----Jetson Nano eMMC version ----
Booting start UART debugging Message
[0000.220] [L4T TegraBoot] (version 00.00.2018.01-l4t-8728f3cb)
[0000.225] Processing in cold boot mode Bootloader 2
[0000.230] A02 Bootrom Patch rev = 1023
[0000.234] Power-up reason: pmc por
[0000.237] No Battery Present
[0000.239] pmic max77620 reset reason
[0000.243] pmic max77620 NVERC : 0x50
[0000.246] RamCode = 0
[0000.248] Platform has DDR4 type RAM
[0000.252] max77620 disabling SD1 Remote Sense
[0000.256] Setting DDR voltage to 1125mv
[0000.260] Serial Number of Pmic Max77663: 0x62e74
[0000.268] Entering ramdump check
[0000.271] Get RamDumpCarveOut = 0x0
[0000.274] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.279] Last reboot was clean, booting normally!
[0000.283] Sdram initialization is successful
[0000.288] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.294] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.299] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.305] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.311] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.317] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.323] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.329] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0000.345] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.351] Platform-DebugCarveout: 0
[0000.354] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.360] Non secure mode, and RB not enabled.
[0000.364] *** Booting BFS0.
[0000.367] Initialize FailControl
[0000.370] Read PT from (0:3)
[0000.385] Csd NumOfBlocks=0
[0000.424] PT crc32 and magic check passed.
[0000.428] Using BFS PT to query partitions
[0000.432] PT: Partition LNX NOT found !
[0000.436] *** Booting KFS0.
[0000.438] NvTbootFailControlDoFailover: No failover; Continuing …
[0000.445] BoardID = 3448, SKU = 0x2
[0000.448] Not Nano-SD or !QSPI-ONLY, check GPT table first …
[0000.453] Read GPT from (0:3)
[0000.462] Using GPT Primary to query partitions
[0000.466] NvTbootFailControlDoFailover: No failover; Continuing …
[0000.473] Loading Tboot-CPU binary
[0000.479] Verifying TBC in OdmNonSecureSBK mode
[0000.489] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.496] Bootloader downloaded successfully.
[0000.500] Downloaded Tboot-CPU binary to 0xa0000258
[0000.505] MAX77620_GPIO5 configured
[0000.508] CPU power rail is up
[0000.511] CPU clock enabled
[0000.515] Performing RAM repair
[0000.518] Updating A64 Warmreset Address to 0xa00002e9
[0000.523] BoardID = 3448, SKU = 0x2
[0000.526] Not Nano-SD or !QSPI-ONLY, check GPT table first …
[0000.532] NvTbootFailControlDoFailover: No failover; Continuing …
[0000.538] Loading NvTbootBootloaderDTB
[0000.555] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0000.627] Bootloader DTB Load Address: 0x83000000
[0000.631] BoardID = 3448, SKU = 0x2
[0000.634] Not Nano-SD or !QSPI-ONLY, check GPT table first …
[0000.640] Loading NvTbootKernelDTB
[0000.657] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0000.728] Kernel DTB Load Address: 0x83100000
[0000.732] BoardID = 3448, SKU = 0x2
[0000.736] Not Nano-SD or !QSPI-ONLY, check GPT table first …
[0000.742] NvTbootFailControlDoFailover: No failover; Continuing …
[0000.749] Loading cboot binary
[0000.760] Verifying EBT in OdmNonSecureSBK mode
[0000.801] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0000.808] Bootloader downloaded successfully.
[0000.812] BoardID = 3448, SKU = 0x2
[0000.816] Not Nano-SD or !QSPI-ONLY, check GPT table first …
[0000.822] NvTbootFailControlDoFailover: No failover; Continuing …
[0000.828] PT: Partition NCT NOT found !
[0000.832] Warning: Find Partition via PT Failed
[0000.836] Next binary entry address: 0x92c00258
[0000.840] BoardId: 3448
[0000.845] Overriding pmu board id with proc board id
[0000.850] Display board id is not available
[0000.854] BoardID = 3448, SKU = 0x2
[0000.857] Not Nano-SD or !QSPI-ONLY, check GPT table first …
[0000.863] NvTbootFailControlDoFailover: No failover; Continuing …
[0000.877] Verifying SC7EntryFw in OdmNonSecureSBK mode
[0000.933] /bpmp deleted
[0000.935] SC7EntryFw header found loaded at 0xff700000
[0000.972] /clock@70110000 not present in the kernel dtb
[0000.977] Bpmp FW successfully loaded
[0000.980] BoardID = 3448, SKU = 0x2
[0000.983] Not Nano-SD or !QSPI-ONLY, check GPT table first …
[0000.989] NvTbootFailControlDoFailover: No failover; Continuing …
[0000.997] WB0 init successfully at 0xff780000
[0001.001] Verifying NvTbootWb0 in OdmNonSecureSBK mode
[0001.006] Set NvDecSticky Bits
[0001.010] GSC2 address ff53fffc value c0edbbcc
[0001.016] GSC MC Settings done
[0001.019] BoardID = 3448, SKU = 0x2
[0001.022] Not Nano-SD or !QSPI-ONLY, check GPT table first …
[0001.029] TOS Image length 53680
[0001.032] Monitor size 53680
[0001.034] OS size 0
[0001.040] Secure Os AES-CMAC Verification Success!
[0001.044] TOS image cipher info: plaintext
[0001.048] Loading and Validation of Secure OS Successful
[0001.064] SC7 Entry Firmware - 0xff700000, 0x4000
[0001.069] NvTbootPackSdramParams: start.
[0001.074] NvTbootPackSdramParams: done.
[0001.078] Tegraboot started after 149411 us
[0001.082] Basic modules init took 741333 us
[0001.086] Sec Bootdevice Read Time = 54 ms, Read Size = 3682 KB
[0001.091] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0001.097] Next stage binary read took 7378 us
[0001.101] Carveout took -34773 us
[0001.104] CPU initialization took 240551 us
[0001.108] Total time taken by TegraBoot 954489 us
[0001.113] Starting CPU & Halting co-processor
64NOTICE: BL31: v1.3(release):b5eeb33
NOTICE: BL31: Built : 14:22:20, Apr 20 2022
ERROR: Error initializing runtime service trusty_fast
Unhandled Exception in EL3.
x30 = 0x00000000ff800094
x0 = 0x00000000ff80f000
x1 = 0x0000000000000000
x2 = 0x0000000000000000
x3 = 0x0000000000000040
x4 = 0x0000000000000000
x5 = 0x0000000000000003
x6 = 0x0000000000000008
x7 = 0x00000000ff80d000
x8 = 0x00000000ff8023ec
x9 = 0x0000000000000000
x10 = 0x0000000000000000
x11 = 0x0000000000000000
x12 = 0x0000000000000000
x13 = 0x0000000000000000
x14 = 0x0000000000000000
x15 = 0x0000000000000000
x16 = 0x0000000000000000
x17 = 0x0000000000000000
x18 = 0x0000000000000011
x19 = 0x00000000ff800018
x20 = 0x0000000088000320
x21 = 0x00000000880003d8
x22 = 0x83306903a0872d72
x23 = 0x300269b77a00711d
x24 = 0x0a652e32c2b4541e
x25 = 0x40c0c4ed497ca4c7
x26 = 0xe57268c1965e12ab
x27 = 0x0000000000000001
x28 = 0x0000000000000000
x29 = 0xce28d45218e439b0
scr_el3 = 0x0000000000000238
sctlr_el3 = 0x0000000000cd183f
cptr_el3 = 0x0000000000000000
tcr_el3 = 0x000000008080351d
daif = 0x00000000000003c0
mair_el3 = 0x00000000004404ff
spsr_el3 = 0x00000000600002cc
elr_el3 = 0x00000000fb88038c
ttbr0_el3 = 0x00000000ff814b00
esr_el3 = 0x0000000086000006
far_el3 = 0x00000000fb88038c
spsr_el1 = 0x0000000000000000
elr_el1 = 0x0000000000000000
spsr_abt = 0x0000000000000000
spsr_und = 0x0000000000000000
spsr_irq = 0x0000000000000000
spsr_fiq = 0x0000000000000000
sctlr_el1 = 0x0000000030d00800
actlr_el1 = 0x0000000000000000
cpacr_el1 = 0x0000000000000000
csselr_el1 = 0x0000000000000000
sp_el1 = 0x0000000000000000
esr_el1 = 0x0000000000000000
ttbr0_el1 = 0x0000000000000000
ttbr1_el1 = 0x0000000000000000
mair_el1 = 0x0000000000000000
amair_el1 = 0x0000000000000000
tcr_el1 = 0x0000000000000000
tpidr_el1 = 0x0000000000000000
tpidr_el0 = 0x0000000000000000
tpidrro_el0 = 0x0000000000000000
dacr32_el2 = 0x0000000000000000
ifsr32_el2 = 0x0000000000000000
par_el1 = 0x0000000000000000
mpidr_el1 = 0x0000000080000000
afsr0_el1 = 0x0000000000000000
afsr1_el1 = 0x0000000000000000
contextidr_el1 = 0x0000000000000000
vbar_el1 = 0x0000000000000000
cntp_ctl_el0 = 0x0000000000000000
cntp_cval_el0 = 0x0000000000000000
cntv_ctl_el0 = 0x0000000000000000
cntv_cval_el0 = 0x0000000000000000
cntkctl_el1 = 0x0000000000000002
fpexc32_el2 = 0x0000000000000700
sp_el0 = 0x00000000ff80d5c0
isr_el1 = 0x0000000000000000
cpuectlr_el1 = 0x0000001b00000047
cpumerrsr_el1 = 0x0000000000000000
l2merrsr_el1 = 0x0000000000000000
gicc_hppir = 0x00000000000003ff
gicc_ahppir = 0x00000000000003ff
gicc_ctlr = 0x00000000000001eb
gicd_ispendr regs (Offsets 0x200 - 0x278)
Offset: value
0000000000000200: 0x0000000000000000
0000000000000204: 0x0000000000000000
0000000000000208: 0x0000000000000000
000000000000020c: 0x0000000000000000
0000000000000210: 0x0000000000000000
0000000000000214: 0x0000000000000000
0000000000000218: 0x0000000000000000
000000000000021c: 0x0000000000000000
0000000000000220: 0x0000000000000000
0000000000000224: 0x0000000000000000
0000000000000228: 0x0000000000000000
000000000000022c: 0x0000000000000000
0000000000000230: 0x0000000000000000
0000000000000234: 0x0000000000000000
0000000000000238: 0x0000000000000000
000000000000023c: 0x0000000000000000
0000000000000240: 0x0000000000000000
0000000000000244: 0x0000000000000000
0000000000000248: 0x0000000000000000
000000000000024c: 0x0000000000000000
0000000000000250: 0x0000000000000000
0000000000000254: 0x0000000000000000
0000000000000258: 0x0000000000000000
000000000000025c: 0x0000000000000000
0000000000000260: 0x0000000000000000
0000000000000264: 0x0000000000000000
0000000000000268: 0x0000000000000000
000000000000026c: 0x0000000000000000
0000000000000270: 0x0000000000000000
0000000000000274: 0x0000000000000000
0000000000000278: 0x0000000000000000
000000000000027c: 0x0000000000000000
Jetson Nano has been operating in buildings without human hands for a long time.
It is Embedded communication system.
We want to know What is problems in Jetson Nano Module?
Tested on Another Custom Board. same result.
Not yet, eMMC flash burning.
