0:00:00.083427937 4290 0x5623395bc070 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1716> [UID = 1]: Trying to create engine from model files
INFO: ../nvdsinfer/nvdsinfer_func_utils.cpp:39 [TRT]: UFFParser: Did not find plugin field entry scoreBits in the Registered Creator for layer NMS
INFO: ../nvdsinfer/nvdsinfer_func_utils.cpp:39 [TRT]: Some tactics do not have sufficient workspace memory to run. Increasing workspace size may increase performance, please check verbose output.
INFO: ../nvdsinfer/nvdsinfer_func_utils.cpp:39 [TRT]: Detected 1 inputs and 2 output network tensors.
0:00:24.279772551 4290 0x5623395bc070 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1749> [UID = 1]: serialize cuda engine to file: /opt/nvidia/deepstream/deepstream-5.1/sources/apps/sample_apps/deepstream-transfer-learning-app/configs/dssd_head/export18/dssd_resnet18_epoch_2.etlt_b1_gpu0_fp32.engine successfully
INFO: ../nvdsinfer/nvdsinfer_model_builder.cpp:685 [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT Input 3x300x300
1 OUTPUT kFLOAT NMS 1x200x7
2 OUTPUT kFLOAT NMS_1 1x1x1
0:00:24.286733350 4290 0x5623395bc070 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<primary_gie> [UID 1]: Load new model:/opt/nvidia/deepstream/deepstream-5.1/sources/apps/sample_apps/deepstream-transfer-learning-app/configs/dssd_head/config_infer_primary_dssd.txt sucessfully
Runtime commands:
h: Print this help
q: Quit
p: Pause
r: Resume
NOTE: To expand a source in the 2D tiled display and view object details, left-click on the source.
To go back to the tiled display, right-click anywhere on the window.
**PERF: FPS 0 (Avg)
**PERF: 0.00 (0.00)
** INFO: <bus_callback:181>: Pipeline ready
** INFO: <bus_callback:167>: Pipeline running
ERROR: ../nvdsinfer/nvdsinfer_func_utils.cpp:33 [TRT]: Assertion failed: status == STATUS_SUCCESS
/home/bcao/code/gitlab/TRT7.2/oss/plugin/nmsPlugin/nmsPlugin.cpp:119
Aborting...
Aborted
deepstream-app version 5.1.0
DeepStreamSDK 5.1.0
CUDA Driver Version: 11.2
CUDA Runtime Version: 10.1
TensorRT Version: 7.2
cuDNN Version: 8.0
libNVWarp360 Version: 2.0.1d3
1 if no any code and configure modification, can you run deepstream-transfer-learning-app successfully?
2 did you do any code modification? please provide your diff and configure file.
deaepstream-transfer learning running with other models. Problem with tensorrt oss required models.
I installed tensor oss.
git clone -b 21.03 https://github.com/nvidia/TensorRT
cd TensorRT/
git submodule update --init --recursive
export TRT_SOURCE=`pwd`
cd $TRT_SOURCE
mkdir -p build && cd build
/usr/local/bin/cmake .. -DGPU_ARCHS=61 -DTRT_LIB_DIR=/usr/lib/x86_64-linux-gnu/ -DCMAKE_C_COMPILER=/usr/bin/gcc -DTRT_BIN_DIR=`pwd`/out
Building for TensorRT version: 7.2.2, library version: 7
-- Targeting TRT Platform: x86_64
-- CUDA version set to 10.1
-- cuDNN version set to 8.0
-- Protobuf version set to 3.0.0
-- Using libprotobuf /home/dell/TensorRT/build/third_party.protobuf/lib/libprotobuf.a
-- ========================= Importing and creating target nvinfer ==========================
-- Looking for library nvinfer
-- Library that was found /usr/lib/x86_64-linux-gnu/libnvinfer.so
-- ========================= Importing and creating target nvuffparser ==========================
-- Looking for library nvparsers
-- Library that was found /usr/lib/x86_64-linux-gnu/libnvparsers.so
-- GPU_ARCHS defined as 61. Generating CUDA code for SM 61
-- Protobuf proto/trtcaffe.proto -> proto/trtcaffe.pb.cc proto/trtcaffe.pb.h
-- /home/dell/TensorRT/build/parsers/caffe
Generated: /home/dell/TensorRT/build/parsers/onnx/third_party/onnx/onnx/onnx_onnx2trt_onnx-ml.proto
Generated: /home/dell/TensorRT/build/parsers/onnx/third_party/onnx/onnx/onnx-operators_onnx2trt_onnx-ml.proto
-- ******** Summary ********
-- CMake version : 3.13.5
-- CMake command : /usr/local/bin/cmake
-- System : Linux
-- C++ compiler : /usr/bin/g++
-- C++ compiler version : 7.5.0
-- CXX flags : -Wno-deprecated-declarations -DBUILD_SYSTEM=cmake_oss -Wall -Wno-deprecated-declarations -Wno-unused-function -Wnon-virtual-dtor
-- Build type : Release
-- Compile definitions : _PROTOBUF_INSTALL_DIR=/home/dell/TensorRT/build;ONNX_NAMESPACE=onnx2trt_onnx
-- CMAKE_PREFIX_PATH :
-- CMAKE_INSTALL_PREFIX : /usr/lib/x86_64-linux-gnu/..
-- CMAKE_MODULE_PATH :
-- ONNX version : 1.6.0
-- ONNX NAMESPACE : onnx2trt_onnx
-- ONNX_BUILD_TESTS : OFF
-- ONNX_BUILD_BENCHMARKS : OFF
-- ONNX_USE_LITE_PROTO : OFF
-- ONNXIFI_DUMMY_BACKEND : OFF
-- ONNXIFI_ENABLE_EXT : OFF
-- Protobuf compiler :
-- Protobuf includes :
-- Protobuf libraries :
-- BUILD_ONNX_PYTHON : OFF
-- Found TensorRT headers at /home/dell/TensorRT/include
-- Find TensorRT libs at /usr/lib/x86_64-linux-gnu/libnvinfer.so;/usr/lib/x86_64-linux-gnu/libnvinfer_plugin.so;TENSORRT_LIBRARY_MYELIN-NOTFOUND
-- Could NOT find TENSORRT (missing: TENSORRT_LIBRARY)
ERRORCannot find TensorRT library.
-- Adding new sample: sample_algorithm_selector
-- - Parsers Used: caffe
-- - InferPlugin Used: OFF
-- - Licensing: opensource
-- Adding new sample: sample_char_rnn
-- - Parsers Used: uff;caffe;onnx
-- Adding new sample: sample_dynamic_reshape
-- - Parsers Used: onnx
-- Adding new sample: sample_fasterRCNN
-- - InferPlugin Used: ON
-- Adding new sample: sample_googlenet
-- Adding new sample: sample_int8
-- Adding new sample: sample_int8_api
-- Adding new sample: sample_mlp
-- Adding new sample: sample_mnist
-- Adding new sample: sample_mnist_api
-- Adding new sample: sample_movielens
-- Adding new sample: sample_movielens_mps
-- Adding new sample: sample_nmt
-- - Parsers Used: none
-- Adding new sample: sample_onnx_mnist
-- Adding new sample: sample_plugin
-- Adding new sample: sample_reformat_free_io
-- Adding new sample: sample_ssd
-- Adding new sample: sample_uff_fasterRCNN
-- Adding new sample: sample_uff_maskRCNN
-- Adding new sample: sample_uff_mnist
-- Adding new sample: sample_uff_plugin_v2_ext
-- Adding new sample: sample_uff_ssd
-- Adding new sample: sample_onnx_mnist_coord_conv_ac
-- Adding new sample: trtexec
-- - Parsers Used: caffe;uff;onnx
CMake Error: The following variables are used in this project, but they are set to NOTFOUND.
Please set them or make sure they are set and tested correctly in the CMake files:
CUBLASLT_LIB
linked by target "nvinfer_plugin" in directory /home/dell/TensorRT/plugin
CUBLAS_LIB
linked by target "sample_algorithm_selector" in directory /home/dell/TensorRT/samples/opensource/sampleAlgorithmSelector
linked by target "sample_char_rnn" in directory /home/dell/TensorRT/samples/opensource/sampleCharRNN
linked by target "sample_dynamic_reshape" in directory /home/dell/TensorRT/samples/opensource/sampleDynamicReshape
linked by target "sample_fasterRCNN" in directory /home/dell/TensorRT/samples/opensource/sampleFasterRCNN
linked by target "sample_googlenet" in directory /home/dell/TensorRT/samples/opensource/sampleGoogleNet
linked by target "sample_int8" in directory /home/dell/TensorRT/samples/opensource/sampleINT8
linked by target "sample_int8_api" in directory /home/dell/TensorRT/samples/opensource/sampleINT8API
linked by target "sample_mlp" in directory /home/dell/TensorRT/samples/opensource/sampleMLP
linked by target "sample_mnist" in directory /home/dell/TensorRT/samples/opensource/sampleMNIST
linked by target "sample_mnist_api" in directory /home/dell/TensorRT/samples/opensource/sampleMNISTAPI
linked by target "sample_movielens" in directory /home/dell/TensorRT/samples/opensource/sampleMovieLens
linked by target "sample_movielens_mps" in directory /home/dell/TensorRT/samples/opensource/sampleMovieLensMPS
linked by target "sample_nmt" in directory /home/dell/TensorRT/samples/opensource/sampleNMT
linked by target "sample_onnx_mnist" in directory /home/dell/TensorRT/samples/opensource/sampleOnnxMNIST
linked by target "sample_plugin" in directory /home/dell/TensorRT/samples/opensource/samplePlugin
linked by target "sample_reformat_free_io" in directory /home/dell/TensorRT/samples/opensource/sampleReformatFreeIO
linked by target "sample_ssd" in directory /home/dell/TensorRT/samples/opensource/sampleSSD
linked by target "sample_uff_fasterRCNN" in directory /home/dell/TensorRT/samples/opensource/sampleUffFasterRCNN
linked by target "sample_uff_maskRCNN" in directory /home/dell/TensorRT/samples/opensource/sampleUffMaskRCNN
linked by target "sample_uff_mnist" in directory /home/dell/TensorRT/samples/opensource/sampleUffMNIST
linked by target "sample_uff_plugin_v2_ext" in directory /home/dell/TensorRT/samples/opensource/sampleUffPluginV2Ext
linked by target "sample_uff_ssd" in directory /home/dell/TensorRT/samples/opensource/sampleUffSSD
linked by target "sample_onnx_mnist_coord_conv_ac" in directory /home/dell/TensorRT/samples/opensource/sampleOnnxMnistCoordConvAC
linked by target "trtexec" in directory /home/dell/TensorRT/samples/opensource/trtexec
linked by target "nvonnxparser_static" in directory /home/dell/TensorRT/parsers/onnx
linked by target "nvonnxparser" in directory /home/dell/TensorRT/parsers/onnx
-- Configuring incomplete, errors occurred!
See also "/home/dell/TensorRT/build/CMakeFiles/CMakeOutput.log".
See also "/home/dell/TensorRT/build/CMakeFiles/CMakeError.log".
then,I used the prebuild file because it gave an error
sudo cp libnvinfer_plugin.so.7.2.2 /usr/lib/x86_64-linux-gnu/libnvinfer_plugin.so.7.2.3
sudo ldconfig
/sbin/ldconfig.real: /usr/local/cuda-10.1/targets/x86_64-linux/lib/libcudnn_adv_infer.so.8 is not a symbolic link
/sbin/ldconfig.real: /usr/local/cuda-10.1/targets/x86_64-linux/lib/libcudnn_adv_train.so.8 is not a symbolic link
/sbin/ldconfig.real: /usr/local/cuda-10.1/targets/x86_64-linux/lib/libcudnn_cnn_infer.so.8 is not a symbolic link
/sbin/ldconfig.real: /usr/local/cuda-10.1/targets/x86_64-linux/lib/libcudnn_cnn_train.so.8 is not a symbolic link
/sbin/ldconfig.real: /usr/local/cuda-10.1/targets/x86_64-linux/lib/libcudnn_ops_infer.so.8 is not a symbolic link
/sbin/ldconfig.real: /usr/local/cuda-10.1/targets/x86_64-linux/lib/libcudnn_ops_train.so.8 is not a symbolic link
/sbin/ldconfig.real: /usr/local/cuda-10.1/targets/x86_64-linux/lib/libcudnn.so.8 is not a symbolic link
from your log , here is an error “ERRORCannot find TensorRT library.”. did you set up tensorrt successfully? please share the output of “dpkg -l|grep tensorrt”.
please refer to tensorrt link “https://developer.nvidia.com/tensorrt-getting-started”
