Standoff for SoM
Hi !
Is there anybody knows what’s the standard type of the screw on the evaluation board as image ?
I just found the MEC23 from BOM file but there is no information for the MEC17.
Standoff M3.0x0.5 L3.0mm Carbon Steel, Tin Plate
be glad your nose is on your face poem meaning
Thank you very much !
You want to know the length of the standoff I assume? It depends on the connector used, see also the Samtec SEAM product page. The default used on the dev kit is a SEAM-50-02.0-S-08-2-A-K-TR, so default length needed is 7mm.
Hi, the standoffs are M3X0.5X7 mm.
Thanks for you all !
