Standalone Python: How are sensor render products scheduled under app.update()?
Important: Isaac Sim support
Note: For Isaac Sim support, the community is gradually transitioning from this forum to the Isaac Sim GitHub repository so that questions and issues can be tracked, searched, and resolved more efficiently in one place. Whenever possible, please create a GitHub Discussion or Issue there instead of starting a new forum topic.
Note: For any Isaac Lab topics, please submit your topic to its GitHub repo ( GitHub - isaac-sim/IsaacLab: Unified framework for robot learning built on NVIDIA Isaac Sim · GitHub ) following the instructions provided on Isaac Lab’s Contributing Guidelines ( Contribution Guidelines — Isaac Lab Documentation ).
6.0.0
5.1.0
5.0.0
4.5.0
4.2.0
4.1.0
4.0.0
4.5.0
2023.1.1
2023.1.0-hotfix.1
Other (please specify):
Operating System
Ubuntu 24.04
Ubuntu 22.04
Ubuntu 20.04
Windows 11
Windows 10
GPU Information
  • Model: RTX 4090
  • Driver Version: 580.126.09
Topic Description
Standalone Python: Is there any supported way to explicitly schedule or spread sensor rendering across frames?
Detailed Description
We are using Isaac Sim in standalone Python for a robotics simulation / SIL-style setup.
The main question is about the actual rendering / scheduling mechanism for sensors.
What we are trying to do:
  • keep a controlled loop period
  • maintain consistent timestamps between loops
  • spread sensor rendering load across frames when multiple sensors are active
What we expected:
  • some supported way to explicitly control which sensors are rendered on a given frame, or
  • some documented scheduling / load-sharing mechanism for sensor render products
What actually happened:
  • omni.kit.app.get_app_interface().update() appears to be the main path that drives rendering internally
  • but we cannot find a documented way to explicitly schedule per-sensor rendering from standalone Python
  • we also cannot find documentation explaining how registered render products are internally scheduled and rendered
We are not asking about:
  • publisher throttling
  • dropping outputs after rendering
  • post-processing rate reduction
We are specifically asking about render scheduling / load sharing of explicit sensors.
Steps to Reproduce
  1. Create a standalone Python Isaac Sim application
  2. Run a loop similar to :
while simulation_app.is_running():
if not sim.is_playing():
    sim.render()
    continue
loop_start = time.perf_counter()
sim.step(render=False)
now_wall = time.perf_counter()
if now_wall >= next_render_wall:
    sim.render()
    next_render_wall = now_wall + render_wall_period
elapsed = time.perf_counter() - loop_start
sleep_time = TARGET_WALL_DT - elapsed - time_debt
if sleep_time > 0:
    time.sleep(sleep_time)
    time_debt = 0.0
else:
    time_debt = abs(sleep_time)
    time_debt = min(time_debt, TARGET_WALL_DT)
  1. Add multiple rendered sensors using render products
  2. Add multiple rendered sensors using render products
  3. Observe loop timing as sensor count increases
Error Messages
No direct Python error in the main case.
The issue is mainly lack of documentation / lack of visible supported control over per-sensor render scheduling.
Screenshots or Videos
(If applicable, add screenshots or links to videos that demonstrate the issue)
Additional Information
What I’ve Tried
  1. checked omni.kit.app docs
  2. checked isaacsim.simulation_app docs
  3. checked omni.replicator.core docs
  4. checked render/update callback APIs
  5. checked Replicator render product / annotator / writer usage
  6. checked standalone camera and RTX lidar paths separately
I still could not find a clear answer to:
  • whether explicit per-sensor render scheduling is supported
  • how sensor render products are internally scheduled under app.update()
Related Issues
(If you’re aware of any related issues or forum posts, please link them here)
Additional Context
If explicit per-sensor render scheduling is not supported, please confirm whether the intended model is simply:
  • all active sensor render products are handled by the main update/render path
  • and users can only control rates after rendering, not the render scheduling itself
If there is a supported mechanism, please point to the recommended API or design pattern.
Unfortunately, as you surmised, explicit per-sensor render scheduling is not supported. They are all rendered simultaneously.
You may be able to work around this by enabling/disabling sensors per frame. Something like:
rp1 = rep.create.render_product("/World/Camera1", (640, 480))
rp2 = rep.create.render_product("/World/Camera2", (640, 480))
frame = 0
# Alternate which sensor renders each frame
rp1.hydra_texture.set_updates_enabled(frame % 2 == 0)
rp2.hydra_texture.set_updates_enabled(frame % 2 == 1)
sim.render()
frame += 1
This is untested, but you get the idea.
HTH
Thanks for the clarification. This is very helpful, especially the confirmation that explicit per-sensor render scheduling is not supported.
We had already tried the manual hydra_texture.set_updates_enabled(True/False) style workaround. In our case, the main effects were:
  • visible GUI flickering when sensors were alternated
  • a noticeable warm-up / stabilization cost when re-enabling render products (on the order of ~100 ms in our tests)
So while the workaround is conceptually clear, it did not behave like a practical solution for our real-time loop.
Can you confirm whether this kind of flicker / warm-up cost is expected when toggling render products this way?
If so, then it seems this workaround is mainly a functional workaround, not a low-overhead scheduling mechanism.
Thanks again.
This topic was automatically closed after 6 days. New replies are no longer allowed.
