Hi
I am using Tx2 to get depth image.When I compare the SGBM result from visionworks and from opencv, I find out that result from visionworks does fill the little hole with wrong pixel value. Especially when I move the camera and the noise go up.
So here is my problem, how can I set the configuration file to reduce these error filling.
Here is my configuration file.
min_disparity = 0
max_disparity = 64
P1 = 20
P2 = 120
sad = 5
bt_clip_value = 31
max_diff = 32000
uniqueness_ratio = 10
scanlines_mask = 255
flags = 2
ct_win_size = 0
hc_win_size = 1
