STL::map
I’m new to CUDA so forgive me if my question sounds a bit stupid. Is it possible to insert new elements in a STL::map in parallel ?
Thanks,
Do
Thanks,
Do
I’ve never heard of an implementation of std::map for device code. What are you using?
I use standard C++ as much as possible, seems to work pretty well for cards with CUDA capability 2.0 and up. Basically map is an associative array from the C++ Standard Template Library.
However I’m not sure it makes sense to try to write elements in a map in parallel.
Do
Do
The STL doesn’t work in CUDA device code (host code is fine, of course), so I’m still confused.
No it wouldn’t work and there doesn’t seem to be an easy way to port existing implementations to CUDA. Just writing an allocator isn’t enough AFAICT.
