I have a huge lidar.bin data >70GB
I need to split the data in the same format.
Is there a method in DW ?
Thanks in advance!
Thanks in advance!
Hello uuresin,
yes, DW include post-recording tools, among others, the “Recording Chopping Tool” is available for cutting parts of the recording.
you can use that to cut how many parts you need.
Thanks for the response,
I got the following error:
[08-03-2020 19:21:52] Platform: Detected Generic x86 Platform
[08-03-2020 19:21:52] TimeSource: monotonic epoch time offset is 1583676100723944
[08-03-2020 19:21:52] Platform: number of GPU devices detected 1
[08-03-2020 19:21:52] Platform: currently selected GPU device discrete ID 0
[08-03-2020 19:21:52] SDK: Resources mounted from /usr/local/driveworks-2.2/data/
[08-03-2020 19:21:52] Initialize DriveWorks SDK v2.2.3136
[08-03-2020 19:21:52] Release build with GNU 7.4.0 from heads/buildbrain-branch-0-gca7b4b26e65
[Chop]: [WARN]: Input file “~/records/2020_02_22/data/SSD3/lidar_left.bin” does not exist. Ignoring sensor
I am 100% sure in the given path the “lidar_left.bin” file exists.
Dear uuresin,
Could you check with absolute path of input file instead of ~/records/2020_02_22/data/SSD3/lidar_left.bin
