Stop the third preview in CSI camera
I’m trying to open multiple CSI cameras using the following command.
gst-launch-1.0 nvarguscamerasrc sensor_id=${1} ! 'video/x-raw(memory:NVMM), width=3840, height=2162, framerate=30/1, format=NV12' ! nvvidconv flip-method=0 ! 'video/x-raw,width=1920, height=1080' ! nvvidconv ! nvegltransform ! nveglglessink -e
At this time, the first and second preview are okay. But, the first preview window will be disappeard as soon as the third preview command runs. The followings are the log message at that time.
Setting pipeline to PAUSED ...
Using winsys: x11
Pipeline is live and does not need PREROLL ...
Got context from element 'eglglessink0': gst.egl.EGLDisplay=context, display=(GstEGLDisplay)NULL;
Setting pipeline to PLAYING ...
New clock: GstSystemClock
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected...
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 3840 x 2162 FR = 29.999999 fps Duration = 33333334 ; Analog Gain range min 1.122018, max 6.309574; Exposure Range min 16000, max 660000000;
GST_ARGUS: Running with following settings:
   Camera index = 0
   Camera mode  = 0
   Output Stream W = 3840 H = 2162
   seconds to Run    = 0
   Frame Rate = 29.999999
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
WARNING: from element /GstPipeline:pipeline0/GstEglGlesSink:eglglessink0: Pipeline construction is invalid, please add queues.
Additional debug info:
gstbasesink.c(1209): gst_base_sink_query_latency (): /GstPipeline:pipeline0/GstEglGlesSink:eglglessink0:
Not enough buffering available for  the processing deadline of 0:00:00.015000000, add enough queues to buffer  0:00:00.015000000 additional data. Shortening processing latency to 0:00:00.000000000.
WARNING: from element /GstPipeline:pipeline0/GstEglGlesSink:eglglessink0: A lot of buffers are being dropped.
gstbasesink.c(3003): gst_base_sink_is_too_late (): /GstPipeline:pipeline0/GstEglGlesSink:eglglessink0:
There may be a timestamping problem, or this computer is too slow.
CONSUMER: Done Success
Got EOS from element "pipeline0".
Execution ended after 0:00:20.114682067
Setting pipeline to NULL ...
GST_ARGUS: Cleaning up
GST_ARGUS: Done Success
Freeing pipeline ...
hello wyoung7222,
please try running argus_camera with multi-session mode. or MMAPI, 13_argus_multi_camera/.
