Ok, it looks like from the docs you gave the URL to that R21.4 and the kernel edit will be fairly trivial. If for safety you want to clone the root partition before you start, or indeed the whole TK1, see:
http://elinux.org/Jetson/Cloning
The first actual step would be to flash R21.4, following the regular documentation. A command line, once rootfs is in on your desktop host machine, and you have run apply_binaries.sh, would be something like:
sudo ./flash.sh -S 14580MiB jetson-tk1 mmcblk0p1
You would then bring up the Jetson normally. There would be one change to /boot/extlinux/extlinux.conf, this would be to change “usb_port_owner_info=0” to instead be “usb_port_owner_info=2”. This enables USB3 on the full-size USB connector. Reboot after this file edit.
Although it may sound complicated, you would then put the kernel source on the TK1 and edit one line in one file, followed by putting the new kernel in. When using the u-boot boot loader (default of R21.x) you don’t even need to flash, you’d just copy some of the compiled files into place. It takes a bit of time, but is actually fairly pain-free.
If on your TK1 you unpack the kernel source to to your Jetson directory “/usr/src/kernels”, you will have a kernel subdirectory. Within that is file “drivers/usb/core/devio.c”. Search for the line:
static unsigned usbfs_memory_mb = 16;
…edit the “16” to instead be 1000. Build the kernel and modules (setting CONFIG_LOCALVERSION) and put them in place, reboot. All of the Jetson patching and USB3 setup will be complete.
General comments on building the kernel:
when your R21.4 first runs after flashing this new L4T version, save a copy of /proc/config.gz. This is a reflection of your running kernel configuration. Uncompressing it and renaming it “.config”, placed in the kernel source tree gives you an exact copy of the running kernel’s working configuration. Keep an archive copy of this file on both the Jetson and your host. For your case you will use this exact copy without edit. The kernel is getting a code change, but configuration is remaining constant.
The module search includes CONFIG_LOCALVERSION in the .config. Before you compile the new kernel, check your Jetson’s response to “uname -r”. You will see something like 3.10.40-gdacac96". The “-gdacac96” is the suffix which goes into CONFIG_LOCALVERSION. This will cause module searches to go to the original location and avoid complicating things.
You will need to copy the zImage to /boot, probably backing up the old one. I’d rename the old one “zImage-3.10.40-gdacac96-original”, and put the new one in by copy to name “zImage-3.10.40-gdacac96-cam” (short for camera). In your /boot/extlinux/extlinux.conf, you will see something like this:
LABEL primary
MENU LABEL primary kernel
LINUX <b>/boot/zImage</b>
The “/boot/zImage” is where this boot entry will look for the kernel…since you installed file “/boot/zImage-3.10.40-gdacac96-cam”, you would change the entry name “zImage” to “zImage-3.10.40-gdacac96-cam”.
Any make modules_install step would automatically use the CONFIG_LOCALVERSION of “-3.10.40-gdacac96” which is what the install was originally using…any modules_install would be correct without moving things around.
If you need to know more about kernel compile or install under u-boot, just ask.
