Hi there all. When running the image for Stable Diffusion, sourced from jetson-containers, I run into an issue. When giving it larger images, the machine suddenly switches off and needs to be manually started. What is causing this issue? Feel free to ask for more details from me. I would expect the container to crash before causing a system-level crash.
Which JetPack and docker image do you use?
Just want to confirm do you use AGX Xavier?
What kind of power supply do you use?
