Hello all, I am receiving the following exception in the Maxscript listener when I “Export to USD”, from 3DS Max 2023 when using Physical Material, and a bitmap with the name “base color texture” or “base_color_texture”.
Exception with set_plug_value color: attribute base_color_map type is <class ‘str’> valueStr is base color texture:Bitmap
Similarly, experiencing the same error when using the “Standard” material as well.
Exception with set_plug_value color: attribute base_color_shader type is <class ‘str’> valueStr is base color texture:Bitmap
get_filename_from_texturemap: Unhandled Bitmap data type!!! [0,0,0], type name is MXSWrapperBase
can_set_plug_value: skip attribute=thin_film_IOR
WARNING: Unable to set output plug “thin_film_IOR”.
The issue does not occur with the MDLMaster material, is this something anyone else has been able to reproduce?
