SQUASHFS error when trying to install Jetson 7.2 on Orin Nano
I am getting the exact error from this post: Squash FS Error during Jetpack 7.2 install
Same block, same size.
SquashFS error :Unable to read page, block d455b4, size ad40
I tried two different computers to write the USB drive, two different drives, fresh download on each.
I am a newbie at this and the “seeedstudio” link did not provide enough information to help me. What image do I write to the disk? The full ISO image? @john612 I would greatly appreciate if you can share a little more information.
I also tried the 7.1 jetpack image with similar results. Maybe there’s something specific to my hardware? Its an Advantech MIC-711-on if that makes a difference.
Could you tell us the exact file name of the JetPack 7.2 ISO you are using? We have made some fixes in the latest JetPack 7.2 ISO, so please check that you have the newest version. Thanks!
Thanks for the reply! I am using the iso file directly downloaded from NVIDIA:
jetsoninstaller-r39.2.1-2026-08-07-18-30-47-arm64.iso
I encountered the exact same SQUASHFS errors.
In my case, the cause was a USB hub. After connecting the installer USB drive directly to the Jetson instead of through the hub, the installation completed successfully.
Hopefully this helps.
Thank you for the reply.
My USB was plugged directly into the device. No other hub.
I finally got the install to work by skipping the USB entirely and using the SDK Manager to flash directly to the SSD.
