I’m running into a problem where the “redundant” connection to a storage system is not coming online for a SRP initiator/target setup where we have a single server direct attached to a storage array. The server has a dual port MT27600:
lspci | grep -i mell
02:00.0 Infiniband controller: Mellanox Technologies MT27600 [Connect-IB]
Ca : 0x5005076061d1cb83 ports 2 “IB Controller”
Ca : 0x5849560e566b0301 ports 2 “server002 HCA-1”
---- Performing Adapter Device Self Test ----
Number of CAs Detected … 1
PCI Device Check … PASS
Kernel Arch … x86_64
Host Driver Version … MLNX_OFED_LINUX-3.2-2.0.0.0 (OFED-3.2-2.0.0): 4.2.0-16-generic
Host Driver RPM Check … PASS
Firmware on CA #0 HCA … v10.14.2036
Firmware Check on CA #0 (HCA) … PASS
Host Driver Initialization … PASS
Number of CA Ports Active … 2
Port State of Port #1 on CA #0 (HCA)… UP 4X QDR (InfiniBand)
Port State of Port #2 on CA #0 (HCA)… UP 4X QDR (InfiniBand)
Error Counter Check on CA #0 (HCA)… PASS
Kernel Syslog Check … PASS
Node GUID on CA #0 (HCA) … 58:49:56:0e:56:6b:03:01
------------------ DONE ---------------------
OpenSM 4.6.1.MLNX20160112
