I’d like to draw your attention to the following issue:
I have a small test case:
#include <string.h>
#include <stdlib.h>
#define copy_free free
static void (*deallocate)(void *pointer) = copy_free;
I compile it using the include path of the HPC SDK:
gcc -O2 -I/opt/bm/nvidia/hpc_sdk229/Linux_x86_64/22.9/compilers/include -c test.c
Which yields the following error message:
test.c:4:19: error: ‘free’ undeclared here (not in a function)
4 | #define copy_free free
test.c:6:44: note: in expansion of macro ‘copy_free’
6 | static void (*deallocate)(void *pointer) = copy_free;
test.c:2:1: note: ‘free’ is defined in header ‘<stdlib.h>’; did you forget to ‘#include <stdlib.h>’?
1 | #include <string.h>
+++ |+#include <stdlib.h>
2 | #include <stdlib.h>
The HPC SDK has its own stdlib.h
file, which invokes #include_next <stdlib.h>
. If I remove the #include <string.h>
directive, the code compiles. Investigating the pre-processed code (-E option) reveals that in fact no declaration of free
is included when #include <string.h>
is present. Further, I want to point out that it works fine when only the glibc headers are included. This brings me to the conclusion that something might be wrong with the #include_next
directive. Some googling suggests that this feature has been observed to cause trouble in different circumstances.
Unfortunately, I only have an old version of glibc present (2.17) and could not yet check with a newer one.
Another observation is that the issue vanishes when -O0
is used.
