we have compiled the following simple code with PGI Fortran 17.10:
program prova
implicit none
real(8) a(4)
real(8) x
real(8) b
real(8) c
integer(4) j
a=2.
x=0.d0
b=1.d-3
c=3.
DO J=1,4
x=a(j)*b+c
ENDDO
WRITE(6,*) x
STOP
END
The code run correctly on Desktop PC running Windows from 7 to 10.
The same executable fails on WinSrv2012, giving the following error:
Problem signature:
Problem Event Name: APPCRASH
Application Name: prova.exe
Application Version: 0.0.0.0
Application Timestamp: 5bd07bce
Fault Module Name: prova.exe
Fault Module Version: 0.0.0.0
Fault Module Timestamp: 5bd07bce
Exception Code: c000001d
Exception Offset: 000000000000116b
OS Version: 6.3.9600.2.0.0.272.7
Locale ID: 1033
Additional Information 1: 17e0
Additional Information 2: 17e0329eab0c93a7e9658d6bb0d608f0
Additional Information 3: a283
Additional Information 4: a2831258489be3f056d5a8b3fdd99b1b
The same code run correctly if the variable b is initialized to 1. instead of 1.d-3.
Do you know how to fix this problem?
Thank you
