*** stack smashing detected ***: <unknown> terminated
• Jetson AGX Xavier
• Deepstream 6.0
• JetPack 4.6
• TensorRT 8.0.1
• NVIDIA GPU Driver 32.6.1
Hi, I’m trying to make usb-input and rtsp-output pipeline with face recognition.
I used this code as an example: deepstream c++ rtsp流输出 - 代码先锋网
Here is my code
Makefile (2.6 KB)
deepstream_infer_tensor_meta_test.cpp (33.5 KB)
dstest2_pgie_config.txt (3.1 KB)
dstest2_sgie1_config.txt (423 Bytes)
So here is the issue:
When I’m starting pipeline and there is no faces in the frame it works well, but when face appears it printing embeddings one time and print this error:
+_+_+_+_+_+_+_+_+_+_+_+_+EMBEDDING+_+_+_+_+_+_+_+_+_+_+_+_+
There is 512 embeddings
I can’t understand where is the error exactly
Before I added rtsp-out it worked well (I user overlay as a sink)
Hi @gff1038m , Could you test your pipeline with the deepstream-test cli? You can write a simple config text with your pipeline to debug first, like
/opt/nvidia/deepstream/deepstream-X.X/samples/configs/deepstream-app/source1_usb_dec_infer_resnet_int8.txt
And run it with the cli:
deepstream-test "your config file"
After the cli works well. then you can write code refer the cli pipeline. Thanks
Hi, thank you for help, but I can’t find info about cli. What is this? And where is deepstream-test located?
Ok, I tried deepstream-app “config path”, so i’ll try to make my application with refer on deepstream-app. But why my code is not working?
I’m trying to make an app using deepstream-app. But can’t understand why g_print in deepstream_app_main.main() is not working?
Could you please show some guides or examples?
Hi @gff1038m ,
  1. You could learn the basic knowledge about Gstreamer, like source , sink, plugin, etc.
    https://gstreamer.freedesktop.org/documentation/tutorials/index.html?gi-language=c
  2. You could learn the basic plugin about Deepstream and know how to setup the config file
    https://docs.nvidia.com/metropolis/deepstream/dev-guide/text/DS_ref_app_deepstream.html
  3. Then you can just change the config file with different paras, like
  1. just use the deepstream-test "your config file" command to run without write any code
5.If the command works well, you can write code by referring the plugin in your config file
