Steam not opening in Hybrid Mode in Pop! OS
I have Nvidia GeForce 720M which I’m using in Pop! OS. When I run Steam in Nvidia Graphics mode, it works fine but when I switch to Hybrid Graphics it don’t work and give the error: OpenGL GLX extension not supported by display,
nvidia-smi gives following output:
| NVIDIA-SMI 390.144 Driver Version: 390.144 |
| 0 GeForce GT 720M Off | 00000000:01:00.0 N/A | N/A |
| N/A 43C P8 N/A / N/A | 2MiB / 1985MiB | N/A Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 Not Supported |
I get same result when I try to run using command line:
__NV_PRIME_RENDER_OFFLOAD=1 __GLX_VENDOR_LIBRARY_NAME=nvidia steam
Sorry, your gpu is too old. Render offload is only available since driver v450 and your Fermi based gpu is only supported up until v390. So you can only use nvidia primary mode.
Okay, thanks for the help.
