Squashfs: SQUASHFS error: Filesystem uses "lzo" compression
I’m new, so sorry for the questions.
I’m trying to install a program by snap (CCTV-VIEWER), and I’m having problems because I don’t have LZO enabled.
dec 29 03:29:09 nano systemd[1]: snap-cctv\x2dviewer-803.mount: Failed with result 'exit-code'.
-- Subject: Unit failed
-- Defined-By: systemd
-- Support: http://www.ubuntu.com/support
-- The unit snap-cctv\x2dviewer-803.mount has entered the 'failed' state with result 'exit-code'.
dec 29 03:29:09 nano kernel: squashfs: SQUASHFS error: Filesystem uses "lzo" compression. This is not supported
dec 29 03:29:09 nano systemd[1]: Failed to mount Mount unit for cctv-viewer, revision 803.
-- Subject: A start job for unit snap-cctv\x2dviewer-803.mount has failed
Since I don’t understand Linux Kernel, here’s the question:
Can I enable LZO to run on Ubuntu 20.04 on Jetson Nano?
Thanks in advance.
Hi @usuario_a1649,
Looks like you posted in the wrong forum. This will be better served in the Jetson Nano category. I will move it over for you.
Cheers, Tom K
Not if if install the lzo compression working for it?
