I have sporadic system freeze that can be resolved only by reseting the board.
This is fresh L4T21.1 install with booting from SSD. Beside that I have added this line into rc.local to prevent USB dropouts:
echo -1 > /sys/module/usbcore/parameters/autosuspend
I have logitech wireless kbd with touchpad and the unified receiver is the only device connected to USB 3.0 port.
I have also modified extlinux.conf to get USB 3.0 support.
System sporadically freezes - in a way that keyboard or mouse or both are dead. The same scenario happens sporadically when USB 2.0 HUB with usb mouse and keyboard is attached to USB 3.0 port. When this happens only thing that I can do is to reset the board.
These are the lines from system log that correspond to system freeze.
Dec 9 20:23:55 tegra-ubuntu kernel: [ 1033.329787] ------------[ cut here ]------------
Dec 9 20:23:55 tegra-ubuntu kernel: [ 1033.330150] WARNING: at /dvs/git/dirty/git-master_linux/kernel/drivers/gpu/nvgpu/gk20a/channel_gk20a.c:1636 gk20a_channel_finish+0x88/0x17c()
Dec 9 20:23:55 tegra-ubuntu kernel: [ 1033.330273] Modules linked in: joydev dm_crypt dm_mod bnep rfcomm bluetooth rfkill nvhost_vi
Dec 9 20:23:55 tegra-ubuntu kernel: [ 1033.331255] CPU: 0 PID: 3857 Comm: Watchdog Tainted: G W 3.10.40-g8c4516e #1
Dec 9 20:23:55 tegra-ubuntu kernel: [ 1033.331600] [<c00168e0>] (unwind_backtrace+0x0/0x140) from [<c0013234>] (show_stack+0x18/0x1c)
Dec 9 20:23:55 tegra-ubuntu kernel: [ 1033.332103] [<c0013234>] (show_stack+0x18/0x1c) from [<c0067150>] (warn_slowpath_common+0x54/0x70)
Dec 9 20:23:55 tegra-ubuntu kernel: [ 1033.332357] [<c0067150>] (warn_slowpath_common+0x54/0x70) from [<c0067190>] (warn_slowpath_null+0x24/0x2c)
Dec 9 20:23:55 tegra-ubuntu kernel: [ 1033.332599] [<c0067190>] (warn_slowpath_null+0x24/0x2c) from [<c03dcaec>] (gk20a_channel_finish+0x88/0x17c)
Dec 9 20:23:55 tegra-ubuntu kernel: [ 1033.333052] [<c03dcaec>] (gk20a_channel_finish+0x88/0x17c) from [<c03dcc44>] (gk20a_disable_channel+0x64/0x80)
Dec 9 20:23:55 tegra-ubuntu kernel: [ 1033.333283] [<c03dcc44>] (gk20a_disable_channel+0x64/0x80) from [<c03dcd28>] (gk20a_free_channel+0xc8/0x3c0)
Dec 9 20:23:55 tegra-ubuntu kernel: [ 1033.333515] [<c03dcd28>] (gk20a_free_channel+0xc8/0x3c0) from [<c03dd074>] (gk20a_channel_release+0x54/0x110)
Dec 9 20:23:55 tegra-ubuntu kernel: [ 1033.333972] [<c03dd074>] (gk20a_channel_release+0x54/0x110) from [<c01501b0>] (__fput+0x94/0x200)
Dec 9 20:23:55 tegra-ubuntu kernel: [ 1033.334221] [<c01501b0>] (__fput+0x94/0x200) from [<c008aac8>] (task_work_run+0xcc/0x108)
Dec 9 20:23:55 tegra-ubuntu kernel: [ 1033.334446] [<c008aac8>] (task_work_run+0xcc/0x108) from [<c006d1a4>] (do_exit+0x15c/0x3a4)
Dec 9 20:23:55 tegra-ubuntu kernel: [ 1033.334835] [<c006d1a4>] (do_exit+0x15c/0x3a4) from [<c006d5ec>] (do_group_exit+0x48/0xb8)
Dec 9 20:23:55 tegra-ubuntu kernel: [ 1033.335056] [<c006d5ec>] (do_group_exit+0x48/0xb8) from [<c007c144>] (get_signal_to_deliver+0x21c/0x434)
Dec 9 20:23:55 tegra-ubuntu kernel: [ 1033.335324] [<c007c144>] (get_signal_to_deliver+0x21c/0x434) from [<c0012644>] (do_signal+0x84/0x168)
Dec 9 20:23:55 tegra-ubuntu kernel: [ 1033.335584] [<c0012644>] (do_signal+0x84/0x168) from [<c0012a70>] (do_work_pending+0x6c/0xb4)
Dec 9 20:23:55 tegra-ubuntu kernel: [ 1033.351870] [<c0012a70>] (do_work_pending+0x6c/0xb4) from [<c000f1c0>] (work_pending+0xc/0x20)
Dec 9 20:23:55 tegra-ubuntu kernel: [ 1033.351898] ---[ end trace 83181803af49d533 ]---
Dec 9 20:23:55 tegra-ubuntu kernel: [ 1033.351921] gk20a gk20a.0: timed out waiting for gk20a channel to finish
Dec 9 20:23:55 tegra-ubuntu kernel: [ 1033.351930] ------------[ cut here ]------------
Dec 9 20:23:55 tegra-ubuntu kernel: [ 1033.351951] WARNING: at /dvs/git/dirty/git-master_linux/kernel/drivers/gpu/nvgpu/gk20a/channel_gk20a.c:453 gk20a_disable_channel+0x78/0x80()
Dec 9 20:23:55 tegra-ubuntu kernel: [ 1033.351960] Modules linked in: joydev dm_crypt dm_mod bnep rfcomm bluetooth rfkill nvhost_vi
Dec 9 20:23:55 tegra-ubuntu kernel: [ 1033.352003] CPU: 0 PID: 3857 Comm: Watchdog Tainted: G W 3.10.40-g8c4516e #1
Dec 9 20:23:55 tegra-ubuntu kernel: [ 1033.352022] [<c00168e0>] (unwind_backtrace+0x0/0x140) from [<c0013234>] (show_stack+0x18/0x1c)
Dec 9 20:23:55 tegra-ubuntu kernel: [ 1033.352043] [<c0013234>] (show_stack+0x18/0x1c) from [<c0067150>] (warn_slowpath_common+0x54/0x70)
Dec 9 20:23:55 tegra-ubuntu kernel: [ 1033.352060] [<c0067150>] (warn_slowpath_common+0x54/0x70) from [<c0067190>] (warn_slowpath_null+0x24/0x2c)
Dec 9 20:23:55 tegra-ubuntu kernel: [ 1033.352073] [<c0067190>] (warn_slowpath_null+0x24/0x2c) from [<c03dcc58>] (gk20a_disable_channel+0x78/0x80)
Dec 9 20:23:55 tegra-ubuntu kernel: [ 1033.352089] [<c03dcc58>] (gk20a_disable_channel+0x78/0x80) from [<c03dcd28>] (gk20a_free_channel+0xc8/0x3c0)
Dec 9 20:23:55 tegra-ubuntu kernel: [ 1033.352101] [<c03dcd28>] (gk20a_free_channel+0xc8/0x3c0) from [<c03dd074>] (gk20a_channel_release+0x54/0x110)
Dec 9 20:23:55 tegra-ubuntu kernel: [ 1033.352119] [<c03dd074>] (gk20a_channel_release+0x54/0x110) from [<c01501b0>] (__fput+0x94/0x200)
Dec 9 20:23:55 tegra-ubuntu kernel: [ 1033.352138] [<c01501b0>] (__fput+0x94/0x200) from [<c008aac8>] (task_work_run+0xcc/0x108)
Dec 9 20:23:55 tegra-ubuntu kernel: [ 1033.352154] [<c008aac8>] (task_work_run+0xcc/0x108) from [<c006d1a4>] (do_exit+0x15c/0x3a4)
Dec 9 20:23:55 tegra-ubuntu kernel: [ 1033.352164] [<c006d1a4>] (do_exit+0x15c/0x3a4) from [<c006d5ec>] (do_group_exit+0x48/0xb8)
Dec 9 20:23:55 tegra-ubuntu kernel: [ 1033.352179] [<c006d5ec>] (do_group_exit+0x48/0xb8) from [<c007c144>] (get_signal_to_deliver+0x21c/0x434)
Dec 9 20:23:55 tegra-ubuntu kernel: [ 1033.352195] [<c007c144>] (get_signal_to_deliver+0x21c/0x434) from [<c0012644>] (do_signal+0x84/0x168)
Dec 9 20:23:55 tegra-ubuntu kernel: [ 1033.352208] [<c0012644>] (do_signal+0x84/0x168) from [<c0012a70>] (do_work_pending+0x6c/0xb4)
Dec 9 20:23:55 tegra-ubuntu kernel: [ 1033.352220] [<c0012a70>] (do_work_pending+0x6c/0xb4) from [<c000f1c0>] (work_pending+0xc/0x20)
Dec 9 20:23:55 tegra-ubuntu kernel: [ 1033.352227] ---[ end trace 83181803af49d534 ]---
Any help would be appreciated.
many thanks
Mirko
