For “No CMAKE_CUDA_COMPILER could be found” error:
Please add nvcc to the PATH environment variable.
For example:
$ echo 'export PATH=/usr/local/cuda-10.2/bin:$PATH' >> ~/.bashrc
$ echo 'export LD_LIBRARY_PATH=/usr/local/cuda-10.2/lib64:$LD_LIBRARY_PATH' >> ~/.bashrc
$ source ~/.bashrc
For “cub/cub.cuh” error:
Please try following patch to see if it works:
diff --git a/plugin/CMakeLists.txt b/plugin/CMakeLists.txt
index 562681f..656cf9e 100644
--- a/plugin/CMakeLists.txt
+++ b/plugin/CMakeLists.txt
@@ -77,7 +77,7 @@ if(BERT_GENCODES)
include_directories(bertQKVToContextPlugin/fused_multihead_attention/include bertQKVToContextPlugin/fused_multihead_attention_v2/include)
endif()
-include_directories(common common/kernels ${CMAKE_SOURCE_DIR}/third_party)
+include_directories(common common/kernels ${CMAKE_SOURCE_DIR}/third_party ${CMAKE_SOURCE_DIR}/third_party/cub)
foreach(PLUGIN_ITER ${PLUGIN_LISTS})
include_directories(${PLUGIN_ITER})
