Hi kayccc. Thanks for your reply.
First of all, on my Jetson TX2 there is a file (/etc/modprobe.d/blacklist-mttcan.conf) and, inside it:
blacklist mttcan
I commented this to deactivate that command (and be able to load mttcan module). Anyway, why is that for, by default?
My /etc/modules:
can
can_raw
can_dev
mttcan
My dmesg output on boot:
[ 0.000000] Booting Linux on physical CPU 0x100
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.38-tegra (buildbrain@mobile-u64-773) (gcc version 4.8.5 (GCC) ) #1 SMP PREEMPT Thu May 17 00:15:19 PDT 2018
[ 0.000000] Boot CPU: AArch64 Processor [411fd073]
[ 0.000000] earlycon: Early serial console at MMIO32 0x3100000 (options ‘’)
[ 0.000000] bootconsole [uart0] enabled
[ 0.000000] Reserved memory: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fc000000
[ 0.000000] On node 0 totalpages: 2052096
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 519680 pages, LIFO batch:31
[ 0.000000] Normal zone: 23968 pages used for memmap
[ 0.000000] Normal zone: 1532416 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] PERCPU: Embedded 17 pages/cpu @ffffffc1f5f9a000 s31360 r8192 d30080 u69632
[ 0.000000] pcpu-alloc: s31360 r8192 d30080 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 2019936
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 OS=l4t fbcon=map:0 net.ifnames=0 memtype=0 video=tegrafb no_console_suspend=1 earlycon=uart8250,mmio32,0x03100000 nvdumper_reserved=0x2772e0000 gpt tegraid=18.1.2.0.0 tegra_keep_boot_clocks maxcpus=6 boot.slot_suffix= boot.ratchetvalues=0.2.1 androidboot.serialno=0324217138332 bl_prof_dataptr=0x10000@0x277040000 sdhci_tegra.en_boot_part_access=1 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Memory: 7975976K/8208384K available (11296K kernel code, 1841K rwdata, 5796K rodata, 1168K init, 691K bss, 166872K reserved, 65536K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
vmalloc : 0xffffff8000000000 - 0xffffffbdbfff0000 ( 246 GB)
vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000 ( 8 GB maximum)
0xffffffbdc2000000 - 0xffffffbdc9da0000 ( 125 MB actual)
fixed : 0xffffffbffa7fd000 - 0xffffffbffac00000 ( 4108 KB)
PCI I/O : 0xffffffbffae00000 - 0xffffffbffbe00000 ( 16 MB)
modules : 0xffffffbffc000000 - 0xffffffc000000000 ( 64 MB)
memory : 0xffffffc000000000 - 0xffffffc1f6800000 ( 8040 MB)
.init : 0xffffffc001132000 - 0xffffffc001256000 ( 1168 KB)
.text : 0xffffffc000080000 - 0xffffffc001132000 ( 17096 KB)
.data : 0xffffffc001278000 - 0xffffffc001444730 ( 1842 KB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=6.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] Architected cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000002] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.009858] Console: colour dummy device 80x25
[ 0.014519] console [tty0] enabled
[ 0.018077] bootconsole [uart0] disabled
[ 0.022181] kmemleak: Kernel memory leak detector disabled
[ 0.022193] Calibrating delay loop (skipped), value calculated using timer frequency… 62.50 BogoMIPS (lpj=125000)
[ 0.022205] pid_max: default: 32768 minimum: 301
[ 0.022252] Security Framework initialized
[ 0.022289] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.022299] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.022684] Initializing cgroup subsys io
[ 0.022697] Initializing cgroup subsys memory
[ 0.022714] Initializing cgroup subsys devices
[ 0.022724] Initializing cgroup subsys freezer
[ 0.022732] Initializing cgroup subsys net_cls
[ 0.022743] Initializing cgroup subsys perf_event
[ 0.022751] Initializing cgroup subsys net_prio
[ 0.022762] Initializing cgroup subsys pids
[ 0.022770] Initializing cgroup subsys debug
[ 0.022908] CPU0 ipc=752
[ 0.022918] CPU1 ipc=1024
[ 0.022925] CPU2 ipc=1024
[ 0.022934] CPU3 ipc=752
[ 0.022943] CPU4 ipc=752
[ 0.022953] CPU5 ipc=752
[ 0.022990] ASID allocator initialised with 65536 entries
[ 0.046278] tegra-id: chipid=21817.
[ 0.046296] tegra-id: opt_subrevision=1.
[ 0.046310] Tegra Revision: A02p SKU: 0xdc CPU Process: 0 SoC Process: 0
[ 0.047005] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.4/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
[ 0.047030] DTB Build time: May 17 2018 00:17:47
[ 0.062575] CPU1: Booted secondary processor [4e0f0030]
[ 0.074087] CPU2: Booted secondary processor [4e0f0030]
[ 0.085795] CPU3: Booted secondary processor [411fd073]
[ 0.097819] CPU4: Booted secondary processor [411fd073]
[ 0.109807] CPU5: Booted secondary processor [411fd073]
[ 0.109870] Brought up 6 CPUs
[ 0.109927] SMP: Total of 6 processors activated.
[ 0.109939] CPU: All CPU(s) started at EL2
[ 0.110357] devtmpfs: initialized
[ 0.136897] Initilizing CustomIPI irq domain
[ 0.137102] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.137912] pinctrl core: initialized pinctrl subsystem
[ 0.138085] OS set in device tree is not L4T.
[ 0.138279] regulator-dummy: no parameters
[ 0.138389] Initializing plugin-manager
[ 0.138442] Plugin module not found
[ 0.138874] node /plugin-manager/soc-prod-a02-fragment match with chip-id A02P
[ 0.139222] node /plugin-manager/fragement@0 match with odm-data enable-denver-wdt
[ 0.139860] node /plugin-manager/fragement@4 match with odm-data enable-denver-wdt
[ 0.141053] node /plugin-manager/fragment-sdwake-p3310-1000-300 match with board >=3310-1000-300
[ 0.141419] node /plugin-manager/fragement-pmon-p3310-1000-300 match with board >=3310-1000-300
[ 0.141676] node /plugin-manager/fragement-pmon-p3310-1000-800 match with board >=3310-1000-800
[ 0.141896] node /plugin-manager/fragment-devslp@0 match with board >=3310-1000-200
[ 0.142314] node /plugin-manager/fragment-500-pcie-config match with board >=3310-1000-500
[ 0.142748] node /plugin-manager/fragment-500-xusb-config match with board >=3310-1000-500
[ 0.143025] node /plugin-manager/fragment-500-e3325-pcie match with board >=3310-1000-500
[ 0.143401] node /plugin-manager/fragment-p3310-c00-comm match with board >=3310-1000-800
[ 0.143648] node /plugin-manager/fragment-p3310-c00-pmic match with board >=3310-1000-800
[ 0.143868] node /plugin-manager/fragment-p3310-c01 match with board >=3310-1000-900
[ 0.144122] node /plugin-manager/fragment-p3310-c03 match with board >=3310-1000-B00
[ 0.146048] node /plugin-manager/fragment-p3310-c00-camera match with board >=3310-1000-800
[ 0.147831] Adding domain adsp-pd to PM domain ape-pd
[ 0.150150] NET: Registered protocol family 16
[ 0.150969] console [pstore-1] enabled
[ 0.150981] pstore: Registered ramoops as persistent store backend
[ 0.150994] ramoops: attached 0x200000@0x277080000, ecc: 0/0
[ 0.161354] cpuidle: using governor ladder
[ 0.165796] cpuidle: using governor menu
[ 0.166964] bpmp: waiting for handshake
[ 0.166979] bpmp: handshake completed
[ 0.167020] bpmp: synchronizing channels
[ 0.167044] bpmp: channels synchronized
[ 0.167056] bpmp: mail init ok
[ 0.167402] vdso: 2 pages (1 code @ ffffffc00127d000, 1 data @ ffffffc00127c000)
[ 0.167436] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.168381] atomic_pool_init():526: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.169801] tegra_powergate_init: DONE
[ 0.169822] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.4/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t18x/quill/kernel-dts/tegra186-quill-p3310-1000-c03-00-base.dts
[ 0.169849] DTB Build time: May 17 2018 00:17:47
[ 0.170789] Tegra reboot handler registered.
[ 0.171865] Registering Tegra186 clocks (this may take a while)…done
[ 0.174034] arm-smmu 12000000.iommu: probing hardware configuration…
[ 0.174053] arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.174067] arm-smmu 12000000.iommu: stage 1 translation
[ 0.174079] arm-smmu 12000000.iommu: stage 2 translation
[ 0.174092] arm-smmu 12000000.iommu: nested translation
[ 0.174107] arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
[ 0.174126] arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[ 0.174146] arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
[ 0.174160] arm-smmu 12000000.iommu: Stage-1: 39-bit VA → 48-bit IPA
[ 0.174174] arm-smmu 12000000.iommu: Stage-2: 39-bit IPA → 48-bit PA
[ 0.222751] arm-smmu 12000000.iommu: registered 67 master devices
[ 0.228435] iommu: Adding device 3460000.sdhci to group 0
[ 0.229302] iommu: Adding device 3400000.sdhci to group 1
[ 0.232942] iommu: Adding device 3507000.ahci-sata to group 2
[ 0.233395] iommu: Adding device 3160000.i2c to group 3
[ 0.233815] iommu: Adding device c240000.i2c to group 4
[ 0.234147] iommu: Adding device 3180000.i2c to group 5
[ 0.234506] iommu: Adding device 3190000.i2c to group 6
[ 0.235020] iommu: Adding device 31b0000.i2c to group 7
[ 0.235365] iommu: Adding device 31c0000.i2c to group 8
[ 0.235689] iommu: Adding device c250000.i2c to group 9
[ 0.236020] iommu: Adding device 31e0000.i2c to group 10
[ 0.238021] iommu: Adding device 3210000.spi to group 11
[ 0.238363] iommu: Adding device c260000.spi to group 12
[ 0.238732] iommu: Adding device 3240000.spi to group 13
[ 0.239548] iommu: Adding device 3100000.serial to group 14
[ 0.239896] iommu: Adding device 3110000.serial to group 15
[ 0.240226] iommu: Adding device c280000.serial to group 16
[ 0.240544] iommu: Adding device 3130000.serial to group 17
[ 0.241817] iommu: Adding device 2490000.ether_qos to group 18
[ 0.243024] iommu: Adding device b000000.rtcpu to group 19
[ 0.243562] iommu: Adding device c1a0000.aon to group 20
[ 0.244488] Wake73 for irq=42
[ 0.244842] iommu: Adding device smmu_test to group 21
[ 0.245374] mc: mapped MMIO address: 0xffffff8000560000 → 0x2c10000
[ 0.245417] mc: mapped MMIO address: 0xffffff8000640000 → 0x2c20000
[ 0.245454] mc: mapped MMIO address: 0xffffff8000660000 → 0x2c30000
[ 0.245497] mc: mapped MMIO address: 0xffffff8000fa0000 → 0x2c40000
[ 0.245535] mc: mapped MMIO address: 0xffffff8000fc0000 → 0x2c50000
[ 0.245597] mc-err: Set intmask: 0xf3140
[ 0.245865] ecc-err: dram ecc disabled-MC_ECC_CONTROL:0x0000000c
[ 0.246764] Wake76 for irq=199
[ 0.246790] Wake77 for irq=199
[ 0.246836] Wake78 for irq=199
[ 0.246857] Wake79 for irq=199
[ 0.246878] Wake80 for irq=199
[ 0.246898] Wake81 for irq=199
[ 0.246919] Wake82 for irq=199
[ 0.247038] iommu: Adding device 3530000.xhci to group 22
[ 0.247423] iommu: Adding device 3550000.xudc to group 23
[ 0.248285] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.248318] tegra-pmc: ### PMC reset source: Power on reset
[ 0.248342] tegra-pmc: ### PMC reset level: L0
[ 0.248365] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.248626] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.248677] tegra-pmc c360000.pmc: IO padctrl driver initialized
[ 0.248862] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[ 0.248899] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 320
[ 0.249383] iommu: Adding device 13e10000.host1x to group 24
[ 0.249688] iommu: Adding device 13e10000.host1x:ctx0 to group 25
[ 0.249920] iommu: Adding device 13e10000.host1x:ctx1 to group 26
[ 0.250174] iommu: Adding device 13e10000.host1x:ctx2 to group 27
[ 0.250415] iommu: Adding device 13e10000.host1x:ctx3 to group 28
[ 0.250702] iommu: Adding device 13e10000.host1x:ctx4 to group 29
[ 0.250932] iommu: Adding device 13e10000.host1x:ctx5 to group 30
[ 0.251204] iommu: Adding device 13e10000.host1x:ctx6 to group 31
[ 0.251460] iommu: Adding device 13e10000.host1x:ctx7 to group 32
[ 0.251927] iommu: Adding device 150c0000.nvcsi to group 33
[ 0.252503] iommu: Adding device 15700000.vi to group 34
[ 0.252835] iommu: Adding device 15600000.isp to group 35
[ 0.253219] iommu: Adding device 15210000.nvdisplay to group 36
[ 0.253435] iommu: Adding device 15340000.vic to group 37
[ 0.253655] iommu: Adding device 154c0000.nvenc to group 38
[ 0.253892] iommu: Adding device 15480000.nvdec to group 39
[ 0.254274] iommu: Adding device 15380000.nvjpg to group 40
[ 0.254486] iommu: Adding device 15500000.tsec to group 41
[ 0.254731] iommu: Adding device 15100000.tsecb to group 42
[ 0.255477] iommu: Adding device 15810000.se to group 43
[ 0.255684] iommu: Adding device 15820000.se to group 44
[ 0.255911] iommu: Adding device 15830000.se to group 45
[ 0.256104] iommu: Adding device 15840000.se to group 46
[ 0.256635] iommu: Adding device 17000000.gp10b to group 47
[ 0.258057] tegra-reset 5000000.clock: registered 193 resets.
[ 0.260254] iommu: Adding device d000000.bpmp to group 48
[ 0.260481] bpmp: ping status is 0
[ 0.260657] bpmp d000000.bpmp: firmware tag is 83385b61e34297b2f37e76e0cd1ff81e
[ 0.261049] bpmp d000000.bpmp: probe ok
[ 0.263806] iommu: Adding device 2600000.dma to group 49
[ 0.264646] GPIO line 461 (cam0-rst) hogged as output/low
[ 0.264720] GPIO line 456 (cam0-pwdn) hogged as output/low
[ 0.264800] GPIO line 457 (cam1-rst) hogged as output/low
[ 0.264857] GPIO line 426 (cam1-pwdn) hogged as output/low
[ 0.264932] GPIO line 424 (wifi-enable) hogged as output/high
[ 0.264989] GPIO line 445 (sdmmc-wake-input) hogged as input
[ 0.265044] GPIO line 446 (sdmmc-wake-output) hogged as output/low
[ 0.265156] gpiochip_add_data: registered GPIOs 320 to 511 on device: tegra-gpio
[ 0.267090] GPIO line 315 (wifi-wake-ap) hogged as input
[ 0.267287] gpiochip_add_data: registered GPIOs 256 to 319 on device: tegra-gpio-aon
[ 0.268233] iommu: Adding device 10003000.pcie-controller to group 50
[ 0.268508] iommu: Adding device sound to group 51
[ 0.270366] iommu: Adding device 3510000.hda to group 52
[ 0.271847] iommu: Adding device adsp_audio to group 53
[ 0.273511] iommu: Adding device 2993000.adsp to group 54
[ 0.282899] vdd-ac-bat: 5000 mV
[ 0.285114] vdd-1v8-ap: 1800 mV
[ 0.304779] SCSI subsystem initialized
[ 0.305064] libata version 3.00 loaded.
[ 0.305264] usbcore: registered new interface driver usbfs
[ 0.305331] usbcore: registered new interface driver hub
[ 0.305445] usbcore: registered new device driver usb
[ 0.308194] tegra-i2c 3160000.i2c: no acknowledge from address 0x74
[ 0.308397] pca953x 0-0074: failed reading register
[ 0.308466] pca953x: probe of 0-0074 failed with error -121
[ 0.308839] tegra-i2c 3160000.i2c: no acknowledge from address 0x77
[ 0.309032] pca953x 0-0077: failed reading register
[ 0.309087] pca953x: probe of 0-0077 failed with error -121
[ 0.319789] media: Linux media interface: v0.10
[ 0.319853] Linux video capture interface: v2.00
[ 0.323751] pps_core: LinuxPPS API ver. 1 registered
[ 0.323776] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.323823] PTP clock support registered
[ 0.324720] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.324768] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[ 0.326211] max77620 4-003c: PMIC Version OTP:0x45 and ES:0x8
[ 0.328244] GPIO line 253 (spmic_gpio_input_5) hogged as input
[ 0.328427] GPIO line 254 (spmic_gpio_input_6) hogged as input
[ 0.328515] gpiochip_add_data: registered GPIOs 248 to 255 on device: max77620-gpio
[ 0.334274] vddio-ddr: at 1125 mV
[ 0.338096] avdd_dsi_csi: 1200 mV
[ 0.342096] vdd-1v8: 1800 mV
[ 0.346102] vdd-3v3-sys: 3300 mV
[ 0.347180] spmic-ldo0: at 1800 mV
[ 0.347929] spmic-ldo1: at 800 mV
[ 0.350099] vddio-3v3: 3300 mV
[ 0.350722] vddio-sdmmc1: 1800 <–> 3300 mV at 3300 mV
[ 0.354098] vdd-rtc: at 800 mV
[ 0.354913] avdd-ts-hv: 1800 <–> 3300 mV at 1800 mV
[ 0.358100] spmic-ldo6: at 1500 mV
[ 0.361352] vdd-pex-1v05: 1000 mV
[ 0.361924] dvdd-pex: 1000 mV
[ 0.362204] max77620 4-003c: max77620 probe successful
[ 0.362448] Advanced Linux Sound Architecture Driver Initialized.
[ 0.363409] en-vdd-sd: 3300 mV
[ 0.363680] vdd-usb0-5v: 5000 mV
[ 0.363853] vdd-usb1-5v: 5000 mV
[ 0.364209] vdd-3v3: 3300 mV
[ 0.364351] en-vdd-vcm-2v8: 2800 mV
[ 0.364487] vdd-sys-bl: 3300 mV
[ 0.367846] extcon-gpio-states external-connection:extcon@1: Cable state 2
[ 0.368248] clocksource: Switched to clocksource arch_sys_counter
[ 0.386749] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.387043] nvmap: nvmap_override_cache_ops() set roc flush ops to replace cache ops by set/ways
[ 0.387528] nvmap_page_pool_init: Total RAM pages: 2010378
[ 0.387546] nvmap_page_pool_init: nvmap page pool size: 251297 pages (981 MB)
[ 0.387747] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.392352] Wake76 for irq=199
[ 0.392366] Wake77 for irq=199
[ 0.392378] Wake78 for irq=199
[ 0.392388] Wake79 for irq=199
[ 0.392399] Wake80 for irq=199
[ 0.392409] Wake81 for irq=199
[ 0.392419] Wake82 for irq=199
[ 0.393161] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type BCPU-therm
[ 0.393362] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type MCPU-therm
[ 0.393747] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.393828] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.393970] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type Tboard_tegra
[ 0.394112] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tdiode_tegra
[ 0.394260] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type PMIC-Die
[ 0.394554] isomgr_init(): iso emc max clk=1866000KHz
[ 0.394567] isomgr_init(): max_iso_bw=26870400KB
[ 0.394654] NET: Registered protocol family 2
[ 0.395005] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.395235] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.395532] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.395589] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.395644] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.395815] NET: Registered protocol family 1
[ 0.396022] RPC: Registered named UNIX socket transport module.
[ 0.396037] RPC: Registered udp transport module.
[ 0.396049] RPC: Registered tcp transport module.
[ 0.396061] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.396082] PCI: CLS 0 bytes, default 128
[ 0.396182] Trying to unpack rootfs image as initramfs…
[ 0.410006] host1x 13e10000.host1x: initialized
[ 0.410855] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.413127] futex hash table entries: 2048 (order: 6, 262144 bytes)
[ 0.413224] audit: initializing netlink subsys (disabled)
[ 0.413254] audit: type=2000 audit(0.400:1): initialized
[ 0.423768] io scheduler noop registered
[ 0.423929] io scheduler cfq registered (default)
[ 0.427418] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 0.428836] tegra-pwm 3290000.pwm: PWM clk can sleep in ops
[ 0.430132] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 0.431389] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[ 0.436125] tsec 15500000.tsec: initialized
[ 0.437515] tsec 15100000.tsecb: initialized
[ 0.440693] nvdec 15480000.nvdec: initialized
[ 0.445553] falcon 15340000.vic: initialized
[ 0.446843] falcon 154c0000.nvenc: initialized
[ 0.448079] falcon 15380000.nvjpg: initialized
[ 0.449283] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[ 0.450040] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[ 0.450800] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[ 0.451532] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[ 0.452309] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[ 0.453020] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[ 0.453749] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[ 0.454494] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[ 0.458137] DC OR NODE connected to /host1x/sor1
[ 0.458318] generic_infoframe_type: 0x87
[ 0.458488] tegradc 15210000.nvdisplay: DT parsed successfully
[ 0.458530] tegradc 15210000.nvdisplay: Display dc.ffffff8002320000 registered with id=0
[ 0.458538] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 0.458739] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[ 0.458780] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=4687500, vi_iso_bw=1500000, max_bw=4687500
[ 0.467016] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 16727000 KB/s
[ 0.467037] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 665600000 Hz
[ 0.467054] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 357620000 Hz
[ 0.467099] tegradc 15210000.nvdisplay: vblank syncpt # 7 for dc 1
[ 0.467114] tegradc 15210000.nvdisplay: vpulse3 syncpt # 8 for dc 1
[ 0.467514] hdmi: couldn’t get regulator vdd_hdmi_5v0: -517
[ 0.468366] tegra-adma 2930000.adma: Tegra ADMA driver register 10 channels
[ 0.469621] tegradc 15210000.nvdisplay: hdmi: no prod_list_hdmi_board, use default range
[ 0.470478] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[ 0.470888] kfuse 3830000.kfuse: initialized
[ 0.472613] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 0.473272] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 0.476022] console [ttyS0] disabled
[ 0.476103] 3100000.serial: ttyS0 at MMIO 0x3100000 (irq = 37, base_baud = 25500000) is a Tegra
[ 2.472238] tegra-i2c 3190000.i2c: pio timed out addr: 0x50 tlen:28 rlen:128
[ 2.472241] tegra-i2c 3190000.i2c: — register dump for debugging ----
[ 2.472244] tegra-i2c 3190000.i2c: I2C_CNFG - 0x22c00
[ 2.472247] tegra-i2c 3190000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 2.472251] tegra-i2c 3190000.i2c: I2C_FIFO_CONTROL - 0xe0
[ 2.472254] tegra-i2c 3190000.i2c: I2C_FIFO_STATUS - 0x800040
[ 2.472257] tegra-i2c 3190000.i2c: I2C_INT_MASK - 0x7d
[ 2.472260] tegra-i2c 3190000.i2c: I2C_INT_STATUS - 0x0
[ 2.472265] tegra-i2c 3190000.i2c: i2c transfer timed out addr: 0x50
[ 2.474237] tegradc 15210000.nvdisplay: probed
[ 2.571858] console [ttyS0] enabled
[ 2.573708] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 38, base_baud = 0) is a TEGRA_UART
[ 2.574052] Console: switching to colour frame buffer device 80x30
[ 2.574725] c280000.serial: ttyTHS2 at MMIO 0xc280000 (irq = 39, base_baud = 0) is a TEGRA_UART
[ 2.574932] serial-tegra 3130000.serial: RX in PIO mode
[ 2.575822] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 40, base_baud = 0) is a TEGRA_UART
[ 2.601180] brd: module loaded
[ 2.603990] gk20a 17000000.gp10b: failed to allocate secure buffer -12
[ 2.609288] loop: module loaded
[ 2.609517] nct1008_nct72 7-004c: find device tree node, parsing dt
[ 2.609521] nct1008_nct72 7-004c: starting parse dt
[ 2.609605] nct1008_nct72 7-004c: success parsing dt
[ 2.609750] nct1008_nct72 7-004c: success in enabling tmp451 VDD rail
[ 2.646569] tmp451: Enabled overheat logging at 104.00C
[ 2.646723] nct1008_nct72 7-004c: nct1008_probe: initialized
[ 2.648925] THERMAL EST: found 3 subdevs
[ 2.648931] THERMAL EST num_resources: 0
[ 2.648935] [THERMAL EST subdev 0]
[ 2.648939] [THERMAL EST subdev 1]
[ 2.648942] [THERMAL EST subdev 2]
[ 2.649183] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type thermal-fan-est
[ 2.649185] THERMAL EST: thz register success.
[ 2.649358] THERMAL EST: end of probe, return err: 0
[ 2.649404] tegra_profiler: Branch: Dev
[ 2.649406] tegra_profiler: Version: 1.117
[ 2.649408] tegra_profiler: Samples version: 41
[ 2.649410] tegra_profiler: IO version: 22
[ 2.649416] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.649420] armv8_pmu: [0] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0, pmu ver: 0x1
[ 2.649423] armv8_pmu: imp: 0x4e, idcode: 0x1
[ 2.649427] armv8_pmu: [1] arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 2, pmu ver: 0x1
[ 2.649430] armv8_pmu: imp: 0x4e, idcode: 0x1
[ 2.649432] armv8_pmu: [2] arch: AA64 PmuV3 NVIDIA (Denver), type: 6, ver: 2, pmu ver: 0x1
[ 2.649435] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.649438] armv8_pmu: [3] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0, pmu ver: 0x1
[ 2.649441] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.649444] armv8_pmu: [4] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0, pmu ver: 0x1
[ 2.649446] armv8_pmu: imp: 0x41, idcode: 0x1
[ 2.649449] armv8_pmu: [5] arch: AA64 PmuV3 ARM CORTEX-A57, type: 5, ver: 0, pmu ver: 0x1
[ 2.649609] tegra_profiler: auth: init
[ 2.652837] tegra-ahci 3507000.ahci-sata: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl platform mode
[ 2.652849] tegra-ahci 3507000.ahci-sata: flags: 64bit ncq sntf pm led pmp pio slum part deso sadm apst
[ 2.653746] scsi host0: tegra_ahci
[ 2.654103] scsi host1: tegra_ahci
[ 2.654217] ata1: SATA max UDMA/133 mmio [mem 0x03507000-0x03508fff] port 0x100 irq 25
[ 2.654220] ata2: DUMMY
[ 2.655231] spi-tegra114 3210000.spi: Static pin configuration used
[ 2.655660] spi-tegra114 c260000.spi: Static pin configuration used
[ 2.656046] spi-tegra114 3240000.spi: Static pin configuration used
[ 2.656829] tun: Universal TUN/TAP device driver, 1.6
[ 2.656831] tun: (C) 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 2.657049] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 2.657051] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 2.657083] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.3.0-k
[ 2.657085] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 2.658078] PPP generic driver version 2.4.2
[ 2.658210] PPP BSD Compression module registered
[ 2.658247] PPP Deflate Compression module registered
[ 2.658266] PPP MPPE Compression module registered
[ 2.658279] NET: Registered protocol family 24
[ 2.658332] usbcore: registered new interface driver r8152
[ 2.658362] usbcore: registered new interface driver asix
[ 2.658388] usbcore: registered new interface driver ax88179_178a
[ 2.658411] usbcore: registered new interface driver cdc_ether
[ 2.658445] usbcore: registered new interface driver smsc75xx
[ 2.658471] usbcore: registered new interface driver net1080
[ 2.658495] usbcore: registered new interface driver cdc_subset
[ 2.658519] usbcore: registered new interface driver zaurus
[ 2.658562] usbcore: registered new interface driver cdc_ncm
[ 2.658857] Wake76 for irq=199
[ 2.658860] Wake77 for irq=199
[ 2.658861] Wake78 for irq=199
[ 2.658863] Wake79 for irq=199
[ 2.658865] Wake80 for irq=199
[ 2.658868] Wake81 for irq=199
[ 2.658870] Wake82 for irq=199
[ 2.658959] tegra-xotg xotg: usb2 phy is not available yet
[ 2.659669] usbcore: registered new interface driver cdc_acm
[ 2.659672] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 2.659708] usbcore: registered new interface driver usb-storage
[ 2.659773] usbcore: registered new interface driver usbserial
[ 2.659797] usbcore: registered new interface driver cp210x
[ 2.659813] usbserial: USB Serial support registered for cp210x
[ 2.659840] usbcore: registered new interface driver ftdi_sio
[ 2.659855] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 2.659875] usbcore: registered new interface driver option
[ 2.659889] usbserial: USB Serial support registered for GSM modem (1-port)
[ 2.659909] usbcore: registered new interface driver pl2303
[ 2.659926] usbserial: USB Serial support registered for pl2303
[ 2.660102] tegra-usb-cd usb_cd: otg phy is not available yet
[ 2.678864] eqos 2490000.ether_qos: Setting local MAC: 0 4 4b 8d 44 52
[ 2.679314] libphy: dwc_phy: probed
[ 2.679767] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ 2.741391] bcm54xx_low_power_mode(): put phy in iddq-lp mode
[ 2.811678] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 2.813930] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 2.813943] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 2.814082] i2c /dev entries driver
[ 2.814862] gspca_main: v2.14.0 registered
[ 2.814902] usbcore: registered new interface driver gspca_zc3xx
[ 2.815139] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 2.816999] FAN: coudln’t get the regulator
[ 2.817722] device-mapper: uevent: version 1.0.3
[ 2.817891] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[ 2.818234] sdhci: Secure Digital Host Controller Interface driver
[ 2.818235] sdhci: Copyright(c) Pierre Ossman
[ 2.818239] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.818496] sdhci-tegra 3460000.sdhci: Parent select= pll_p rate=408000000
[ 2.818772] sdhci-tegra 3460000.sdhci: Parent select= pll_c4_out0 rate=196249804
[ 2.818997] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[ 2.822211] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 2.822382] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.824123] usbcore: registered new interface driver usbhid
[ 2.824125] usbhid: USB HID core driver
[ 2.827109] tegra-i2c 3160000.i2c: no acknowledge from address 0x42
[ 2.827326] ina3221x 0-0042: ina3221 reset failure status: 0xffffff87
[ 2.827455] ina3221x: probe of 0-0042 failed with error -121
[ 2.827828] tegra-i2c 3160000.i2c: no acknowledge from address 0x43
[ 2.828031] ina3221x 0-0043: ina3221 reset failure status: 0xffffff87
[ 2.828124] ina3221x: probe of 0-0043 failed with error -121
[ 2.828634] nvadsp 2993000.adsp: in probe()…
[ 2.829951] nvadsp 2993000.adsp: Registering AMC Error Interrupt
[ 2.829986] nvadsp 2993000.adsp: AMC/ARAM initialized.
[ 2.830223] nvadsp 2993000.adsp: nvadsp_app_module_probe
[ 2.839095] Denver: backdoor interface is NOT available.
[ 2.841124] coresight-tmc 8030000.etf: TMC initialized
[ 2.845455] coresight-tmc 8050000.etr: TMC initialized
[ 2.845915] coresight-tpiu 8060000.tpiu: TPIU initialized
[ 2.846490] coresight-funnel 9010000.funnel_bccplex: FUNNEL initialized
[ 2.846999] coresight-funnel 8010000.funnel_major: FUNNEL initialized
[ 2.847477] coresight-funnel 8820000.funnel_minor: FUNNEL initialized
[ 2.847947] coresight-replicator 8040000.replicator: REPLICATOR initialized
[ 2.848671] coresight-etm4x 9840000.ptm: ETM 4.0 initialized
[ 2.849293] coresight-etm4x 9940000.ptm: ETM 4.0 initialized
[ 2.849904] coresight-etm4x 9a40000.ptm: ETM 4.0 initialized
[ 2.850525] coresight-etm4x 9b40000.ptm: ETM 4.0 initialized
[ 2.850559] Module initialized successfully
[ 2.854647] tegra186-cam-rtcpu b000000.rtcpu: Trace buffer configured at IOVA=0xa0000000
[ 2.856242] tegra186-cam-rtcpu b000000.rtcpu: already unhalted
[ 2.856482] tegra-ivc ivc-b000000.rtcpu: region 0: iova=0xa0110000-0xa011957f size=38272
[ 2.856866] tegra-ivc ivc-b000000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 2.856912] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: vinotify: ver=0 grp=1 RX[64x128]=0x1900-0x3980 TX[64x128]=0x3980-0x5a00
[ 2.856955] tegra-ivc ivc-b000000.rtcpu:mods@32c0: mods: ver=0 grp=1 RX[1x64]=0x5a00-0x5ac0 TX[1x64]=0x5ac0-0x5b80
[ 2.857000] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivccontrol: ver=0 grp=1 RX[16x320]=0x5b80-0x7000 TX[16x320]=0x7000-0x8480
[ 2.857039] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivccapture: ver=0 grp=1 RX[16x64]=0x8480-0x8900 TX[16x64]=0x8900-0x8d80
[ 2.857078] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: dbg: ver=0 grp=1 RX[1x384]=0x8d80-0x8f80 TX[1x384]=0x8f80-0x9180
[ 2.857129] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: dbg: ver=0 grp=1 RX[1x384]=0x9180-0x9380 TX[1x384]=0x9380-0x9580
[ 2.857278] tegra186-cam-rtcpu b000000.rtcpu: using cam RTCPU IRQ (52)
[ 2.857280] tegra186-cam-rtcpu b000000.rtcpu: tegra_camrtc_mon_create is successful
[ 2.857908] tegra-ivc ivc-b000000.rtcpu:echo@0: ivc channel driver missing
[ 2.857911] tegra-ivc ivc-b000000.rtcpu:vinotify@12c0: ivc channel driver missing
[ 2.857913] tegra-ivc ivc-b000000.rtcpu:mods@32c0: ivc channel driver missing
[ 2.857916] tegra-ivc ivc-b000000.rtcpu:ivccontrol@52c0: ivc channel driver missing
[ 2.857918] tegra-ivc ivc-b000000.rtcpu:ivccapture@72c0: ivc channel driver missing
[ 2.857921] tegra-ivc ivc-b000000.rtcpu:dbg@7c00: ivc channel driver missing
[ 2.857923] tegra-ivc ivc-b000000.rtcpu:dbg@7e00: ivc channel driver missing
[ 2.857952] tegra186-cam-rtcpu b000000.rtcpu: firmware version cpu=sce cmd=4 sha1=a8b1ecdd9615cd817a56df035be363fce3b0b88f
[ 2.862513] tegra-ivc-cdev ivc-b000000.rtcpu:echo@0: probing /dev/camchar-echo
[ 2.863374] tegra-ivc-cdev ivc-b000000.rtcpu:dbg@7c00: probing /dev/camchar-dbg
[ 2.863475] camchar: rtcpu character device driver loaded
[ 2.868252] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[ 2.868543] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 2.868582] sdhci-tegra 3440000.sdhci: Parent select= pll_p rate=408000000
[ 2.868906] sdhci-tegra 3440000.sdhci: Client registration for eMC Successful
[ 2.868989] register_ari_mca_banks: Registered MCA ROC:IOB
[ 2.869218] register_ari_mca_banks: Registered MCA ROC:CCE
[ 2.869879] tegra18-bridge 2390000.axi2apb: bridge probed OK
[ 2.869912] tegra18-bridge 23a0000.axi2apb: bridge probed OK
[ 2.869940] tegra18-bridge 23b0000.axi2apb: bridge probed OK
[ 2.869971] tegra18-bridge 23c0000.axi2apb: bridge probed OK
[ 2.869998] tegra18-bridge 23d0000.axi2apb: bridge probed OK
[ 2.870025] tegra18-bridge 2100000.axip2p: bridge probed OK
[ 2.870051] tegra18-bridge 2110000.axip2p: bridge probed OK
[ 2.870080] tegra18-bridge 2120000.axip2p: bridge probed OK
[ 2.870106] tegra18-bridge 2130000.axip2p: bridge probed OK
[ 2.870130] tegra18-bridge 2140000.axip2p: bridge probed OK
[ 2.870158] tegra18-bridge 2150000.axip2p: bridge probed OK
[ 2.870185] tegra18-bridge 2160000.axip2p: bridge probed OK
[ 2.870212] tegra18-bridge 2170000.axip2p: bridge probed OK
[ 2.870240] tegra18-bridge 2180000.axip2p: bridge probed OK
[ 2.870271] tegra18-bridge 2190000.axip2p: bridge probed OK
[ 2.870330] **** A57 ECC: Enabled
[ 2.870333] tegra18_a57_serr_init: on CPU 5 a A57 Core
[ 2.870496] parse_throttle_dt_data: Num cap clks = 4
[ 2.870499] parse_throttle_dt_data: clk=mcpu type=1
[ 2.870501] parse_throttle_dt_data: clk=bcpu type=2
[ 2.870510] parse_throttle_dt_data: clk=gpu type=4
[ 2.870512] parse_throttle_dt_data: clk=emc type=3
[ 2.872911] tegra_throttle_probe: probe successful. #cdevs=4
[ 2.873003] tegra18x_actmon d230000.actmon: in actmon_register()…
[ 2.876178] tegra18x_actmon d230000.actmon: initialization Completed for the device mc_all
[ 2.876529] hw perfevents: enabled with denver15_uncore_pmu PMU driver, 3 counters available
[ 2.916237] mmc1: SDHCI controller on 3440000.sdhci [3440000.sdhci] using ADMA 64-bit with 64 bit addr
[ 2.916539] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 2.916591] sdhci-tegra 3400000.sdhci: Got WP GPIO
[ 2.916675] sdhci-tegra 3400000.sdhci: Parent select= pll_p rate=408000000
[ 2.916702] sdhci-tegra 3400000.sdhci: wakeup init done, cd_irq: 256
[ 2.916936] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[ 2.946241] mmc0: MAN_BKOPS_EN bit is not set
[ 2.953511] mmc0: Skipping tuning since strobe enabled
[ 2.960304] mmc2: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[ 2.961112] mmc0: periodic cache flush enabled
[ 2.961119] mmc0: new HS400 MMC card at address 0001
[ 2.961437] mmcblk0: mmc0:0001 032G34 29.1 GiB
[ 2.961607] mmcblk0boot0: mmc0:0001 032G34 partition 1 4.00 MiB
[ 2.961767] mmcblk0boot1: mmc0:0001 032G34 partition 2 4.00 MiB
[ 2.961920] mmcblk0rpmb: mmc0:0001 032G34 partition 3 4.00 MiB
[ 2.963266] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22 p23 p24 p25 p26 p27 p28 p29
[ 2.972265] ata1: SATA link down (SStatus 0 SControl 300)
[ 3.008729] mmc1: queuing unknown CIS tuple 0x80 (5 bytes)
[ 3.206493] mmc1 tuning done saved tap delay=20
[ 3.206496] mmc1: hw tuning done …
[ 3.206502] mmc1: tuning_window[0]: 0xffffffff
[ 3.206508] mmc1: tuning_window[1]: 0xfffff1ff
[ 3.206513] mmc1: tuning_window[2]: 0xff1fffff
[ 3.206518] mmc1: tuning_window[3]: 0x7fffffff
[ 3.206522] mmc1: tuning_window[4]: 0x0
[ 3.206527] mmc1: tuning_window[5]: 0x0
[ 3.206560] mmc1: tuning_window[6]: 0x0
[ 3.206565] mmc1: tuning_window[7]: 0x0
[ 3.206569] sdhci: Tap value: 20 | Trim value: 5
[ 3.206573] sdhci: SDMMC_VENDOR_INTR_STATUS[0x108]: 0x40000
[ 3.212877] mmc1: queuing unknown CIS tuple 0x91 (3 bytes)
[ 3.212926] mmc1: new ultra high speed SDR104 SDIO card at address 0001
[ 4.081082] tegradc 15210000.nvdisplay: fb registered
[ 4.086925] PD DISP0 index2 UP
[ 4.091602] PD DISP1 index3 UP
[ 4.095256] PD DISP2 index4 UP
[ 4.100603] Parent Clock set for DC plld2
[ 4.108102] edid invalid
[ 4.112102] edid invalid
[ 4.115057] edid invalid
[ 4.118012] tegradc 15210000.nvdisplay: hdmi: pclk:25200K, set prod-setting:prod_c_54M
[ 4.144248] tegra-se-nvhost 15810000.se: initialized
[ 4.150286] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 4.157409] tegra-se-nvhost 15820000.se: initialized
[ 4.163338] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 4.170409] tegra-se-nvhost 15830000.se: initialized
[ 4.176146] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 4.183360] tegra-se-nvhost 15840000.se: initialized
[ 4.189291] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 4.199447] tegra-gpcdma 2600000.dma: GPC DMA driver register 32 channels
[ 4.210398] cpufreq: platform driver Initialization: pass
[ 4.216582] tegra_cluster_clk e090000.cluster_clk_priv: in probe()…
[ 4.223670] tegra_cluster_clk e090000.cluster_clk_priv: passed
[ 4.230276] tegra186-padctl 3520000.pinctrl: padctl mmio start 0x0000000003520000 end 0x0000000003520fff
[ 4.240903] tegra186-padctl 3520000.pinctrl: ao mmio start 0x0000000003540000 end 0x0000000003540fff
[ 4.251291] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x28a894
[ 4.258671] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x9
[ 4.267033] tegra186-padctl 3520000.pinctrl: using UTMI port 0 for otg
[ 4.275855] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 0 not supported
[ 4.283913] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 3 not supported
[ 4.293220] cpuidle: Initializing cpuidle driver init for Denver cluster
[ 4.300544] cpuidle: Initializing cpuidle driver init for A57 cluster
[ 4.308636] tachometer tegra-tachometer: Tachometer driver tegra-tachometer registered
[ 4.317353] Tachometer driver initialized with pulse_per_rev: 2 and win_len: 2
[ 4.328888] tegra210_adsp_audio_platform_probe: platform probe started
[ 4.337068] tegra210-adsp adsp_audio: Default param-type to BYTE for mp3-dec1
[ 4.348465] tegra210-adsp adsp_audio: Default param-type to BYTE for spkprot
[ 4.349240] input: tegra-hda HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[ 4.349422] input: tegra-hda HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[ 4.375509] tegra210-adsp adsp_audio: Default param-type to BYTE for src
[ 4.383318] tegra210-adsp adsp_audio: Default param-type to BYTE for aac-dec1
[ 4.391594] tegra210-adsp adsp_audio: Default param-type to BYTE for aec
[ 4.399117] tegra210-adsp adsp_audio: adma channel page address dt entry not found
[ 4.408246] tegra210-adsp adsp_audio: using adma channel page 0
[ 4.415031] tegra210_adsp_audio_platform_probe probe successfull.
[ 4.433567] OPE platform probe
[ 4.437889] OPE platform probe successful
[ 4.533991] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 4.542592] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 4.551157] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 4.559754] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 4.568346] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 4.576981] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 4.585654] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 4.594340] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 4.603006] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 4.611732] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 4.620687] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF11 <-> ADMAIF11 mapping ok
[ 4.629667] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF12 <-> ADMAIF12 mapping ok
[ 4.641941] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF13 <-> ADMAIF13 mapping ok
[ 4.650975] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF14 <-> ADMAIF14 mapping ok
[ 4.660006] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF15 <-> ADMAIF15 mapping ok
[ 4.669068] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF16 <-> ADMAIF16 mapping ok
[ 4.678116] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF17 <-> ADMAIF17 mapping ok
[ 4.687141] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF18 <-> ADMAIF18 mapping ok
[ 4.696164] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF19 <-> ADMAIF19 mapping ok
[ 4.705195] tegra-snd-t186ref-mobile-rt565x sound: ADMAIF20 <-> ADMAIF20 mapping ok
[ 4.717360] tegra-snd-t186ref-mobile-rt565x sound: ADSP-FE1 <-> ADSP PCM1 mapping ok
[ 4.726510] tegra-snd-t186ref-mobile-rt565x sound: ADSP-FE2 <-> ADSP PCM2 mapping ok
[ 4.735533] compress asoc: ADSP-FE3 <-> ADSP COMPR1 mapping ok
[ 4.742034] compress asoc: ADSP-FE4 <-> ADSP COMPR2 mapping ok
[ 4.786576] input: tegra-snd-t186ref-mobile-rt565x Headphone Jack as /devices/sound/sound/card1/input2
[ 4.797830] tegra-snd-t186ref-mobile-rt565x sound: codec-dai “dit-hifi” registered
[ 4.806664] tegra-snd-t186ref-mobile-rt565x sound: This is a dummy codec
[ 4.814536] GACT probability NOT on
[ 4.818643] Mirror/redirect action on
[ 4.822949] u32 classifier
[ 4.826237] Actions configured
[ 4.830230] nf_conntrack version 0.5.0 (65536 buckets, 262144 max)
[ 4.837646] IPVS: Registered protocols ()
[ 4.842264] IPVS: Connection hash table configured (size=4096, memory=64Kbytes)
[ 4.850744] IPVS: Creating netns size=1424 id=0
[ 4.855861] IPVS: ipvs loaded.
[ 4.859436] IPVS: [rr] scheduler registered.
[ 4.864324] ipip: IPv4 over IPv4 tunneling driver
[ 4.869858] Initializing XFRM netlink socket
[ 4.874891] NET: Registered protocol family 10
[ 4.880484] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 4.886477] NET: Registered protocol family 17
[ 4.891401] NET: Registered protocol family 15
[ 4.896327] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 4.909829] 8021q: 802.1Q VLAN Support v1.8
[ 4.914990] Registered cp15_barrier emulation handler
[ 4.920498] Registered setend emulation handler
[ 4.927336] registered taskstats version 1
[ 4.935708] isp 15600000.isp: initialized
[ 4.944051] nvcsi 150c0000.nvcsi: initialized
[ 4.950911] Wake76 for irq=199
[ 4.954657] Wake77 for irq=199
[ 4.958372] Wake78 for irq=199
[ 4.962073] Wake79 for irq=199
[ 4.965744] Wake80 for irq=199
[ 4.969384] Wake81 for irq=199
[ 4.972989] Wake82 for irq=199
[ 4.976768] xhci-tegra 3530000.xhci: can’t get usb3-0 phy (-517)
[ 4.983679] spi-tegra114 3210000.spi: Static pin configuration used
[ 4.991191] spi-tegra114 c260000.spi: Static pin configuration used
[ 4.998742] spi-tegra114 3240000.spi: Static pin configuration used
[ 5.006088] Wake76 for irq=199
[ 5.009625] Wake77 for irq=199
[ 5.013156] Wake78 for irq=199
[ 5.016647] Wake79 for irq=199
[ 5.020116] Wake80 for irq=199
[ 5.023584] Wake81 for irq=199
[ 5.027019] Wake82 for irq=199
[ 5.030453] tegra-xotg xotg: usb2 phy is not available yet
[ 5.036813] tegra-usb-cd usb_cd: otg phy is not available yet
[ 5.043462] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ 5.050492] tegra186-padctl 3520000.pinctrl: padctl mmio start 0x0000000003520000 end 0x0000000003520fff
[ 5.060499] tegra186-padctl 3520000.pinctrl: ao mmio start 0x0000000003540000 end 0x0000000003540fff
[ 5.070249] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x28a894
[ 5.077435] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x9
[ 5.085318] tegra186-padctl 3520000.pinctrl: using UTMI port 0 for otg
[ 5.095129] Wake76 for irq=199
[ 5.098513] Wake77 for irq=199
[ 5.101889] Wake78 for irq=199
[ 5.105264] Wake79 for irq=199
[ 5.108625] Wake80 for irq=199
[ 5.111965] Wake81 for irq=199
[ 5.115305] Wake82 for irq=199
[ 5.118885] xhci-tegra 3530000.xhci: can’t get usb3-0 phy (-517)
[ 5.126203] input: gpio-keys as /devices/gpio-keys/input/input3
[ 5.132848] Wake76 for irq=199
[ 5.136217] Wake77 for irq=199
[ 5.139587] Wake78 for irq=199
[ 5.142955] Wake79 for irq=199
[ 5.146326] Wake80 for irq=199
[ 5.149697] Wake81 for irq=199
[ 5.153050] Wake82 for irq=199
[ 5.156498] tegra-xotg xotg: usb2 phy is not available yet
[ 5.162480] tegra-usb-cd usb_cd: otg phy is not available yet
[ 5.168534] tegra_rtc c2a0000.rtc: setting system clock to 2019-05-29 18:09:34 UTC (1559153374)
[ 5.178324] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ 5.185388] tegra186-padctl 3520000.pinctrl: padctl mmio start 0x0000000003520000 end 0x0000000003520fff
[ 5.195456] tegra186-padctl 3520000.pinctrl: ao mmio start 0x0000000003540000 end 0x0000000003540fff
[ 5.198309] bpmp: mounted debugfs mirror
[ 5.198807] [dram-timers] DRAM derating cdev registered.
[ 5.202961] spmic-ldo0: disabling
[ 5.203161] spmic-ldo1: disabling
[ 5.203348] en-vdd-sd: disabling
[ 5.203349] vdd-usb0-5v: disabling
[ 5.203351] vdd-usb1-5v: disabling
[ 5.203352] vdd-3v3: disabling
[ 5.203354] en-vdd-vcm-2v8: disabling
[ 5.203355] vdd-sys-bl: disabling
[ 5.209533] ALSA device list:
[ 5.209535] #0: tegra-hda at 0x3518000 irq 400
[ 5.209536] #1: tegra-snd-t186ref-mobile-rt565x
[ 5.210681] tegra-vi4 15700000.vi: initialized
[ 5.211753] tegra-vi4 15700000.vi: ep of_device is not enabled /host1x/vi@15700000/ports/port@0/endpoint.
[ 5.211755] tegra-vi4 15700000.vi: all channel register failed
[ 5.279372] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x28a894
[ 5.286656] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x9
[ 5.294487] tegra186-padctl 3520000.pinctrl: using UTMI port 0 for otg
[ 5.304255] Wake76 for irq=199
[ 5.306856] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 5.306869] VFS: Mounted root (ext4 filesystem) on device 179:1.
[ 5.307845] devtmpfs: mounted
[ 5.308152] Freeing unused kernel memory: 1168K (ffffffc001132000 - ffffffc001256000)
[ 5.308173] Freeing alternatives memory: 96K (ffffffc001256000 - ffffffc00126e000)
[ 5.316241] btb inv war enabled
[ 5.346776] Wake77 for irq=199
[ 5.350325] Wake78 for irq=199
[ 5.350326] Wake79 for irq=199
[ 5.350328] Wake80 for irq=199
[ 5.350338] Wake81 for irq=199
[ 5.350340] Wake82 for irq=199
[ 5.350582] xhci-tegra 3530000.xhci: can’t get usb3-0 phy (-517)
[ 5.350948] Wake76 for irq=199
[ 5.350950] Wake77 for irq=199
[ 5.350951] Wake78 for irq=199
[ 5.350952] Wake79 for irq=199
[ 5.350953] Wake80 for irq=199
[ 5.350954] Wake81 for irq=199
[ 5.350955] Wake82 for irq=199
[ 5.350984] tegra-xotg xotg: usb2 phy is not available yet
[ 5.351131] tegra-usb-cd usb_cd: otg phy is not available yet
[ 5.351545] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ 5.351701] tegra186-padctl 3520000.pinctrl: padctl mmio start 0x0000000003520000 end 0x0000000003520fff
[ 5.351706] tegra186-padctl 3520000.pinctrl: ao mmio start 0x0000000003540000 end 0x0000000003540fff
[ 5.351736] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x28a894
[ 5.351740] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x9
[ 5.352615] tegra186-padctl 3520000.pinctrl: using UTMI port 0 for otg
[ 5.492431] random: systemd: uninitialized urandom read (16 bytes read, 97 bits of entropy available)
[ 5.504084] random: systemd: uninitialized urandom read (16 bytes read, 98 bits of entropy available)
[ 5.514179] random: systemd: uninitialized urandom read (16 bytes read, 98 bits of entropy available)
[ 5.526316] systemd[1]: systemd 229 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ -LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN)
[ 5.546525] systemd[1]: Detected architecture arm64.
[ 5.559751] systemd[1]: Set hostname to .
[ 5.578314] random: systemd: uninitialized urandom read (16 bytes read, 100 bits of entropy available)
[ 5.582173] random: systemd-cryptse: uninitialized urandom read (16 bytes read, 100 bits of entropy available)
[ 5.603049] random: systemd: uninitialized urandom read (16 bytes read, 101 bits of entropy available)
[ 5.606518] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 101 bits of entropy available)
[ 5.606576] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 101 bits of entropy available)
[ 5.606591] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 101 bits of entropy available)
[ 5.606681] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 101 bits of entropy available)
[ 5.726850] systemd[1]: Listening on Syslog Socket.
[ 5.734066] systemd[1]: Listening on udev Kernel Socket.
[ 5.741343] systemd[1]: Reached target Remote File Systems (Pre).
[ 5.749366] systemd[1]: Reached target Remote File Systems.
[ 5.756894] systemd[1]: Reached target Encrypted Volumes.
[ 5.764362] systemd[1]: Reached target User and Group Name Lookups.
[ 5.772771] systemd[1]: Reached target Swap.
[ 5.779170] systemd[1]: Listening on udev Control Socket.
[ 5.786174] systemd[1]: Listening on Journal Socket.
[ 5.792694] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 5.801194] systemd[1]: Listening on Journal Audit Socket.
[ 5.809012] systemd[1]: Created slice User and Session Slice.
[ 5.816885] systemd[1]: Created slice System Slice.
[ 5.828920] systemd[1]: Starting Create list of required static device nodes for the current kernel…
[ 5.842714] systemd[1]: Started Braille Device Support.
[ 5.851862] systemd[1]: Starting Remount Root and Kernel File Systems…
[ 5.861524] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 5.862131] systemd[1]: Mounting Debug File System…
[ 5.874873] systemd[1]: Reached target Slices.
[ 5.882905] systemd[1]: Mounting POSIX Message Queue File System…
[ 5.891653] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 5.901280] systemd[1]: Starting Set console keymap…
[ 5.914089] systemd[1]: Starting Load Kernel Modules…
[ 5.920836] systemd[1]: Listening on Journal Socket (/dev/log).
[ 5.926631] Wake76 for irq=199
[ 5.926632] Wake77 for irq=199
[ 5.926633] Wake78 for irq=199
[ 5.926634] Wake79 for irq=199
[ 5.926635] Wake80 for irq=199
[ 5.926635] Wake81 for irq=199
[ 5.926636] Wake82 for irq=199
[ 5.926838] xhci-tegra 3530000.xhci: can’t get usb3-0 phy (-517)
[ 5.927229] Wake76 for irq=199
[ 5.927230] Wake77 for irq=199
[ 5.927231] Wake78 for irq=199
[ 5.927231] Wake79 for irq=199
[ 5.927232] Wake80 for irq=199
[ 5.927233] Wake81 for irq=199
[ 5.927233] Wake82 for irq=199
[ 5.927268] tegra-xotg xotg: usb2 phy is not available yet
[ 5.927421] tegra-usb-cd usb_cd: otg phy is not available yet
[ 5.927874] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ 5.928062] tegra186-padctl 3520000.pinctrl: padctl mmio start 0x0000000003520000 end 0x0000000003520fff
[ 5.928067] tegra186-padctl 3520000.pinctrl: ao mmio start 0x0000000003540000 end 0x0000000003540fff
[ 5.928103] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x28a894
[ 5.928106] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x9
[ 5.928854] tegra186-padctl 3520000.pinctrl: using UTMI port 0 for otg
[ 5.929448] can: controller area network core (rev 20120528 abi 9)
[ 5.929487] NET: Registered protocol family 29
[ 5.932169] can: raw protocol (rev 20120528)
[ 5.935132] CAN device driver interface
[ 5.947608] Message RAM Configuration
| base addr |0x0c312000|
| sidfc_flssa |0x00000000|
| xidfc_flesa |0x00000040|
| rxf0c_f0sa |0x000000c0|
| rxf1c_f1sa |0x00000300|
| rxbc_rbsa |0x00000540|
| txefc_efsa |0x00000780|
| txbc_tbsa |0x00000800|
| tmc_tmsa |0x00000c80|
[ 5.947778] Release 3.2.0 from 19.12.2014
[ 5.948005] net can0: mttcan device registered (regs=ffffff8006f7e000, irq=427)
[ 5.949119] Message RAM Configuration
| base addr |0x0c322000|
[ 5.949286] Release 3.2.0 from 19.12.2014
[ 5.949482] net can1: mttcan device registered (regs=ffffff8007ffe000, irq=428)
[ 5.950132] Wake76 for irq=199
[ 5.950133] Wake77 for irq=199
[ 5.950134] Wake78 for irq=199
[ 5.950134] Wake79 for irq=199
[ 5.950135] Wake80 for irq=199
[ 5.950136] Wake81 for irq=199
[ 5.950136] Wake82 for irq=199
[ 5.950346] xhci-tegra 3530000.xhci: can’t get usb3-0 phy (-517)
[ 5.950685] Wake76 for irq=199
[ 5.950686] Wake77 for irq=199
[ 5.950687] Wake78 for irq=199
[ 5.950687] Wake79 for irq=199
[ 5.950688] Wake80 for irq=199
[ 5.950689] Wake81 for irq=199
[ 5.950689] Wake82 for irq=199
[ 5.950718] tegra-xotg xotg: usb2 phy is not available yet
[ 5.950840] tegra-usb-cd usb_cd: otg phy is not available yet
[ 5.951237] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ 5.951389] tegra186-padctl 3520000.pinctrl: padctl mmio start 0x0000000003520000 end 0x0000000003520fff
[ 5.951393] tegra186-padctl 3520000.pinctrl: ao mmio start 0x0000000003540000 end 0x0000000003540fff
[ 5.951430] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x28a894
[ 5.951433] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x9
[ 5.952133] tegra186-padctl 3520000.pinctrl: using UTMI port 0 for otg
[ 5.953278] vcan: Virtual CAN interface driver
[ 6.286601] tegra-i2c 3190000.i2c: rx dma timeout txlen:28 rxlen:128
[ 6.293329] tegra-i2c 3190000.i2c: — register dump for debugging ----
[ 6.293333] tegra-i2c 3190000.i2c: I2C_CNFG - 0x22c00
[ 6.293336] tegra-i2c 3190000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 6.293339] tegra-i2c 3190000.i2c: I2C_FIFO_CONTROL - 0x1c
[ 6.293342] tegra-i2c 3190000.i2c: I2C_FIFO_STATUS - 0x800040
[ 6.293352] tegra-i2c 3190000.i2c: I2C_INT_MASK - 0x6c
[ 6.293355] tegra-i2c 3190000.i2c: I2C_INT_STATUS - 0x2
[ 6.293410] tegra-i2c 3190000.i2c: i2c transfer timed out addr: 0x50
[ 6.345355] systemd[1]: Starting Journal Service…
[ 6.349661] random: nonblocking pool is initialized
[ 6.356849] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 6.370273] systemd[1]: Mounted POSIX Message Queue File System.
[ 6.377527] systemd[1]: Mounted Debug File System.
[ 6.385349] systemd[1]: Started Create list of required static device nodes for the current kernel.
[ 6.399957] systemd[1]: Started Remount Root and Kernel File Systems.
[ 6.409928] systemd[1]: Started Set console keymap.
[ 6.418179] systemd[1]: Started Load Kernel Modules.
[ 6.424861] systemd[1]: Started Journal Service.
[ 6.589524] systemd-journald[309]: Received request to flush runtime journal from PID 1
[ 6.814732] tegra-pcie 10003000.pcie-controller: 4x1, 1x1 configuration
[ 6.815684] Wake76 for irq=199
[ 6.815685] Wake77 for irq=199
[ 6.815686] Wake78 for irq=199
[ 6.815687] Wake79 for irq=199
[ 6.815687] Wake80 for irq=199
[ 6.815688] Wake81 for irq=199
[ 6.815689] Wake82 for irq=199
[ 6.815898] tegra-pcie 10003000.pcie-controller: PCIE: Enable power rails
[ 6.815998] xhci-tegra 3530000.xhci: can’t get usb3-0 phy (-517)
[ 6.816352] tegra-pcie 10003000.pcie-controller: probing port 0, using 4 lanes
[ 6.816525] Wake76 for irq=199
[ 6.816526] Wake77 for irq=199
[ 6.816526] Wake78 for irq=199
[ 6.816527] Wake79 for irq=199
[ 6.816528] Wake80 for irq=199
[ 6.816529] Wake81 for irq=199
[ 6.816529] Wake82 for irq=199
[ 6.816572] tegra-xotg xotg: usb2 phy is not available yet
[ 6.816797] tegra-usb-cd usb_cd: otg phy is not available yet
[ 6.817327] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ 6.817577] tegra186-padctl 3520000.pinctrl: padctl mmio start 0x0000000003520000 end 0x0000000003520fff
[ 6.817582] tegra186-padctl 3520000.pinctrl: ao mmio start 0x0000000003540000 end 0x0000000003540fff
[ 6.817617] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x28a894
[ 6.817620] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x9
[ 6.818437] tegra186-padctl 3520000.pinctrl: using UTMI port 0 for otg
[ 6.818971] tegra-pcie 10003000.pcie-controller: probing port 2, using 1 lanes
[ 6.850959] cfg80211: World regulatory domain updated:
[ 6.850964] cfg80211: DFS Master region: unset
[ 6.850964] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 6.850970] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 6.850974] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz, 92000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 6.850976] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 6.850979] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 6.850983] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 6.850985] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 6.850988] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 6.850990] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 7.030952] dhd_module_init in
[ 7.030983] tegra_net_perf_init: cannot get wifi sclk
[ 7.031051] found wifi platform device bcmdhd_wlan
[ 7.037668] wifi_platform_get_country_code_map: could not get country_code_map
[ 7.037670] wifi_plat_dev_drv_probe:platform country code map is not available
[ 7.037680] Power-up adapter ‘DHD generic adapter’
[ 7.037687] wifi_platform_set_power = 1
[ 7.240241] tegra-pcie 10003000.pcie-controller: link 0 down, retrying
[ 7.240243] wifi_platform_bus_enumerate device present 1
[ 7.254702] Wake76 for irq=199
[ 7.254703] Wake77 for irq=199
[ 7.254704] Wake78 for irq=199
[ 7.254705] Wake79 for irq=199
[ 7.254705] Wake80 for irq=199
[ 7.254706] Wake81 for irq=199
[ 7.254707] Wake82 for irq=199
[ 7.255043] xhci-tegra 3530000.xhci: can’t get usb3-0 phy (-517)
[ 7.255982] Wake76 for irq=199
[ 7.255983] Wake77 for irq=199
[ 7.255984] Wake78 for irq=199
[ 7.255985] Wake79 for irq=199
[ 7.255985] Wake80 for irq=199
[ 7.255986] Wake81 for irq=199
[ 7.255987] Wake82 for irq=199
[ 7.256058] tegra-xotg xotg: usb2 phy is not available yet
[ 7.256383] tegra-usb-cd usb_cd: otg phy is not available yet
[ 7.257080] tegra-xudc-new 3550000.xudc: usb2 phy is not available yet
[ 7.257447] tegra186-padctl 3520000.pinctrl: padctl mmio start 0x0000000003520000 end 0x0000000003520fff
[ 7.257453] tegra186-padctl 3520000.pinctrl: ao mmio start 0x0000000003540000 end 0x0000000003540fff
[ 7.257490] tegra186-padctl 3520000.pinctrl: FUSE_SKU_USB_CALIB_0 0x28a894
[ 7.257493] tegra186-padctl 3520000.pinctrl: FUSE_USB_CALIB_EXT_0 0x9
[ 7.258535] tegra186-padctl 3520000.pinctrl: using UTMI port 0 for otg
[ 7.261807] Wake76 for irq=199
[ 7.261808] Wake77 for irq=199
[ 7.261809] Wake78 for irq=199
[ 7.261810] Wake79 for irq=199
[ 7.261811] Wake80 for irq=199
[ 7.261811] Wake81 for irq=199
[ 7.261812] Wake82 for irq=199
[ 7.262047] xhci-tegra 3530000.xhci: can’t get usb3-0 phy (-517)
[ 7.267336] wifi_platform_bus_enumerate device present 0
[ 7.267871] F1 signature read @0x18000000=0x17214354
[ 7.267918] Wake76 for irq=199
[ 7.267919] Wake77 for irq=199
[ 7.267919] Wake78 for irq=199
[ 7.267920] Wake79 for irq=199
[ 7.267921] Wake80 for irq=199
[ 7.267921] Wake81 for irq=199
[ 7.267922] Wake82 for irq=199
[ 7.268001] tegra-xotg xotg: usb2 phy is not available yet
[ 7.268369] tegra-usb-cd usb_cd: otg phy is not
