SSH problem in Jetson Orin Nano
Hi I have few questions. I want to connect my laptop to Jetson Orin Nano but ssh didn’t work. I already enable SSH port and also enable Autonomatic Login. And I tried to send ping but It did not work. Please help me
Can you log in normally on the Jetson itself? If so, what do you see from the command “ifconfig” and “route”?
Is the other computer running Linux? If so, what do you see from those same commands for the host PC (make sure to label if the output is from the host or from the Jetson)?
Do both devices talk to the same router or network switch? Are those routers or switches yours, or are they within a company that has firewalls and security set up?
