Storing inference results to redis with nvmsgbroker
• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 6.2
• TensorRT Version
• Issue Type( questions, new requirements, bugs) Question
Hi, I am trying to save the inference results to redis with the msg broker sink.
In order to do so, I did the followings.
  1. I followed all the instructions from this page to set up redis.
    Gst-nvmsgbroker — DeepStream 6.2 Release documentation
    Then, I created a host group named mygroup with a key named metadata.
  2. in deepstream_app_config, I set type=6 under the sink property.
    I also added the config, proto-lib, and conn-str property.
    So the entire sink property looks like this
[sink0]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File
type=6
sync=0
source-id=0
gpu-id=0
nvbuf-memory-type=0
msg-conv-config=cfg_redis.txt
msg-broker-proto-lib=/opt/nvidia/deepstream/deepstream-6.2/lib/libnvds_redis_proto.so
msg-broker-conn-str=localhost;6379
where the cfg_redis looks like this
[message-broker]
hostname=localhost
port=6379
payloadkey=metadata
consumergroup=mygroup
consumername=myname
streamsize=10000
Then, I run an app, it finishes successfully.
But it seems like it has not saved any inference results.
Am I missing something?
What do you mean? You didn’t received anything in the redis server?
Right. The server did not get the results.
Did you run with deepstream-app or deepstream-test4-app?
How did you confirm the message has been generated and sent in the client side?
