I built my application outside of Visual Studio, but am attempting to use Nsight Tegra to debug it.
When I start debugging all the steps succeed (Deploying application, Launching application, Starting GDB server, Starting Java debugger) until I reach Starting GDB debugger which give me the following error:
Failed to attach: Remote communication error. Target disconnected.: No error…
In the output window I see:
Device API level: 17.
Android: Setting ports…
Android: Starting GDB server on device…
Android: Starting C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\Platforms\Android\gdb.exe …
gdb.setup file was not found, initialization is skipped.
Android: Loading C:\Users\xxxxx\AppData\Local\Temp\Android\015d2a4ffa5c0018\system/bin/app_process …
Android: Connecting to remote device…
On my android device, sometimes the application will crash (no debug info), and sometimes the application is still “Waiting for debugger.”
Any thoughts on how I might be able to discover the problem?
