I have installed the intel wifi chip on my jetson nano, but I need help configuring a static ip. The ip address needs to changed from 192.168.2.x to 192.168.1.x. I tried the command line approach, but the jetson nano does not have a netplan directory and config.yaml file. I also tried the graphical approach and that does not work either. It cannot connect to internet. This is urgent.
Does “sudo nm-connection-editor
” work? Also, what do you mean that you installed the chip? Is it USB? PCIe? Custom carrier board?
