Statement Functions and OpenMP
Hi, I don’t know if this is the right place for this question, but here goes.
Is there any standard way of using statement functions in code parallized with OpenMP?
Ex:
REAL*8  :: omega,a,b,c,d,t0,expp,pp
OMEGA(A,B,C,D) = A + B * C ** (D - 1.0d0)
ZC = 0;
!$omp parallel DEFAULT(shared) private(a,b,d,pp)
!$omp do
   something = omega(a, b, c, d);
!$omp enddo
!$omp end parallel
I couldn’t seem to move the statement functions into the parallel block, and as things are it’s telling me that a,b,d,pp can’t be private.[/quote]
Hi khea_actua1,
I think this a compiler error with our 9.0 version. I have created a technical problem report (TPR#16350) and sent if off to our engineers. I was able to recreate the error here and show that it works with 8.0 but fails with the same error in 9.0.
As a work around, you could rewrite OMEGA to be an internal function instead of a statement function.
Thanks for the report,
Mat
Hi khea_actua1,
I was wrong, this in not a compiler error. Variables appearing in the rhs of statement function definitions cannot appear in PRIVATE, FIRSTPRIVATE, and LASTPRIVATE clauses. Earlier versions of pgf90 failed to detect the error.
I have closed TPR#16350.
  • Mat
So would the only solution be making these internal functions?
-what is the technical explanation that statement function variables cannot be private. As long those variables are computed inside the paralle region, I think it should be OK.
I just wrote a small example, it compiles with older version of compiler, but not with version 9.
program sf1
real :: x,y,sf,z
sf(x,y)=xx+yy
!$omp parallel do default(shared) private(i,j,x,y,z)
do i=1,8
do j =1,4
x=float(i)
y=float(j)
z=sf(x,y)
write(6,*)'pab x,y,z ',x,y,z
enddo
enddo
!$omp end parallel do
stop
end
Is it a big or a feature in ver 9 of compiler?
Hi bpabla,
I thought it might be ok as well, until it was pointed out the OpenMP 3.0 spec specifically disallows it. From the bottom of page 91 of http://www.openmp.org/mp-documents/spec30.pdf
• Variables that appear in namelist statements, in variable format expressions, and in Fortran
expressions for statement function definitions, may not appear in a private clause.
khea_actua1, yes, I think you should change these to internal functions.
Hope this helps,
Mat
