Stack smashing detected
**• Hardware Platform (Jetson / GPU)**rtx3050
• DeepStream Version6.4
I am using deepsteram-app for peoplenet.
I can interface to 17 cctvs successfully.
When increased to one more camera and altogether 18, I have this error.
*** stack smashing detected ***: terminated
Aborted (core dumped)
The whole log is here
Warning: 'input-dims' parameter has been deprecated. Use 'infer-dims' instead.
tst1!
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so
[NvTrackerParams::getConfigRoot()] !!![WARNING] File doesn't exist. Will go ahead with default values
[NvMultiObjectTracker] Initialized
0:00:04.503105856 1350039 0x63ed0c14bcc0 INFO                 nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:2092> [UID = 1]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-6.4/samples/configs/conf-app/../../models/iFocus/resnet34_peoplenet_int8.onnx_b1_gpu0_int8.engine
WARNING: [TRT]: The getMaxBatchSize() function should not be used with an engine built from a network created with NetworkDefinitionCreationFlag::kEXPLICIT_BATCH flag. This function will always return 1.
INFO: ../nvdsinfer/nvdsinfer_model_builder.cpp:610 [Implicit Engine Info]: layers num: 3
0   INPUT  kFLOAT input_1:0       3x544x960
1   OUTPUT kFLOAT output_cov/Sigmoid:0 3x34x60
2   OUTPUT kFLOAT output_bbox/BiasAdd:0 12x34x60
0:00:04.641283671 1350039 0x63ed0c14bcc0 INFO                 nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2195> [UID = 1]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-6.4/samples/configs/conf-app/../../models/iFocus/resnet34_peoplenet_int8.onnx_b1_gpu0_int8.engine
0:00:04.645671984 1350039 0x63ed0c14bcc0 INFO                 nvinfer gstnvinfer_impl.cpp:328:notifyLoadModelStatus:<primary_gie> [UID 1]: Load new model:/opt/nvidia/deepstream/deepstream-6.4/samples/configs/conf-app/iFocus_primary.txt sucessfully
Runtime commands:
	h: Print this help
	q: Quit
	p: Pause
	r: Resume
** INFO: <bus_callback:338>: Pipeline ready
The config file is here.
iFocus_main.txt (9.5 KB)
What could be wrong?
CPU usages reached to 16% only and GPU usages also not exhausted.
This happened immediately right after the program starts.
1.How much GPU memory is used?
2.This may be a memory problem. You can use valgrind to detect whether there is a memory out of bounds.
Run valgrind as the following command.
valgrind --leak-check=full \
         --show-leak-kinds=all \
         --track-origins=yes \
         --verbose \
         --log-file=valgrind-out.txt \
         ./deepstream-app -c ../../../../samples/configs/conf-app/iFocus_main.txt
What do I observer?
It is screenshot during test.
I have segmentation fault at the end.
ser@va:/opt/nvidia/deepstream/deepstream-6.4/sources/apps/sample_apps/iFocus$ valgrind --leak-check=full          --show-leak-kinds=all          --track-origins=yes          --verbose          --log-file=valgrind-out.txt          ./deepstream-app -c ../../../../samples/configs/conf-app/iFocus_main.txt
** WARN: <parse_dsexample:908>: Unknown key 'batch-size' for group [ds-example]
tst1!
0:03:29.176800697 1363565    0x1406c6920 INFO                 nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:2092> [UID = 1]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-6.4/samples/configs/conf-app/../../models/iFocus/resnet34_peoplenet_int8.onnx_b1_gpu0_int8.engine
0:03:39.833621910 1363565    0x1406c6920 INFO                 nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2195> [UID = 1]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-6.4/samples/configs/conf-app/../../models/iFocus/resnet34_peoplenet_int8.onnx_b1_gpu0_int8.engine
0:03:40.122489031 1363565    0x1406c6920 INFO                 nvinfer gstnvinfer_impl.cpp:328:notifyLoadModelStatus:<primary_gie> [UID 1]: Load new model:/opt/nvidia/deepstream/deepstream-6.4/samples/configs/conf-app/iFocus_primary.txt sucessfully
Runtime commands:
	h: Print this help
	q: Quit
	p: Pause
	r: Resume
The followings are GPU memory usage for 17 cctvs. 17 cctvs runs very stable. Only changed to 18, I have issue.
17 cctvs, GPU memory usage is only ~1G. rtx3050 has 8GB.
1.Run nvidia-smi pmon to check if the dec is too high. The decoder may be fully loaded.
# gpu         pid   type     sm    mem    enc    dec    jpg    ofa    command
# Idx           #    C/G      %      %      %      %      %      %    name
After the crash, is there any output in the valgrind-out.txt from valgrind?
The valgrind file is here. Thanks.
valgrind-out.txt - Google Drive
Can you download the file?
Yes, I can.I’m trying to analyze it. I guess it’s due to array out of bounds. There’s not much progress so far.
You can refer to the following link
This is a screenshot for testing with 18 cctvs.
Recorded with nvidia-smi pmon. We can see that dec is only 13%.
Have you made any changes to the deepstream-app? Especially perf_cb and perf_measurement_callback, there seems to be overflow here
==1363565== 1 errors in context 1 of 777:
==1363565== Invalid write of size 4
==1363565==    at 0x1293B8: perf_cb (in /opt/nvidia/deepstream/deepstream-6.4/sources/apps/sample_apps/iFocus/deepstream-app)
==1363565==    by 0x14BE20: perf_measurement_callback (in /opt/nvidia/deepstream/deepstream-6.4/sources/apps/sample_apps/iFocus/deepstream-app)
==1363565==    by 0x51552C7: ??? (in /usr/lib/x86_64-linux-gnu/libglib-2.0.so.0.7200.4)
==1363565==    by 0x5154C43: g_main_context_dispatch (in /usr/lib/x86_64-linux-gnu/libglib-2.0.so.0.7200.4)
==1363565==    by 0x51AA2B7: ??? (in /usr/lib/x86_64-linux-gnu/libglib-2.0.so.0.7200.4)
==1363565==    by 0x51542B2: g_main_loop_run (in /usr/lib/x86_64-linux-gnu/libglib-2.0.so.0.7200.4)
==1363565==    by 0x12BD90: main (in /opt/nvidia/deepstream/deepstream-6.4/sources/apps/sample_apps/iFocus/deepstream-app)
==1363565==  Address 0x0 is not stack'd, malloc'd or (recently) free'd
Yeah I did slight modification in perf_cb (gpointer context, NvDsAppPerfStruct * str). I’ll check and thanks.
Stack smashing detected is because of that? Can’t be, right?
Not necessarily. If there is no problem with the official sample, it may be caused by the modification.
