Acid_2
1
Hallo,
I have the following code…
I want to choice my stepsize so that i can reach each second value in the vector arrays over the “opt” value.
At first i think the replacement of THREAD_N by THREAD_N*2 solves my problem but
it isn’t so… what’s my fault.
__global__ void ComplexProduct(float* vector1, float* vector2, float* result, int size){
const int tid = blockDim.x * blockIdx.x + threadIdx.x;
const int THREAD_N = blockDim.x * gridDim.x;
for(int opt = tid; opt < size; opt += THREAD_N){
result[opt]=(vector1[opt]*vector2[opt]) - (vector1[opt+1]*vector2[opt+1]);
result[opt+1]=(vector1[opt+1]*vector2[opt]) + (vector2[opt+1]*vector1[opt]);
Thanks for Help
my solution was:
__global__ void Muld(float2* devMemImg2, float2* devMemMulImg, long * config)
unsigned long blockPos = threadIdx.x + IMUL(threadIdx.y, blockDim.x) + IMUL(threadIdx.z, IMUL(blockDim.x, blockDim.y));
unsigned long gridPosX = IMUL(IMUL(IMUL(blockDim.x, blockDim.y), blockDim.z), blockIdx.x);
unsigned long gridPosY = IMUL(IMUL(IMUL(IMUL(blockDim.x, blockDim.y), blockDim.z), gridDim.x), blockIdx.y);
unsigned long tid = blockPos + gridPosX + gridPosY;
float x1, x2, y1, y2;
x1 = devMemMulImg[tid].x * devMemImg2[tid].x;
y1 = devMemMulImg[tid].y * devMemImg2[tid].y;
x2 = devMemMulImg[tid].x * devMemImg2[tid].y;
y2 = devMemMulImg[tid].y * devMemImg2[tid].x;
devMemMulImg[tid].x = x1 - y1;
devMemMulImg[tid].y = x2 + y2;
or something like that…
Acid_2
3
thanks…
but my problem is that i don’t use the float2 typ…i have only float…
or now anybody a cast solution from float* to float2*
ur data is in a row major style in memory? then u can simply float2 * x = (float2*) y; (y is float*)
