Here’s the summary of the steps as outlined on the getting started with the IVA developer program:
- Install Docker related software on Ubuntu Linux environment :
Install Docker.
Install Nvidia driver (>= 384.xx) (please can you be more specific on the version? I am using Ubuntu 19.04
Install nvidia-docker.
4.Sign into ngc.nvidia.com using the same credentials as your NVIDIA account
- Go to Configuration tab to generate the API key. Save this API key in a secure location. You’ll need it throughout using software.
6.Download the docker container:
docker login nvcr.io
Username: $oa (where is the username? Is this the same username for the NVIDIA developer program)
Password:(is this the same password to the Nvidia Developer program or something else?)
- docker pull nvcr.io/nvidia/tlt-streamanalytics:v0.3_py2
Where is the documentation from https://developer.nvidia.com/transfer-learning-toolkit to get started?
Please an someone clarify these issues?
Thank you
