I converted successfully ssd-mobilenet-v3-large to tensorrt uff file. You can try it. Hope it will help you.
import graphsurgeon as gs
import tensorflow as tf
Input = gs.create_node("Input",
op="Placeholder",
dtype=tf.float32,
shape=[1, 3, 320, 320])
PriorBox = gs.create_plugin_node(name="GridAnchor", op="GridAnchor_TRT",
numLayers=6,
minSize=0.2,
maxSize=0.95,
aspectRatios=[1.0, 2.0, 0.5, 3.0, 0.33],
variance=[0.1,0.1,0.2,0.2],
featureMapShapes=[20, 10, 5, 3, 2, 1])
NMS = gs.create_plugin_node(name="NMS", op="NMS_TRT",
shareLocation=1,
varianceEncodedInTarget=0,
backgroundLabelId=0,
confidenceThreshold=1e-8,
nmsThreshold=0.6,
topK=100,
keepTopK=100,
numClasses=3,
inputOrder=[0, 2, 1],
confSigmoid=1,
isNormalized=1)
concat_priorbox = gs.create_node(name="concat_priorbox", op="ConcatV2", dtype=tf.float32, axis=2)
concat_box_loc = gs.create_plugin_node("concat_box_loc", op="FlattenConcat_TRT", dtype=tf.float32, axis=1, ignoreBatch=0)
concat_box_conf = gs.create_plugin_node("concat_box_conf", op="FlattenConcat_TRT", dtype=tf.float32, axis=1, ignoreBatch=0)
namespace_plugin_map = {
"MultipleGridAnchorGenerator": PriorBox,
"Postprocessor": NMS,
"Preprocessor": Input,
"ToFloat": Input,
"image_tensor": Input,
"Concatenate": concat_priorbox,
"concat": concat_box_loc,
"concat_1": concat_box_conf
def preprocess(dynamic_graph):
# Now create a new graph by collapsing namespaces
dynamic_graph.collapse_namespaces(namespace_plugin_map)
# Remove the outputs, so we just have a single output node (NMS).
dynamic_graph.remove(dynamic_graph.graph_outputs, remove_exclusive_dependencies=False)
# Disconnect the Input node from NMS, as it expects to have only 3 inputs.
dynamic_graph.find_nodes_by_op("NMS_TRT")[0].input.remove("Input")`Preformatted text`
convert-to-uff --input-file frozen_inference_graph.pb -O NMS -p config.py
If you have issue with Cast operation, checkout tensorflow models to branch 1.12.0 (from 1.13.0, tensorflow will Cast operation automatically to trained model) , add some SSD Mobilenet V3 stuffs, then export frozen model and convert it to uff file.
