Hello, I am very new to nsight environment and cuda development. So, I need to create a static library project and generate a libXX.a output.
Nsight could not manage to create a libXX.a output although the compilation of the source files is completed. I have changed the same project to generate a shared library, it works.
The output says:
Building target: libXX.a
Invoking: NVCC Archiver
nvcc -lib -o “libXX.a” ./main.o
/bin/sh: 1: nvcc: not found
makefile:58: recipe for target ‘libXX.a’ failed
make: Leaving directory ‘/home/ubuntu/work/XX/Debug’
make: *** [libXX.a]Error 127
Shell completed (exit code = 2)
Thank you
