Hello, I’m setting up a dynamic pipeline to use Gst-nvmultiurisrcbin with the REST API. The problem is that I start it empty and when I add a camera to the API with camera_add or camera_streaming I get an error and it can’t connect at all. When doing the same thing with a local .h264 file in the Deepstream image, everything works without problems. Curiously, in the RTSP use case, if I start the pipeline with at least one camera and then start adding others via the API, everything works fine. Can someone please guide me? I’ve been trying for a week and can’t find what’s going on. There are no examples of Python pipelines in a similar situation.
I attach the code here.
CODE.pdf (65.1 KB)
And this the error after i add the first RTSP to the empty pipeline:
Creating Pipeline
Starting pipeline without any RTSP source. Waiting for API POST to add streams.
Creating multiurisrcbin
Creating Pgie
Creating nvtracker
Creating nvvidconv1
Creating filter1
Creating tiler
Creating nvvidconv
Creating nvosd
Creating nvvidconv_postosd
Creating filter2
Creating sink
WARNING: Overriding infer-config batch-size 2 with number of sources 32
Adding elements to Pipeline
Is it Integrated GPU? : 0
Starting pipeline
Civetweb version: v1.16
Server running at port: 9014
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so
[NvMultiObjectTracker] Initialized
0:00:01.025952848 1214 0x5c004589e930 INFO nvinfer gstnvinfer.cpp:684:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:2092> [UID = 1]: deserialized trt engine from :/models/deepstream/7.1/A100/32/peoplenet/model_int8.plan
INFO: ../nvdsinfer/nvdsinfer_model_builder.cpp:327 [FullDims Engine Info]: layers num: 3
0 INPUT kFLOAT input_1:0 3x544x960 min: 1x3x544x960 opt: 32x3x544x960 Max: 32x3x544x960
1 OUTPUT kFLOAT output_cov/Sigmoid:0 3x34x60 min: 0 opt: 0 Max: 0
2 OUTPUT kFLOAT output_bbox/BiasAdd:0 12x34x60 min: 0 opt: 0 Max: 0
0:00:01.026055133 1214 0x5c004589e930 INFO nvinfer gstnvinfer.cpp:684:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2195> [UID = 1]: Use deserialized engine model: /models/deepstream/7.1/A100/32/peoplenet/model_int8.plan
0:00:01.042540615 1214 0x5c004589e930 INFO nvinfer gstnvinfer_impl.cpp:343:notifyLoadModelStatus: [UID 1]: Load new model:config_peoplenet.txt sucessfully
uri:/api/v1/stream/add
method:POST
Resetting source 0, attempts: 1
Warning: gst-stream-error-quark: No data from source since last 30 sec. Trying reconnection (1): gstdsnvurisrcbin.cpp(1529): watch_source_status (): /GstPipeline:pipeline0/GstDsNvMultiUriBin:nvmultiurisrcbin/GstBin:nvmultiurisrcbin_creator/GstDsNvUriSrcBin:dsnvurisrcbin0
