i am using jetson tx1 to do some image processing, it is also related to cuda. however, when i compile a project, it says that “sse2 instruction set not enabled”, and the project include the head file emmintrin.h. the head file first is not included in the path ~/gcc/4.8/include and i just move the single file into it, and so i do not know if it takes some effects. the gcc in tx1 just do not include this head file. i compile the project in qt, should i do some to set in the makefile to set qt support sse2 and i have tried some approaches but they didn’t work. i am asking if u could help me? if can please contact me with 1643686513@qq.com. thanks a lot
Hi Doge_1994,
If you are talking about the AMD x86_64 SSE/SSE2, then no, ARM CPUs do not support that. You can refer to below thread:
[url]https://devtalk.nvidia.com/default/topic/980212/[/url]
thanks a lot
