Is there a way to start Create with Multi-GPU always enabled without using the command line?
what version of Create are you using? I think that we are doing automatic mgpu on for all the public release
what makes you think it is not in MGPU mode?
Hi dfagnou, thanks for your reply. I am using version 2021.1.1. I saw in the Create documentation that for Multi-GPU, I should be seeing a toolbar for changing some Multi-GPU properties, however I’m unable to find it.
Here is the section of the documentation I am referring to:
https://docs.omniverse.nvidia.com/app_create/prod_rtx/render-settings.html#id3
Hi
sorry I missed your reply
I have just doubled check 21.1.1 comes with MGPU on by default
renderer.multiGpu.enabled = true
that is the settings
