After going through this:: Deploying Tensorflow Model on Jetson Xavier NX: onnx to tensorrt - #4 by AastaLLL
I reinstalled the newest version of onnx-tensorrt and then tried out the compatibility again which gave this:;
&&&& RUNNING TensorRT.trtexec # /usr/src/tensorrt/bin/trtexec --onnx=/home/nano/tfobjectdetection/workspace/fp16model.onnx --verbose
[04/20/2021-01:10:00] [I] === Model Options ===
[04/20/2021-01:10:00] [I] Format: ONNX
[04/20/2021-01:10:00] [I] Model: /home/nano/tfobjectdetection/workspace/fp16model.onnx
[04/20/2021-01:10:00] [I] Output:
[04/20/2021-01:10:00] [I] === Build Options ===
[04/20/2021-01:10:00] [I] Max batch: 1
[04/20/2021-01:10:00] [I] Workspace: 16 MB
[04/20/2021-01:10:00] [I] minTiming: 1
[04/20/2021-01:10:00] [I] avgTiming: 8
[04/20/2021-01:10:00] [I] Precision: FP32
[04/20/2021-01:10:00] [I] Calibration:
[04/20/2021-01:10:00] [I] Safe mode: Disabled
[04/20/2021-01:10:00] [I] Save engine:
[04/20/2021-01:10:00] [I] Load engine:
[04/20/2021-01:10:00] [I] Builder Cache: Enabled
[04/20/2021-01:10:00] [I] NVTX verbosity: 0
[04/20/2021-01:10:00] [I] Inputs format: fp32:CHW
[04/20/2021-01:10:00] [I] Outputs format: fp32:CHW
[04/20/2021-01:10:00] [I] Input build shapes: model
[04/20/2021-01:10:00] [I] Input calibration shapes: model
[04/20/2021-01:10:00] [I] === System Options ===
[04/20/2021-01:10:00] [I] Device: 0
[04/20/2021-01:10:00] [I] DLACore:
[04/20/2021-01:10:00] [I] Plugins:
[04/20/2021-01:10:00] [I] === Inference Options ===
[04/20/2021-01:10:00] [I] Batch: 1
[04/20/2021-01:10:00] [I] Input inference shapes: model
[04/20/2021-01:10:00] [I] Iterations: 10
[04/20/2021-01:10:00] [I] Duration: 3s (+ 200ms warm up)
[04/20/2021-01:10:00] [I] Sleep time: 0ms
[04/20/2021-01:10:00] [I] Streams: 1
[04/20/2021-01:10:00] [I] ExposeDMA: Disabled
[04/20/2021-01:10:00] [I] Spin-wait: Disabled
[04/20/2021-01:10:00] [I] Multithreading: Disabled
[04/20/2021-01:10:00] [I] CUDA Graph: Disabled
[04/20/2021-01:10:00] [I] Skip inference: Disabled
[04/20/2021-01:10:00] [I] Inputs:
[04/20/2021-01:10:00] [I] === Reporting Options ===
[04/20/2021-01:10:00] [I] Verbose: Enabled
[04/20/2021-01:10:00] [I] Averages: 10 inferences
[04/20/2021-01:10:00] [I] Percentile: 99
[04/20/2021-01:10:00] [I] Dump output: Disabled
[04/20/2021-01:10:00] [I] Profile: Disabled
[04/20/2021-01:10:00] [I] Export timing to JSON file:
[04/20/2021-01:10:00] [I] Export output to JSON file:
[04/20/2021-01:10:00] [I] Export profile to JSON file:
[04/20/2021-01:10:00] [V] [TRT] Registered plugin creator - ::GridAnchor_TRT version 1
[04/20/2021-01:10:00] [V] [TRT] Registered plugin creator - ::NMS_TRT version 1
[04/20/2021-01:10:00] [V] [TRT] Registered plugin creator - ::Reorg_TRT version 1
[04/20/2021-01:10:00] [V] [TRT] Registered plugin creator - ::Region_TRT version 1
[04/20/2021-01:10:00] [V] [TRT] Registered plugin creator - ::Clip_TRT version 1
[04/20/2021-01:10:00] [V] [TRT] Registered plugin creator - ::LReLU_TRT version 1
[04/20/2021-01:10:00] [V] [TRT] Registered plugin creator - ::PriorBox_TRT version 1
[04/20/2021-01:10:00] [V] [TRT] Registered plugin creator - ::Normalize_TRT version 1
[04/20/2021-01:10:00] [V] [TRT] Registered plugin creator - ::RPROI_TRT version 1
[04/20/2021-01:10:00] [V] [TRT] Registered plugin creator - ::BatchedNMS_TRT version 1
[04/20/2021-01:10:00] [V] [TRT] Registered plugin creator - ::FlattenConcat_TRT version 1
[04/20/2021-01:10:00] [V] [TRT] Registered plugin creator - ::CropAndResize version 1
[04/20/2021-01:10:00] [V] [TRT] Registered plugin creator - ::DetectionLayer_TRT version 1
[04/20/2021-01:10:00] [V] [TRT] Registered plugin creator - ::Proposal version 1
[04/20/2021-01:10:00] [V] [TRT] Registered plugin creator - ::ProposalLayer_TRT version 1
[04/20/2021-01:10:00] [V] [TRT] Registered plugin creator - ::PyramidROIAlign_TRT version 1
[04/20/2021-01:10:00] [V] [TRT] Registered plugin creator - ::ResizeNearest_TRT version 1
[04/20/2021-01:10:00] [V] [TRT] Registered plugin creator - ::Split version 1
[04/20/2021-01:10:00] [V] [TRT] Registered plugin creator - ::SpecialSlice_TRT version 1
[04/20/2021-01:10:00] [V] [TRT] Registered plugin creator - ::InstanceNormalization_TRT version 1
[04/20/2021-01:10:02] [I] [TRT] ----------------------------------------------------------------
[04/20/2021-01:10:02] [I] [TRT] Input filename: /home/nano/tfobjectdetection/workspace/fp16model.onnx
[04/20/2021-01:10:02] [I] [TRT] ONNX IR version: 0.0.7
[04/20/2021-01:10:02] [I] [TRT] Opset version: 13
[04/20/2021-01:10:02] [I] [TRT] Producer name:
[04/20/2021-01:10:02] [I] [TRT] Producer version:
[04/20/2021-01:10:02] [I] [TRT] Domain:
[04/20/2021-01:10:02] [I] [TRT] Model version: 0
[04/20/2021-01:10:02] [I] [TRT] Doc string:
[04/20/2021-01:10:02] [V] [TRT] Plugin creator already registered - ::GridAnchor_TRT version 1
[04/20/2021-01:10:02] [V] [TRT] Plugin creator already registered - ::NMS_TRT version 1
[04/20/2021-01:10:02] [V] [TRT] Plugin creator already registered - ::Reorg_TRT version 1
[04/20/2021-01:10:02] [V] [TRT] Plugin creator already registered - ::Region_TRT version 1
[04/20/2021-01:10:02] [V] [TRT] Plugin creator already registered - ::Clip_TRT version 1
[04/20/2021-01:10:02] [V] [TRT] Plugin creator already registered - ::LReLU_TRT version 1
[04/20/2021-01:10:02] [V] [TRT] Plugin creator already registered - ::PriorBox_TRT version 1
[04/20/2021-01:10:02] [V] [TRT] Plugin creator already registered - ::Normalize_TRT version 1
[04/20/2021-01:10:02] [V] [TRT] Plugin creator already registered - ::RPROI_TRT version 1
[04/20/2021-01:10:02] [V] [TRT] Plugin creator already registered - ::BatchedNMS_TRT version 1
[04/20/2021-01:10:02] [V] [TRT] Plugin creator already registered - ::FlattenConcat_TRT version 1
[04/20/2021-01:10:02] [V] [TRT] Plugin creator already registered - ::CropAndResize version 1
[04/20/2021-01:10:02] [V] [TRT] Plugin creator already registered - ::DetectionLayer_TRT version 1
[04/20/2021-01:10:02] [V] [TRT] Plugin creator already registered - ::Proposal version 1
[04/20/2021-01:10:02] [V] [TRT] Plugin creator already registered - ::ProposalLayer_TRT version 1
[04/20/2021-01:10:02] [V] [TRT] Plugin creator already registered - ::PyramidROIAlign_TRT version 1
[04/20/2021-01:10:02] [V] [TRT] Plugin creator already registered - ::ResizeNearest_TRT version 1
[04/20/2021-01:10:02] [V] [TRT] Plugin creator already registered - ::Split version 1
[04/20/2021-01:10:02] [V] [TRT] Plugin creator already registered - ::SpecialSlice_TRT version 1
[04/20/2021-01:10:02] [V] [TRT] Plugin creator already registered - ::InstanceNormalization_TRT version 1
[04/20/2021-01:10:02] [V] [TRT] Adding network input: input_tensor:0 with dtype: float32, dimensions: (1, 3, 640, 640)
[04/20/2021-01:10:02] [V] [TRT] Registering tensor: input_tensor:0 for ONNX tensor: input_tensor:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/Preprocessor/mul/x:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/Preprocessor/sub/y:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: const_axes__1092
[04/20/2021-01:10:02] [W] [TRT] /home/nano/onnx-tensorrt/onnx2trt_utils.cpp:229: Your ONNX model has been generated with INT64 weights, while TensorRT does not natively support INT64. Attempting to cast down to INT32.
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: const_axes__534
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: const_fold_opt__1274
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: const_empty_float__37
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/Conv1/Conv2D_weights_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/Conv1/Conv2D_bias_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/Postprocessor/BatchMultiClassNonMaxSuppression/MultiClassNonMaxSuppression/ClipToWindow/Greater/y:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_8_depthwise_relu/Relu6_max__220
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/expanded_conv_depthwise/depthwise_weights_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/expanded_conv_depthwise/depthwise_bias_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/expanded_conv_project/Conv2D_weights_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/expanded_conv_project/Conv2D_bias_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_1_expand/Conv2D/ReadVariableOp:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_1_expand_BN/ReadVariableOp:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_1_expand_BN/ReadVariableOp_1:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_1_expand_BN/FusedBatchNormV3/ReadVariableOp:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_1_expand_BN/FusedBatchNormV3/ReadVariableOp_1:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_1_depthwise/depthwise_weights_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_1_depthwise/depthwise_bias_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_1_project/Conv2D_weights_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_1_project/Conv2D_bias_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_2_expand/Conv2D/ReadVariableOp:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_2_expand_BN/ReadVariableOp:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_2_expand_BN/ReadVariableOp_1:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_2_expand_BN/FusedBatchNormV3/ReadVariableOp:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_2_expand_BN/FusedBatchNormV3/ReadVariableOp_1:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_2_depthwise/depthwise_weights_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_2_depthwise/depthwise_bias_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_2_project/Conv2D_weights_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_2_project/Conv2D_bias_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_3_expand/Conv2D_weights_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_3_expand/Conv2D_bias_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_3_depthwise/depthwise_weights_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_3_depthwise/depthwise_bias_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_3_project/Conv2D_weights_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_3_project/Conv2D_bias_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_4_expand/Conv2D/ReadVariableOp:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_4_expand_BN/ReadVariableOp:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_4_expand_BN/ReadVariableOp_1:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_4_expand_BN/FusedBatchNormV3/ReadVariableOp:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_4_expand_BN/FusedBatchNormV3/ReadVariableOp_1:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_4_depthwise/depthwise_weights_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_4_depthwise/depthwise_bias_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_4_project/Conv2D_weights_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_4_project/Conv2D_bias_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_5_expand/Conv2D_weights_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_5_expand/Conv2D_bias_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_5_depthwise/depthwise_weights_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_5_depthwise/depthwise_bias_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_5_project/Conv2D_weights_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_5_project/Conv2D_bias_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_6_expand/Conv2D_weights_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_6_expand/Conv2D_bias_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_6_depthwise/depthwise_weights_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_6_depthwise/depthwise_bias_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_6_project/Conv2D_weights_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_6_project/Conv2D_bias_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_7_expand/Conv2D/ReadVariableOp:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_7_expand_BN/ReadVariableOp:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_7_expand_BN/ReadVariableOp_1:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_7_expand_BN/FusedBatchNormV3/ReadVariableOp:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_7_expand_BN/FusedBatchNormV3/ReadVariableOp_1:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_7_depthwise/depthwise_weights_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_7_depthwise/depthwise_bias_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_7_project/Conv2D_weights_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_7_project/Conv2D_bias_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_8_expand/Conv2D_weights_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_8_expand/Conv2D_bias_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_8_depthwise/depthwise_weights_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_8_depthwise/depthwise_bias_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_8_project/Conv2D_weights_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_8_project/Conv2D_bias_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_9_expand/Conv2D_weights_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_9_expand/Conv2D_bias_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_9_depthwise/depthwise_weights_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_9_depthwise/depthwise_bias_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_9_project/Conv2D_weights_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_9_project/Conv2D_bias_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_10_expand/Conv2D_weights_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_10_expand/Conv2D_bias_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_10_depthwise/depthwise_weights_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_10_depthwise/depthwise_bias_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_10_project/Conv2D_weights_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_10_project/Conv2D_bias_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_11_expand/Conv2D/ReadVariableOp:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_11_expand_BN/ReadVariableOp:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_11_expand_BN/ReadVariableOp_1:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_11_expand_BN/FusedBatchNormV3/ReadVariableOp:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_11_expand_BN/FusedBatchNormV3/ReadVariableOp_1:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_11_depthwise/depthwise_weights_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_11_depthwise/depthwise_bias_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_11_project/Conv2D_weights_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_11_project/Conv2D_bias_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_12_expand/Conv2D_weights_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_12_expand/Conv2D_bias_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_12_depthwise/depthwise_weights_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_12_depthwise/depthwise_bias_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_12_project/Conv2D_weights_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_12_project/Conv2D_bias_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_13_expand/Conv2D_weights_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_13_expand/Conv2D_bias_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_13_depthwise/depthwise_weights_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_13_depthwise/depthwise_bias_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_13_project/Conv2D_weights_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_13_project/Conv2D_bias_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_14_expand/Conv2D/ReadVariableOp:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_14_expand_BN/ReadVariableOp:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_14_expand_BN/ReadVariableOp_1:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_14_expand_BN/FusedBatchNormV3/ReadVariableOp:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_14_expand_BN/FusedBatchNormV3/ReadVariableOp_1:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_14_depthwise/depthwise_weights_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_14_depthwise/depthwise_bias_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_14_project/Conv2D_weights_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_14_project/Conv2D_bias_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_15_expand/Conv2D_weights_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_15_expand/Conv2D_bias_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_15_depthwise/depthwise_weights_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_15_depthwise/depthwise_bias_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_15_project/Conv2D_weights_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_15_project/Conv2D_bias_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_16_expand/Conv2D_weights_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_16_expand/Conv2D_bias_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_16_depthwise/depthwise_weights_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_16_depthwise/depthwise_bias_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_16_project/Conv2D_weights_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/block_16_project/Conv2D_bias_fused_bn
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/Conv_1/Conv2D/ReadVariableOp:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/Conv_1_bn/ReadVariableOp:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/Conv_1_bn/ReadVariableOp_1:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/Conv_1_bn/FusedBatchNormV3/ReadVariableOp:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/functional_1/Conv_1_bn/FusedBatchNormV3/ReadVariableOp_1:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/FeatureMaps/top_down/projection_3/Conv2D/ReadVariableOp:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/FeatureMaps/top_down/projection_3/BiasAdd/ReadVariableOp:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: const_fold_opt__1246
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/bottom_up_Conv2d_20_depthwise_conv/separable_conv2d/ReadVariableOp_1:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/bottom_up_Conv2d_20_batchnorm/ReadVariableOp:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/bottom_up_Conv2d_20_batchnorm/ReadVariableOp_1:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/bottom_up_Conv2d_20_batchnorm/FusedBatchNormV3/ReadVariableOp:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/bottom_up_Conv2d_20_batchnorm/FusedBatchNormV3/ReadVariableOp_1:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: const_fold_opt__1273
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/bottom_up_Conv2d_21_depthwise_conv/separable_conv2d/ReadVariableOp_1:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/bottom_up_Conv2d_21_batchnorm/ReadVariableOp:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/bottom_up_Conv2d_21_batchnorm/ReadVariableOp_1:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/bottom_up_Conv2d_21_batchnorm/FusedBatchNormV3/ReadVariableOp:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/bottom_up_Conv2d_21_batchnorm/FusedBatchNormV3/ReadVariableOp_1:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: const_fold_opt__1239
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_0/separable_conv2d_3/ReadVariableOp_1:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_0/BatchNorm/feature_4/ReadVariableOp:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_0/BatchNorm/feature_4/ReadVariableOp_1:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_0/BatchNorm/feature_4/FusedBatchNormV3/ReadVariableOp:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_0/BatchNorm/feature_4/FusedBatchNormV3/ReadVariableOp_1:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: const_fold_opt__1204
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_1/separable_conv2d_1/ReadVariableOp_1:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_1/BatchNorm/feature_4/ReadVariableOp:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_1/BatchNorm/feature_4/ReadVariableOp_1:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_1/BatchNorm/feature_4/FusedBatchNormV3/ReadVariableOp:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_1/BatchNorm/feature_4/FusedBatchNormV3/ReadVariableOp_1:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: const_fold_opt__1212
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_2/separable_conv2d/ReadVariableOp_1:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_2/BatchNorm/feature_4/ReadVariableOp:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_2/BatchNorm/feature_4/ReadVariableOp_1:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_2/BatchNorm/feature_4/FusedBatchNormV3/ReadVariableOp:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_2/BatchNorm/feature_4/FusedBatchNormV3/ReadVariableOp_1:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: const_fold_opt__1259
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_3/separable_conv2d_1/ReadVariableOp_1:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_3/BatchNorm/feature_4/ReadVariableOp:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_3/BatchNorm/feature_4/ReadVariableOp_1:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_3/BatchNorm/feature_4/FusedBatchNormV3/ReadVariableOp:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_3/BatchNorm/feature_4/FusedBatchNormV3/ReadVariableOp_1:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: const_fold_opt__1304
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/WeightSharedConvolutionalClassHead/ClassPredictor/separable_conv2d_1/ReadVariableOp_1:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/WeightSharedConvolutionalClassHead/ClassPredictor/BiasAdd_3/ReadVariableOp:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: const_fold_opt__1205
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: const_fold_opt__1229
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: const_fold_opt__1242
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/WeightSharedConvolutionalBoxHead/BoxPredictor/separable_conv2d_1/ReadVariableOp_1:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/WeightSharedConvolutionalBoxHead/BoxPredictor/BiasAdd/ReadVariableOp:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: const_fold_opt__1219
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_0/BatchNorm/feature_3/ReadVariableOp:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_0/BatchNorm/feature_3/ReadVariableOp_1:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_0/BatchNorm/feature_3/FusedBatchNormV3/ReadVariableOp:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_0/BatchNorm/feature_3/FusedBatchNormV3/ReadVariableOp_1:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_1/BatchNorm/feature_3/ReadVariableOp:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_1/BatchNorm/feature_3/ReadVariableOp_1:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_1/BatchNorm/feature_3/FusedBatchNormV3/ReadVariableOp:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_1/BatchNorm/feature_3/FusedBatchNormV3/ReadVariableOp_1:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_2/BatchNorm/feature_3/ReadVariableOp:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_2/BatchNorm/feature_3/ReadVariableOp_1:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_2/BatchNorm/feature_3/FusedBatchNormV3/ReadVariableOp:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_2/BatchNorm/feature_3/FusedBatchNormV3/ReadVariableOp_1:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_3/BatchNorm/feature_3/ReadVariableOp:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_3/BatchNorm/feature_3/ReadVariableOp_1:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_3/BatchNorm/feature_3/FusedBatchNormV3/ReadVariableOp:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_3/BatchNorm/feature_3/FusedBatchNormV3/ReadVariableOp_1:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: const_fold_opt__1248
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: const_axes__531__1184
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: const_fold_opt__1216
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_0/BatchNorm/feature_2/ReadVariableOp:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_0/BatchNorm/feature_2/ReadVariableOp_1:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_0/BatchNorm/feature_2/FusedBatchNormV3/ReadVariableOp:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_0/BatchNorm/feature_2/FusedBatchNormV3/ReadVariableOp_1:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_1/BatchNorm/feature_2/ReadVariableOp:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_1/BatchNorm/feature_2/ReadVariableOp_1:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_1/BatchNorm/feature_2/FusedBatchNormV3/ReadVariableOp:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_1/BatchNorm/feature_2/FusedBatchNormV3/ReadVariableOp_1:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_2/BatchNorm/feature_2/ReadVariableOp:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_2/BatchNorm/feature_2/ReadVariableOp_1:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_2/BatchNorm/feature_2/FusedBatchNormV3/ReadVariableOp:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_2/BatchNorm/feature_2/FusedBatchNormV3/ReadVariableOp_1:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_3/BatchNorm/feature_2/ReadVariableOp:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_3/BatchNorm/feature_2/ReadVariableOp_1:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_3/BatchNorm/feature_2/FusedBatchNormV3/ReadVariableOp:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_3/BatchNorm/feature_2/FusedBatchNormV3/ReadVariableOp_1:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: const_fold_opt__1267
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/FeatureMaps/top_down/projection_2/Conv2D/ReadVariableOp:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/FeatureMaps/top_down/projection_2/BiasAdd/ReadVariableOp:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: const_fold_opt__1289
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/FeatureMaps/top_down/smoothing_2_depthwise_conv/separable_conv2d/ReadVariableOp_1:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/FeatureMaps/top_down/smoothing_2_batchnorm/ReadVariableOp:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/FeatureMaps/top_down/smoothing_2_batchnorm/ReadVariableOp_1:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/FeatureMaps/top_down/smoothing_2_batchnorm/FusedBatchNormV3/ReadVariableOp:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/FeatureMaps/top_down/smoothing_2_batchnorm/FusedBatchNormV3/ReadVariableOp_1:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: const_fold_opt__1257
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_0/BatchNorm/feature_1/ReadVariableOp:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_0/BatchNorm/feature_1/ReadVariableOp_1:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_0/BatchNorm/feature_1/FusedBatchNormV3/ReadVariableOp:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_0/BatchNorm/feature_1/FusedBatchNormV3/ReadVariableOp_1:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_1/BatchNorm/feature_1/ReadVariableOp:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_1/BatchNorm/feature_1/ReadVariableOp_1:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_1/BatchNorm/feature_1/FusedBatchNormV3/ReadVariableOp:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_1/BatchNorm/feature_1/FusedBatchNormV3/ReadVariableOp_1:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_2/BatchNorm/feature_1/ReadVariableOp:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_2/BatchNorm/feature_1/ReadVariableOp_1:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_2/BatchNorm/feature_1/FusedBatchNormV3/ReadVariableOp:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_2/BatchNorm/feature_1/FusedBatchNormV3/ReadVariableOp_1:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_3/BatchNorm/feature_1/ReadVariableOp:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_3/BatchNorm/feature_1/ReadVariableOp_1:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_3/BatchNorm/feature_1/FusedBatchNormV3/ReadVariableOp:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_3/BatchNorm/feature_1/FusedBatchNormV3/ReadVariableOp_1:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: const_fold_opt__1301
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/FeatureMaps/top_down/projection_1/Conv2D/ReadVariableOp:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/FeatureMaps/top_down/projection_1/BiasAdd/ReadVariableOp:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: const_fold_opt__1308
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/FeatureMaps/top_down/smoothing_1_depthwise_conv/separable_conv2d/ReadVariableOp_1:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/FeatureMaps/top_down/smoothing_1_batchnorm/ReadVariableOp:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/FeatureMaps/top_down/smoothing_1_batchnorm/ReadVariableOp_1:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/FeatureMaps/top_down/smoothing_1_batchnorm/FusedBatchNormV3/ReadVariableOp:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/ssd_mobile_net_v2fpn_keras_feature_extractor/FeatureMaps/top_down/smoothing_1_batchnorm/FusedBatchNormV3/ReadVariableOp_1:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_0/BatchNorm/feature_0/ReadVariableOp:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_0/BatchNorm/feature_0/ReadVariableOp_1:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_0/BatchNorm/feature_0/FusedBatchNormV3/ReadVariableOp:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_0/BatchNorm/feature_0/FusedBatchNormV3/ReadVariableOp_1:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_1/BatchNorm/feature_0/ReadVariableOp:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_1/BatchNorm/feature_0/ReadVariableOp_1:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_1/BatchNorm/feature_0/FusedBatchNormV3/ReadVariableOp:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_1/BatchNorm/feature_0/FusedBatchNormV3/ReadVariableOp_1:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_2/BatchNorm/feature_0/ReadVariableOp:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_2/BatchNorm/feature_0/ReadVariableOp_1:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_2/BatchNorm/feature_0/FusedBatchNormV3/ReadVariableOp:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_2/BatchNorm/feature_0/FusedBatchNormV3/ReadVariableOp_1:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_3/BatchNorm/feature_0/ReadVariableOp:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_3/BatchNorm/feature_0/ReadVariableOp_1:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_3/BatchNorm/feature_0/FusedBatchNormV3/ReadVariableOp:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/WeightSharedConvolutionalBoxPredictor/PredictionTower/conv2d_3/BatchNorm/feature_0/FusedBatchNormV3/ReadVariableOp_1:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: const_fold_opt__1293
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: const_starts__752
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: const_ends__753
[04/20/2021-01:10:02] [V] [TRT] Weight at index 0: 9223372036854775807 is out of range. Clamping to: 2147483647
[04/20/2021-01:10:02] [V] [TRT] Weight at index 1: 9223372036854775807 is out of range. Clamping to: 2147483647
[04/20/2021-01:10:02] [V] [TRT] Weight at index 2: 9223372036854775807 is out of range. Clamping to: 2147483647
[04/20/2021-01:10:02] [W] [TRT] /home/nano/onnx-tensorrt/onnx2trt_utils.cpp:255: One or more weights outside the range of INT32 was clamped
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: const_fold_opt__1188
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: const_axes__796
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: const_fold_opt__1253
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: ConstantFolding/StatefulPartitionedCall/Postprocessor/Decode/truediv_2_recip:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/Postprocessor/Decode/get_center_coordinates_and_sizes/sub:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: ConstantFolding/StatefulPartitionedCall/Postprocessor/Decode/truediv_7_recip:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/Postprocessor/Decode/get_center_coordinates_and_sizes/sub_1:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/Postprocessor/Decode/truediv_1:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/Postprocessor/Decode/get_center_coordinates_and_sizes/add_1:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/Postprocessor/Decode/truediv:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/Postprocessor/Decode/get_center_coordinates_and_sizes/add:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: const_fold_opt__1194
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: const_fold_opt__1297
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/Postprocessor/BatchMultiClassNonMaxSuppression/MultiClassNonMaxSuppression/non_max_suppression_with_scores/iou_threshold:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/Postprocessor/BatchMultiClassNonMaxSuppression/MultiClassNonMaxSuppression/non_max_suppression_with_scores/score_threshold:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: const_ends__801
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/Postprocessor/BatchMultiClassNonMaxSuppression/PadOrClipBoxList/sub_18/y:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/Postprocessor/BatchMultiClassNonMaxSuppression/MultiClassNonMaxSuppression/zeros/Const:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/Postprocessor/BatchMultiClassNonMaxSuppression/Reshape_3:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: const_fold_opt__1255
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/Postprocessor/BatchMultiClassNonMaxSuppression/MultiClassNonMaxSuppression/mul:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/Postprocessor/BatchMultiClassNonMaxSuppression/MultiClassNonMaxSuppression/mul_1/x:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/Postprocessor/BatchMultiClassNonMaxSuppression/MultiClassNonMaxSuppression/Concatenate/concat_5/concat:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/Postprocessor/BatchMultiClassNonMaxSuppression/MultiClassNonMaxSuppression/range_1/delta:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/Postprocessor/BatchMultiClassNonMaxSuppression/PadOrClipBoxList/Select_7/e:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: const__976
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: largest_int_val__1080
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/Postprocessor/BatchMultiClassNonMaxSuppression/PadOrClipBoxList/zeros:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/Postprocessor/BatchMultiClassNonMaxSuppression/PadOrClipBoxList/sub_17/x:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: const_fold_opt__1269
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/Postprocessor/BatchMultiClassNonMaxSuppression/PadOrClipBoxList/sub_3/x:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: StatefulPartitionedCall/Postprocessor/BatchMultiClassNonMaxSuppression/PadOrClipBoxList/zeros_6:0
[04/20/2021-01:10:02] [V] [TRT] Importing initializer: const_fold_opt__1218
[04/20/2021-01:10:02] [V] [TRT] Parsing node: StatefulPartitionedCall/Cast [Cast]
[04/20/2021-01:10:02] [V] [TRT] Searching for input: input_tensor:0
[04/20/2021-01:10:02] [V] [TRT] StatefulPartitionedCall/Cast [Cast] inputs: [input_tensor:0 → (1, 3, 640, 640)],
[04/20/2021-01:10:02] [V] [TRT] Casting to type: float32
[04/20/2021-01:10:02] [V] [TRT] Registering layer: StatefulPartitionedCall/Cast for ONNX node: StatefulPartitionedCall/Cast
[04/20/2021-01:10:02] [V] [TRT] Registering tensor: StatefulPartitionedCall/Cast:0 for ONNX tensor: StatefulPartitionedCall/Cast:0
[04/20/2021-01:10:02] [V] [TRT] StatefulPartitionedCall/Cast [Cast] outputs: [StatefulPartitionedCall/Cast:0 → (1, 3, 640, 640)],
[04/20/2021-01:10:02] [V] [TRT] Parsing node: StatefulPartitionedCall/Preprocessor/mul [Mul]
[04/20/2021-01:10:02] [V] [TRT] Searching for input: StatefulPartitionedCall/Preprocessor/mul/x:0
[04/20/2021-01:10:02] [V] [TRT] Searching for input: StatefulPartitionedCall/Cast:0
[04/20/2021-01:10:02] [V] [TRT] StatefulPartitionedCall/Preprocessor/mul [Mul] inputs: [StatefulPartitionedCall/Preprocessor/mul/x:0 → ()], [StatefulPartitionedCall/Cast:0 → (1, 3, 640, 640)],
[04/20/2021-01:10:02] [V] [TRT] Registering constant layer: StatefulPartitionedCall/Preprocessor/mul/x:0 for ONNX initializer: StatefulPartitionedCall/Preprocessor/mul/x:0
[04/20/2021-01:10:02] [V] [TRT] Registering layer: StatefulPartitionedCall/Preprocessor/mul for ONNX node: StatefulPartitionedCall/Preprocessor/mul
[04/20/2021-01:10:02] [V] [TRT] Registering tensor: StatefulPartitionedCall/Preprocessor/mul:0 for ONNX tensor: StatefulPartitionedCall/Preprocessor/mul:0
[04/20/2021-01:10:02] [V] [TRT] StatefulPartitionedCall/Preprocessor/mul [Mul] outputs: [StatefulPartitionedCall/Preprocessor/mul:0 → (1, 3, 640, 640)],
[04/20/2021-01:10:02] [V] [TRT] Parsing node: StatefulPartitionedCall/Preprocessor/sub [Sub]
[04/20/2021-01:10:02] [V] [TRT] Searching for input: StatefulPartitionedCall/Preprocessor/mul:0
[04/20/2021-01:10:02] [V] [TRT] Searching for input: StatefulPartitionedCall/Preprocessor/sub/y:0
[04/20/2021-01:10:02] [V] [TRT] StatefulPartitionedCall/Preprocessor/sub [Sub] inputs: [StatefulPartitionedCall/Preprocessor/mul:0 → (1, 3, 640, 640)], [StatefulPartitionedCall/Preprocessor/sub/y:0 → ()],
[04/20/2021-01:10:02] [V] [TRT] Registering constant layer: StatefulPartitionedCall/Preprocessor/sub/y:0 for ONNX initializer: StatefulPartitionedCall/Preprocessor/sub/y:0
[04/20/2021-01:10:02] [V] [TRT] Registering layer: StatefulPartitionedCall/Preprocessor/sub for ONNX node: StatefulPartitionedCall/Preprocessor/sub
[04/20/2021-01:10:02] [V] [TRT] Registering tensor: StatefulPartitionedCall/Preprocessor/sub:0 for ONNX tensor: StatefulPartitionedCall/Preprocessor/sub:0
[04/20/2021-01:10:02] [V] [TRT] StatefulPartitionedCall/Preprocessor/sub [Sub] outputs: [StatefulPartitionedCall/Preprocessor/sub:0 → (1, 3, 640, 640)],
[04/20/2021-01:10:02] [V] [TRT] Parsing node: StatefulPartitionedCall/Preprocessor/unstack [Split]
[04/20/2021-01:10:02] [V] [TRT] Searching for input: StatefulPartitionedCall/Preprocessor/sub:0
[04/20/2021-01:10:02] [V] [TRT] StatefulPartitionedCall/Preprocessor/unstack [Split] inputs: [StatefulPartitionedCall/Preprocessor/sub:0 → (1, 3, 640, 640)],
[04/20/2021-01:10:02] [V] [TRT] Registering layer: StatefulPartitionedCall/Preprocessor/unstack for ONNX node: StatefulPartitionedCall/Preprocessor/unstack
[04/20/2021-01:10:02] [V] [TRT] Registering tensor: StatefulPartitionedCall/Preprocessor/unstack:0 for ONNX tensor: StatefulPartitionedCall/Preprocessor/unstack:0
[04/20/2021-01:10:02] [V] [TRT] StatefulPartitionedCall/Preprocessor/unstack [Split] outputs: [StatefulPartitionedCall/Preprocessor/unstack:0 → (1, 3, 640, 640)],
[04/20/2021-01:10:02] [V] [TRT] Parsing node: Transpose__38 [Transpose]
[04/20/2021-01:10:02] [V] [TRT] Searching for input: StatefulPartitionedCall/Preprocessor/unstack:0
[04/20/2021-01:10:02] [V] [TRT] Transpose__38 [Transpose] inputs: [StatefulPartitionedCall/Preprocessor/unstack:0 → (1, 3, 640, 640)],
[04/20/2021-01:10:02] [V] [TRT] Registering layer: Transpose__38 for ONNX node: Transpose__38
[04/20/2021-01:10:02] [V] [TRT] Registering tensor: Transpose__38:0 for ONNX tensor: Transpose__38:0
[04/20/2021-01:10:02] [V] [TRT] Transpose__38 [Transpose] outputs: [Transpose__38:0 → (1, 640, 3, 640)],
[04/20/2021-01:10:02] [V] [TRT] Parsing node: Shape__41 [Shape]
[04/20/2021-01:10:02] [V] [TRT] Searching for input: Transpose__38:0
[04/20/2021-01:10:02] [V] [TRT] Shape__41 [Shape] inputs: [Transpose__38:0 → (1, 640, 3, 640)],
[04/20/2021-01:10:02] [V] [TRT] Registering layer: Shape__41 for ONNX node: Shape__41
[04/20/2021-01:10:02] [V] [TRT] Registering tensor: Shape__41:0 for ONNX tensor: Shape__41:0
[04/20/2021-01:10:02] [V] [TRT] Shape__41 [Shape] outputs: [Shape__41:0 → (4)],
[04/20/2021-01:10:02] [V] [TRT] Parsing node: Slice__44 [Slice]
[04/20/2021-01:10:02] [V] [TRT] Searching for input: Shape__41:0
[04/20/2021-01:10:02] [V] [TRT] Searching for input: const_axes__1092
[04/20/2021-01:10:02] [V] [TRT] Searching for input: const_axes__534
[04/20/2021-01:10:02] [V] [TRT] Slice__44 [Slice] inputs: [Shape__41:0 → (4)], [const_axes__1092 → (1)], [const_axes__534 → (1)],
[04/20/2021-01:10:02] [V] [TRT] Registering layer: Slice__44 for ONNX node: Slice__44
[04/20/2021-01:10:02] [V] [TRT] Registering tensor: Slice__44:0 for ONNX tensor: Slice__44:0
[04/20/2021-01:10:02] [V] [TRT] Slice__44 [Slice] outputs: [Slice__44:0 → (2)],
[04/20/2021-01:10:02] [V] [TRT] Parsing node: Concat__46 [Concat]
[04/20/2021-01:10:02] [V] [TRT] Searching for input: Slice__44:0
[04/20/2021-01:10:02] [V] [TRT] Searching for input: const_fold_opt__1274
[04/20/2021-01:10:02] [V] [TRT] Concat__46 [Concat] inputs: [Slice__44:0 → (2)], [const_fold_opt__1274 → (2)],
[04/20/2021-01:10:02] [V] [TRT] Registering constant layer: const_fold_opt__1274 for ONNX initializer: const_fold_opt__1274
[04/20/2021-01:10:02] [V] [TRT] Registering layer: Concat__46 for ONNX node: Concat__46
[04/20/2021-01:10:02] [V] [TRT] Registering tensor: Concat__46:0 for ONNX tensor: Concat__46:0
[04/20/2021-01:10:02] [V] [TRT] Concat__46 [Concat] outputs: [Concat__46:0 → (4)],
[04/20/2021-01:10:02] [V] [TRT] Parsing node: Resize__47 [Resize]
[04/20/2021-01:10:02] [V] [TRT] Searching for input: const_empty_float__37
[04/20/2021-01:10:02] [V] [TRT] Searching for input: Concat__46:0
[04/20/2021-01:10:02] [V] [TRT] Resize__47 [Resize] inputs: [Transpose__38:0 → (1, 640, 3, 640)], [const_empty_float__37 → ()], [const_empty_float__37 → ()], [Concat__46:0 → (4)],
[04/20/2021-01:10:02] [V] [TRT] Registering layer: Resize__47 for ONNX node: Resize__47
[04/20/2021-01:10:02] [E] [TRT] /home/nano/onnx-tensorrt/ModelImporter.cpp:703: While parsing node number 8 [Resize → “Resize__47:0”]:
[04/20/2021-01:10:02] [E] [TRT] /home/nano/onnx-tensorrt/ModelImporter.cpp:704: — Begin node —
[04/20/2021-01:10:02] [E] [TRT] /home/nano/onnx-tensorrt/ModelImporter.cpp:705: input: “Transpose__38:0”
input: “const_empty_float__37”
input: “Concat__46:0”
output: “Resize__47:0”
op_type: “Resize”
attribute {
s: “asymmetric”
type: STRING
attribute {
i: 0
type: INT
attribute {
s: “linear”
type: STRING
attribute {
s: “floor”
type: STRING
[04/20/2021-01:10:02] [E] [TRT] /home/nano/onnx-tensorrt/ModelImporter.cpp:706: — End node —
[04/20/2021-01:10:02] [E] [TRT] /home/nano/onnx-tensorrt/ModelImporter.cpp:709: ERROR: /home/nano/onnx-tensorrt/builtin_op_importers.cpp:3051 In function importResize:
[8] Assertion failed: (transformationMode == “half_pixel” || transformationMode == “pytorch_half_pixel” || transformationMode == “align_corners”) && “TensorRT only supports half_pixel, pytorch_half_pixel, and align_corners transofmration modes for linear resizes when sizes are provided!”
[04/20/2021-01:10:02] [E] Failed to parse onnx file
[04/20/2021-01:10:02] [E] Parsing model failed
[04/20/2021-01:10:02] [E] Engine creation failed
[04/20/2021-01:10:02] [E] Engine set up failed
&&&& FAILED TensorRT.trtexec # /usr/src/tensorrt/bin/trtexec --onnx=/home/nano/tfobjectdetection/workspace/fp16model.onnx --verbose
