Continuing the discussion from Build error with isaac_ros_visual_slam:
it’s said that pulling the image should not require the ngc key, but without it, I’m running into the same issue of not being allowed to pull the image.
I’m running the run_dev.sh script btw.
I’ll test pulling the image then running the script and put an update on this post.
