I have encountered quite confusing behavior when trying to setup a shadow ray type.
My setup here consists of: Win10, 2080ti, Cuda Toolkit 10.1, optix 6.0.0 and msvc 15.9.13 as host compiler.
The minimal complete example reads as:
Main application:
#include <iostream>
#include <vector>
#include <stdexcept>
#include <optix_world.h>
#include <optixu/optixpp_namespace.h>
int main()
const int RTX = true;
if (rtGlobalSetAttribute(RT_GLOBAL_ATTRIBUTE_ENABLE_RTX, sizeof(RTX), &RTX) != RT_SUCCESS)
throw std::runtime_error("RTX mode not available");
optix::Context ctx;
ctx = optix::Context::create();
ctx->setPrintEnabled(true);
ctx->setPrintBufferSize(4096);
ctx->setExceptionEnabled(RT_EXCEPTION_ALL, true);
ctx->setRayTypeCount(1);
ctx->setEntryPointCount(1);
ctx->setMaxTraceDepth(1);
ctx->setMaxCallableProgramDepth(1);
// scene epsilon
ctx["scene_epsilon"]->setFloat(1e-3f);
// create the material and program objects
// these programs take the entry point index as first argument
ctx->setExceptionProgram(0, ctx->createProgramFromPTXFile(PTX_FILE, "exception"));
ctx->setRayGenerationProgram(0, ctx->createProgramFromPTXFile(PTX_FILE, "create_shadow_rays"));
// these programs take the ray type as first index
ctx->setMissProgram(0, ctx->createProgramFromPTXFile(PTX_FILE, "miss_shadow"));
optix::Material scene_mat = ctx->createMaterial();
// create the graph hierarchy
optix::Group top_group = ctx->createGroup();
top_group->setAcceleration(ctx->createAcceleration("NoAccel"));
optix::GeometryGroup gg = ctx->createGeometryGroup();
gg->setAcceleration(ctx->createAcceleration("Trbvh"));
top_group->addChild(gg);
ctx["top_object"]->set(top_group);
// create scene buffers
std::vector<optix::float3> vertices = {{0.0f, -1.0f, 0.0f}, {1.0f, -1.0f, 0.0f}, {1.0f, 1.0f, 0.0f}};
optix::Buffer vertexBuffer = ctx->createBuffer(RT_BUFFER_INPUT, RT_FORMAT_FLOAT3, vertices.size());
optix::float3* buf = (optix::float3*)vertexBuffer->map();
for (int i = 0; i < vertices.size(); i++) { buf[i] = vertices[i]; }
vertexBuffer->unmap();
// create the geometry instance
auto mesh_geometry = ctx->createGeometryTriangles();
mesh_geometry->setFlagsPerMaterial(0, RT_GEOMETRY_FLAG_DISABLE_ANYHIT);
mesh_geometry->setBuildFlags(RT_GEOMETRY_BUILD_FLAG_NONE);
mesh_geometry->setVertices(vertices.size(), vertexBuffer, RT_FORMAT_FLOAT3);
mesh_geometry->setPrimitiveCount(vertices.size() / 3);
auto geom_inst = ctx->createGeometryInstance();
geom_inst->addMaterial(scene_mat);
geom_inst->setGeometryTriangles(mesh_geometry);
geom_inst["object_index"]->setInt(gg->getChildCount());
gg->addChild(geom_inst);
// create ray buffers
std::vector<optix::float3> origins = {{-1.0f, 0.0f, -1.0f}, {0.5f, -0.75f, -1.0f}};
std::vector<optix::float3> directions = {{0.0f, 0.0f, 10.0f}, {0.0f, 0.0f, 10.0f}};
optix::Buffer originsBuffer = ctx->createBuffer(RT_BUFFER_INPUT, RT_FORMAT_FLOAT3, origins.size());
optix::Buffer directionsBuffer = ctx->createBuffer(RT_BUFFER_INPUT, RT_FORMAT_FLOAT3, origins.size());
buf = (optix::float3*)originsBuffer->map();
for (int i = 0; i < origins.size(); i++) { buf[i] = origins[i]; }
originsBuffer->unmap();
buf = (optix::float3*)directionsBuffer->map();
for (int i = 0; i < directions.size(); i++) { buf[i] = directions[i]; }
directionsBuffer->unmap();
// create output buffer
optix::Buffer shadowBuffer = ctx->createBuffer(RT_BUFFER_OUTPUT, RT_FORMAT_BYTE, origins.size());
// set everything
ctx["ray_origins"]->set(originsBuffer);
ctx["ray_directions"]->set(directionsBuffer);
ctx["shadow_buffer"]->set(shadowBuffer);
// launch the entry point
ctx->validate();
ctx->launch(0, origins.size());
// retrieve results
std::vector<int> outShadows;
signed char* sBuf = (signed char*)shadowBuffer->map();
for (int i = 0; i < origins.size(); i++) { outShadows.push_back(sBuf[i]); }
shadowBuffer->unmap();
std::cout << outShadows[0] << ", " << outShadows[1] << std::endl;
ctx->destroy();
return 0;
Optix Kernels:
#include <optix_device.h>
#include <optixu/optixu_math_namespace.h>
using namespace optix;
struct ShadowRayData
optix::char1 inShadow;
// globals per context
rtDeclareVariable(float, scene_epsilon, , "Scene epsilon for tracing");
rtDeclareVariable(unsigned int, launch_index, rtLaunchIndex, );
rtDeclareVariable(rtObject, top_object, , );
// per ray variables
rtDeclareVariable(ShadowRayData, prd_shadow, rtPayload, );
// input buffer from ray struct
rtBuffer<float3, 1> ray_origins;
rtBuffer<float3, 1> ray_directions;
// ouptut buffer for shadow rays
rtBuffer<optix::char1, 1> shadow_buffer;
// Creates rays from given buffer objects
RT_PROGRAM void create_shadow_rays(void)
// UNCOMMENTING THIS PRINTF CHANGES THE OUTPUT
// rtPrintf("Hello from %u, creating shadow ray at: (%f, %f, %f)\n",
// launch_index,
// ray_origins[launch_index].x,
// ray_origins[launch_index].y,
// ray_origins[launch_index].z);
Ray r(ray_origins[launch_index],
normalize(ray_directions[launch_index]),
0,
0.0f,
length(ray_directions[launch_index]) - scene_epsilon);
ShadowRayData shd;
shd.inShadow = optix::make_char1(1);
rtTrace(top_object,
r,
shd,
RT_VISIBILITY_ALL,
(RTrayflags)(RT_RAY_FLAG_DISABLE_CLOSESTHIT | RT_RAY_FLAG_TERMINATE_ON_FIRST_HIT));
// copy values back to output buffers
shadow_buffer[launch_index] = shd.inShadow;
RT_PROGRAM void miss_shadow(void)
rtPrintf("Hello from %u, in miss shadow\n", launch_index);
prd_shadow.inShadow = optix::make_char1(2);
// Exception program
RT_PROGRAM void exception(void)
rtPrintExceptionDetails();
shadow_buffer[launch_index] = optix::make_char1(-1);
CMakeLists.txt to tie everything together:
cmake_minimum_required(VERSION 3.9)
set(CMAKE_CXX_STANDARD 14)
set(CMAKE_CXX_STANDARD_REQUIRED ON)
project(cuda_raytracer LANGUAGES CXX CUDA)
# For find OptiX.cmake
list(APPEND CMAKE_MODULE_PATH "${CMAKE_SOURCE_DIR}/cmake/")
# FindOptiX.cmake sets imported targets
find_package(OptiX REQUIRED)
add_library(optixIntersect OBJECT ray_programs.cu)
set_property(TARGET optixIntersect PROPERTY CUDA_PTX_COMPILATION ON)
target_link_libraries(optixIntersect optix optixu)
# install the binaries
install(FILES $<TARGET_OBJECTS:optixIntersect> DESTINATION "${CMAKE_SOURCE_DIR}")
# tests
add_executable(intersect_test intersect_test.cu)
target_link_libraries(intersect_test optix optixu)
target_compile_definitions(intersect_test PRIVATE PTX_FILE=\"${CMAKE_SOURCE_DIR}/ray_programs.ptx\")
My confusion is mainly due to the fact, that uncommenting the first
rtPrintf
in
create_shadow_rays
changes the result to the expected output, i.e. from
1 1
to
2 1
Any ideas?
