SSD as boot media in Jetson Orin NX
Hi All,
I have a query regarding the Jetson orin NX boot media.As per Jetson Orin NX data sheet and other documents I got an idea that QSPI(64MB) is the primary boot storage of the Jetson Orin NX. We can configure SSDs as secondary storage devices.But how can we configure one of the SSDs (If I am connecting two SSDs) as secondary storage device while flashing?
Hi joseneethu75,
You could refer to the following instruction to flash into an NVMe drive, and also use it as root file system. You could only select one of them as rootfs, and use another one just as storage.
Flashing Support - Flashing to an NVMe Drive
Hi @KevinFFF ,
Thank you for the response . I will check and get back to you.
