spi flash 但目前無設備…故只有量測波形是否正確 , 手動下暫存器 SPI2_MOSI 可以是spidev_test 命令如預期執行
