I am very interested in the performance data of BlueField’s embedded switch, which is also refered to as PCIe switch or eSwich. However, I cannot found these information from the documents:
Technical, based on the type of DPU you have (25/100/200) You can check the datasheet (https://www.nvidia.com/content/dam/en-zz/Solutions/Data-Center/documents/datasheet-nvidia-bluefield-2-dpu.pdf), you should be reaching rate line (results may varies based on deployment(s)
We do not release official performance (white papers) however, if that helps, you can review performance reports we have posted for DPDK/Bluefieldfromhttp://fast.dpdk.org/doc/perf/DPDK_22_03_NVIDIA_Mellanox_NIC_performance_report.pdf
