Here is my Xorg.0.log.
My resolution is 1280x768.
Please give me a hint what’s going wrong.
[ 37.740]
X.Org X Server 1.13.3
Release Date: 2013-03-07
[ 37.740] X Protocol Version 11, Revision 0
[ 37.740] Build Operating System: Linux 3.2.0-37-generic i686 Ubuntu
[ 37.740] Current Operating System: Linux kirk-x 3.8.0-25-generic #37-Ubuntu SMP Thu Jun 6 20:47:30 UTC 2013 i686
[ 37.740] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.8.0-25-generic root=UUID=bd998f68-c04e-435b-9927-c1094553c63f ro quiet splash vt.handoff=7
[ 37.741] Build Date: 17 April 2013 10:42:56PM
[ 37.741] xorg-server 2:1.13.3-0ubuntu6 (For technical support please see http://www.ubuntu.com/support)
[ 37.741] Current version of pixman: 0.28.2
[ 37.741] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 37.741] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 37.741] (==) Log file: "/var/log/Xorg.0.log", Time: Thu Oct 10 18:11:17 2013
[ 37.750] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 37.751] (==) No Layout section. Using the first Screen section.
[ 37.751] (==) No screen section available. Using defaults.
[ 37.751] (**) |-->Screen "Default Screen Section" (0)
[ 37.751] (**) | |-->Monitor "<default monitor>"
[ 37.751] (==) No monitor specified for screen "Default Screen Section".
Using a default monitor configuration.
[ 37.751] (==) Automatically adding devices
[ 37.751] (==) Automatically enabling devices
[ 37.751] (==) Automatically adding GPU devices
[ 37.751] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 37.751] Entry deleted from font path.
[ 37.751] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[ 37.751] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[ 37.751] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[ 37.751] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[ 37.751] (WW) The directory "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType" does not exist.
[ 37.751] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
built-ins
[ 37.751] (==) ModulePath set to "/usr/lib/i386-linux-gnu/xorg/extra-modules,/usr/lib/xorg/extra-modules,/usr/lib/xorg/modules"
[ 37.751] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 37.752] (II) Loader magic: 0xb77566a0
[ 37.752] (II) Module ABI versions:
[ 37.752] X.Org ANSI C Emulation: 0.4
[ 37.752] X.Org Video Driver: 13.1
[ 37.752] X.Org XInput driver : 18.0
[ 37.752] X.Org Server Extension : 7.0
[ 37.752] (II) config/udev: Adding drm device (/dev/dri/card0)
[ 37.754] (--) PCI:*(0:2:0:0) 10de:0312:1043:80fb rev 161, Mem @ 0xe8000000/16777216, 0xd0000000/268435456, BIOS @ 0x????????/131072
[ 37.754] (II) Open ACPI successful (/var/run/acpid.socket)
[ 37.754] Initializing built-in extension Generic Event Extension
[ 37.754] Initializing built-in extension SHAPE
[ 37.754] Initializing built-in extension MIT-SHM
[ 37.754] Initializing built-in extension XInputExtension
[ 37.754] Initializing built-in extension XTEST
[ 37.755] Initializing built-in extension BIG-REQUESTS
[ 37.755] Initializing built-in extension SYNC
[ 37.755] Initializing built-in extension XKEYBOARD
[ 37.755] Initializing built-in extension XC-MISC
[ 37.755] Initializing built-in extension SECURITY
[ 37.755] Initializing built-in extension XINERAMA
[ 37.755] Initializing built-in extension XFIXES
[ 37.755] Initializing built-in extension RENDER
[ 37.755] Initializing built-in extension RANDR
[ 37.755] Initializing built-in extension COMPOSITE
[ 37.755] Initializing built-in extension DAMAGE
[ 37.755] Initializing built-in extension MIT-SCREEN-SAVER
[ 37.755] Initializing built-in extension DOUBLE-BUFFER
[ 37.755] Initializing built-in extension RECORD
[ 37.755] Initializing built-in extension DPMS
[ 37.755] Initializing built-in extension X-Resource
[ 37.755] Initializing built-in extension XVideo
[ 37.755] Initializing built-in extension XVideo-MotionCompensation
[ 37.755] Initializing built-in extension SELinux
[ 37.755] Initializing built-in extension XFree86-VidModeExtension
[ 37.755] Initializing built-in extension XFree86-DGA
[ 37.755] Initializing built-in extension XFree86-DRI
[ 37.755] Initializing built-in extension DRI2
[ 37.755] (II) LoadModule: "glx"
[ 37.782] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 37.782] (II) Module glx: vendor="X.Org Foundation"
[ 37.782] compiled for 1.13.3, module version = 1.0.0
[ 37.782] ABI class: X.Org Server Extension, version 7.0
[ 37.782] (==) AIGLX enabled
[ 37.782] Loading extension GLX
[ 37.782] (==) Matched nvidia as autoconfigured driver 0
[ 37.782] (==) Matched nouveau as autoconfigured driver 1
[ 37.782] (==) Matched nvidia as autoconfigured driver 2
[ 37.782] (==) Matched nouveau as autoconfigured driver 3
[ 37.782] (==) Matched vesa as autoconfigured driver 4
[ 37.782] (==) Matched modesetting as autoconfigured driver 5
[ 37.782] (==) Matched fbdev as autoconfigured driver 6
[ 37.782] (==) Assigned the driver to the xf86ConfigLayout
[ 37.782] (II) LoadModule: "nvidia"
[ 37.783] (WW) Warning, couldn't open module nvidia
[ 37.783] (II) UnloadModule: "nvidia"
[ 37.783] (II) Unloading nvidia
[ 37.783] (EE) Failed to load module "nvidia" (module does not exist, 0)
[ 37.783] (II) LoadModule: "nouveau"
[ 37.783] (II) Loading /usr/lib/xorg/modules/drivers/nouveau_drv.so
[ 37.801] (II) Module nouveau: vendor="X.Org Foundation"
[ 37.801] compiled for 1.13.3, module version = 1.0.7
[ 37.801] Module class: X.Org Video Driver
[ 37.801] ABI class: X.Org Video Driver, version 13.1
[ 37.801] (II) LoadModule: "vesa"
[ 37.802] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[ 37.802] (II) Module vesa: vendor="X.Org Foundation"
[ 37.802] compiled for 1.12.99.902, module version = 2.3.2
[ 37.802] Module class: X.Org Video Driver
[ 37.802] ABI class: X.Org Video Driver, version 13.0
[ 37.802] (II) LoadModule: "modesetting"
[ 37.802] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 37.802] (II) Module modesetting: vendor="X.Org Foundation"
[ 37.802] compiled for 1.13.3, module version = 0.7.0
[ 37.802] ABI class: X.Org Video Driver, version 13.1
[ 37.802] (II) LoadModule: "fbdev"
[ 37.803] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 37.803] (II) Module fbdev: vendor="X.Org Foundation"
[ 37.803] compiled for 1.12.99.902, module version = 0.4.3
[ 37.803] Module class: X.Org Video Driver
[ 37.803] ABI class: X.Org Video Driver, version 13.0
[ 37.803] (==) Matched nvidia as autoconfigured driver 0
[ 37.803] (==) Matched nouveau as autoconfigured driver 1
[ 37.803] (==) Matched nvidia as autoconfigured driver 2
[ 37.803] (==) Matched nouveau as autoconfigured driver 3
[ 37.803] (==) Matched vesa as autoconfigured driver 4
[ 37.803] (==) Matched modesetting as autoconfigured driver 5
[ 37.803] (==) Matched fbdev as autoconfigured driver 6
[ 37.803] (==) Assigned the driver to the xf86ConfigLayout
[ 37.803] (II) LoadModule: "nvidia"
[ 37.804] (WW) Warning, couldn't open module nvidia
[ 37.804] (II) UnloadModule: "nvidia"
[ 37.804] (II) Unloading nvidia
[ 37.804] (EE) Failed to load module "nvidia" (module does not exist, 0)
[ 37.804] (II) LoadModule: "nouveau"
[ 37.804] (II) Loading /usr/lib/xorg/modules/drivers/nouveau_drv.so
[ 37.804] (II) Module nouveau: vendor="X.Org Foundation"
[ 37.804] compiled for 1.13.3, module version = 1.0.7
[ 37.804] Module class: X.Org Video Driver
[ 37.804] ABI class: X.Org Video Driver, version 13.1
[ 37.804] (II) UnloadModule: "nouveau"
[ 37.804] (II) Unloading nouveau
[ 37.804] (II) Failed to load module "nouveau" (already loaded, 0)
[ 37.804] (II) LoadModule: "vesa"
[ 37.805] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[ 37.805] (II) Module vesa: vendor="X.Org Foundation"
[ 37.805] compiled for 1.12.99.902, module version = 2.3.2
[ 37.805] Module class: X.Org Video Driver
[ 37.805] ABI class: X.Org Video Driver, version 13.0
[ 37.805] (II) UnloadModule: "vesa"
[ 37.805] (II) Unloading vesa
[ 37.805] (II) Failed to load module "vesa" (already loaded, 0)
[ 37.805] (II) LoadModule: "modesetting"
[ 37.805] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 37.805] (II) Module modesetting: vendor="X.Org Foundation"
[ 37.805] compiled for 1.13.3, module version = 0.7.0
[ 37.805] ABI class: X.Org Video Driver, version 13.1
[ 37.805] (II) UnloadModule: "modesetting"
[ 37.805] (II) Unloading modesetting
[ 37.805] (II) Failed to load module "modesetting" (already loaded, 0)
[ 37.805] (II) LoadModule: "fbdev"
[ 37.806] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 37.806] (II) Module fbdev: vendor="X.Org Foundation"
[ 37.806] compiled for 1.12.99.902, module version = 0.4.3
[ 37.806] Module class: X.Org Video Driver
[ 37.806] ABI class: X.Org Video Driver, version 13.0
[ 37.806] (II) UnloadModule: "fbdev"
[ 37.806] (II) Unloading fbdev
[ 37.806] (II) Failed to load module "fbdev" (already loaded, 0)
[ 37.806] (II) NOUVEAU driver Date: Wed Mar 27 09:50:03 2013 +0100
[ 37.806] (II) NOUVEAU driver for NVIDIA chipset families :
[ 37.806] RIVA TNT (NV04)
[ 37.806] RIVA TNT2 (NV05)
[ 37.806] GeForce 256 (NV10)
[ 37.806] GeForce 2 (NV11, NV15)
[ 37.806] GeForce 4MX (NV17, NV18)
[ 37.806] GeForce 3 (NV20)
[ 37.806] GeForce 4Ti (NV25, NV28)
[ 37.806] GeForce FX (NV3x)
[ 37.806] GeForce 6 (NV4x)
[ 37.806] GeForce 7 (G7x)
[ 37.806] GeForce 8 (G8x)
[ 37.806] GeForce GTX 200 (NVA0)
[ 37.806] GeForce GTX 400 (NVC0)
[ 37.806] (II) VESA: driver for VESA chipsets: vesa
[ 37.806] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 37.806] (II) FBDEV: driver for framebuffer: fbdev
[ 37.806] (++) using VT number 7
[ 37.808] (II) [drm] nouveau interface version: 1.1.0
[ 37.808] (WW) Falling back to old probe method for vesa
[ 37.808] (WW) Falling back to old probe method for modesetting
[ 37.808] (WW) Falling back to old probe method for fbdev
[ 37.808] (II) Loading sub module "fbdevhw"
[ 37.808] (II) LoadModule: "fbdevhw"
[ 37.809] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 37.809] (II) Module fbdevhw: vendor="X.Org Foundation"
[ 37.809] compiled for 1.13.3, module version = 0.0.2
[ 37.809] ABI class: X.Org Video Driver, version 13.1
[ 37.809] (II) Loading sub module "dri"
[ 37.809] (II) LoadModule: "dri"
[ 37.809] (II) Module "dri" already built-in
[ 37.809] (II) NOUVEAU(0): Loaded DRI module
[ 37.809] (--) NOUVEAU(0): Chipset: "NVIDIA NV31"
[ 37.809] (II) NOUVEAU(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 37.809] (==) NOUVEAU(0): Depth 24, (--) framebuffer bpp 32
[ 37.809] (==) NOUVEAU(0): RGB weight 888
[ 37.809] (==) NOUVEAU(0): Default visual is TrueColor
[ 37.809] (==) NOUVEAU(0): Using HW cursor
[ 37.809] (==) NOUVEAU(0): GLX sync to VBlank enabled.
[ 37.809] (==) NOUVEAU(0): Page flipping enabled
[ 37.809] (==) NOUVEAU(0): Swap limit set to 2 [Max allowed 2]
[ 37.864] (II) NOUVEAU(0): Output VGA-1 has no monitor section
[ 37.896] (II) NOUVEAU(0): Output DVI-I-1 has no monitor section
[ 37.952] (II) NOUVEAU(0): Output TV-1 has no monitor section
[ 38.008] (II) NOUVEAU(0): EDID for output VGA-1
[ 38.040] (II) NOUVEAU(0): EDID for output DVI-I-1
[ 38.040] (II) NOUVEAU(0): Manufacturer: PHL Model: 4650 Serial#: 16843009
[ 38.040] (II) NOUVEAU(0): Year: 2003 Week: 50
[ 38.040] (II) NOUVEAU(0): EDID Version: 1.3
[ 38.040] (II) NOUVEAU(0): Digital Display Input
[ 38.040] (II) NOUVEAU(0): Max Image Size [cm]: horiz.: 70 vert.: 39
[ 38.040] (II) NOUVEAU(0): Gamma: 2.20
[ 38.040] (II) NOUVEAU(0): DPMS capabilities: StandBy
[ 38.040] (II) NOUVEAU(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[ 38.040] (II) NOUVEAU(0): First detailed timing not preferred mode in violation of standard!
[ 38.040] (II) NOUVEAU(0): redX: 0.617 redY: 0.334 greenX: 0.283 greenY: 0.590
[ 38.040] (II) NOUVEAU(0): blueX: 0.143 blueY: 0.086 whiteX: 0.284 whiteY: 0.295
[ 38.040] (II) NOUVEAU(0): Supported established timings:
[ 38.040] (II) NOUVEAU(0): 720x400@70Hz
[ 38.040] (II) NOUVEAU(0): 640x480@60Hz
[ 38.040] (II) NOUVEAU(0): 640x480@67Hz
[ 38.040] (II) NOUVEAU(0): 640x480@72Hz
[ 38.040] (II) NOUVEAU(0): 640x480@75Hz
[ 38.040] (II) NOUVEAU(0): 800x600@56Hz
[ 38.040] (II) NOUVEAU(0): 800x600@60Hz
[ 38.040] (II) NOUVEAU(0): 800x600@72Hz
[ 38.040] (II) NOUVEAU(0): 800x600@75Hz
[ 38.040] (II) NOUVEAU(0): 832x624@75Hz
[ 38.040] (II) NOUVEAU(0): 1024x768@60Hz
[ 38.040] (II) NOUVEAU(0): 1024x768@70Hz
[ 38.040] (II) NOUVEAU(0): 1024x768@75Hz
[ 38.040] (II) NOUVEAU(0): 1280x1024@75Hz
[ 38.040] (II) NOUVEAU(0): Manufacturer's mask: 0
[ 38.040] (II) NOUVEAU(0): Supported standard timings:
[ 38.040] (II) NOUVEAU(0): #0: hsize: 640 vsize 360 refresh: 85 vid: 55601
[ 38.040] (II) NOUVEAU(0): #1: hsize: 800 vsize 450 refresh: 85 vid: 55621
[ 38.040] (II) NOUVEAU(0): #2: hsize: 1024 vsize 576 refresh: 85 vid: 55649
[ 38.040] (II) NOUVEAU(0): #3: hsize: 1152 vsize 648 refresh: 75 vid: 53105
[ 38.040] (II) NOUVEAU(0): #4: hsize: 1280 vsize 720 refresh: 60 vid: 49281
[ 38.040] (II) NOUVEAU(0): #5: hsize: 1280 vsize 720 refresh: 60 vid: 49281
[ 38.040] (II) NOUVEAU(0): Supported detailed timing:
[ 38.040] (II) NOUVEAU(0): clock: 69.0 MHz Image Size: 698 x 393 mm
[ 38.040] (II) NOUVEAU(0): h_active: 1280 h_sync: 1280 h_sync_end 1300 h_blank_end 1424 h_border: 0
[ 38.040] (II) NOUVEAU(0): v_active: 768 v_sync: 769 v_sync_end 775 v_blanking: 812 v_border: 0
[ 38.040] (II) NOUVEAU(0): Serial No:
[ 38.040] (II) NOUVEAU(0): Monitor name: DVI TV
[ 38.040] (II) NOUVEAU(0): Ranges: V min: 47 V max: 85 Hz, H min: 31 H max: 80 kHz, PixClock max 145 MHz
[ 38.041] (II) NOUVEAU(0): EDID (in hex):
[ 38.041] (II) NOUVEAU(0): 00ffffffffffff00410c504601010101
[ 38.041] (II) NOUVEAU(0): 320d01038046277888288e9e55489724
[ 38.041] (II) NOUVEAU(0): 16484bbfef0031d945d961d971cf81c0
[ 38.041] (II) NOUVEAU(0): 81c001c101c1f41a009050002c300014
[ 38.041] (II) NOUVEAU(0): 1600ba8921000018000000ff00202020
[ 38.041] (II) NOUVEAU(0): 20202020202020202020000000fc0044
[ 38.041] (II) NOUVEAU(0): 56492054560a202020202020000000fd
[ 38.041] (II) NOUVEAU(0): 002f551f500e000a202020202020007a
[ 38.041] (II) NOUVEAU(0): Printing probed modes for output DVI-I-1
[ 38.041] (II) NOUVEAU(0): Modeline "1280x1024"x75.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 38.041] (II) NOUVEAU(0): Modeline "1280x768"x59.7 69.00 1280 1280 1300 1424 768 769 775 812 -hsync -vsync (48.5 kHz e)
[ 38.041] (II) NOUVEAU(0): Modeline "1280x720"x60.0 74.44 1280 1336 1472 1664 720 721 724 746 -hsync +vsync (44.7 kHz)
[ 38.041] (II) NOUVEAU(0): Modeline "1024x768"x75.1 78.80 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.1 kHz e)
[ 38.041] (II) NOUVEAU(0): Modeline "1024x768"x70.1 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz e)
[ 38.041] (II) NOUVEAU(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 38.041] (II) NOUVEAU(0): Modeline "1152x648"x75.0 77.19 1152 1216 1336 1520 648 649 652 677 -hsync +vsync (50.8 kHz)
[ 38.041] (II) NOUVEAU(0): Modeline "1024x576"x85.1 69.17 1024 1080 1184 1344 576 577 580 605 -hsync +vsync (51.5 kHz)
[ 38.041] (II) NOUVEAU(0): Modeline "832x624"x74.6 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz e)
[ 38.041] (II) NOUVEAU(0): Modeline "800x600"x72.2 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz e)
[ 38.041] (II) NOUVEAU(0): Modeline "800x600"x75.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 38.041] (II) NOUVEAU(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 38.041] (II) NOUVEAU(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz e)
[ 38.041] (II) NOUVEAU(0): Modeline "800x450"x85.0 41.83 800 840 920 1040 450 451 454 473 -hsync +vsync (40.2 kHz)
[ 38.041] (II) NOUVEAU(0): Modeline "640x480"x72.8 31.50 640 664 704 832 480 489 491 520 -hsync -vsync (37.9 kHz e)
[ 38.041] (II) NOUVEAU(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 38.041] (II) NOUVEAU(0): Modeline "640x480"x66.7 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz e)
[ 38.041] (II) NOUVEAU(0): Modeline "640x480"x60.0 25.20 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 38.041] (II) NOUVEAU(0): Modeline "720x400"x70.1 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 38.041] (II) NOUVEAU(0): Modeline "640x360"x85.0 25.76 640 656 720 800 360 361 364 379 -hsync +vsync (32.2 kHz)
[ 38.096] (II) NOUVEAU(0): EDID for output TV-1
[ 38.096] (II) NOUVEAU(0): Output VGA-1 disconnected
[ 38.096] (II) NOUVEAU(0): Output DVI-I-1 connected
[ 38.096] (II) NOUVEAU(0): Output TV-1 disconnected
[ 38.096] (II) NOUVEAU(0): Using exact sizes for initial modes
[ 38.096] (II) NOUVEAU(0): Output DVI-I-1 using initial mode 1280x720
[ 38.096] (II) NOUVEAU(0): Using default gamma of (1.0, 1.0, 1.0) unless otherwise stated.
[ 38.096] (--) NOUVEAU(0): Virtual size is 1280x720 (pitch 0)
[ 38.096] (**) NOUVEAU(0): Mode "1280x720": 74.4 MHz (scaled from 0.0 MHz), 44.7 kHz, 60.0 Hz
[ 38.096] (II) NOUVEAU(0): Modeline "1280x720"x60.0 74.44 1280 1336 1472 1664 720 721 724 746 -hsync +vsync (44.7 kHz)
[ 38.096] (**) NOUVEAU(0): Driver mode "1024x768": 78.8 MHz (scaled from 0.0 MHz), 60.1 kHz, 75.1 Hz
[ 38.096] (II) NOUVEAU(0): Modeline "1024x768"x75.1 78.80 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.1 kHz e)
[ 38.096] (**) NOUVEAU(0): Driver mode "1024x768": 75.0 MHz (scaled from 0.0 MHz), 56.5 kHz, 70.1 Hz
[ 38.096] (II) NOUVEAU(0): Modeline "1024x768"x70.1 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz e)
[ 38.096] (**) NOUVEAU(0): Driver mode "1024x768": 65.0 MHz (scaled from 0.0 MHz), 48.4 kHz, 60.0 Hz
[ 38.096] (II) NOUVEAU(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 38.096] (**) NOUVEAU(0): Mode "1152x648": 77.2 MHz (scaled from 0.0 MHz), 50.8 kHz, 75.0 Hz
[ 38.096] (II) NOUVEAU(0): Modeline "1152x648"x75.0 77.19 1152 1216 1336 1520 648 649 652 677 -hsync +vsync (50.8 kHz)
[ 38.096] (**) NOUVEAU(0): Mode "1024x576": 69.2 MHz (scaled from 0.0 MHz), 51.5 kHz, 85.1 Hz
[ 38.096] (II) NOUVEAU(0): Modeline "1024x576"x85.1 69.17 1024 1080 1184 1344 576 577 580 605 -hsync +vsync (51.5 kHz)
[ 38.096] (**) NOUVEAU(0): Driver mode "832x624": 57.3 MHz (scaled from 0.0 MHz), 49.7 kHz, 74.6 Hz
[ 38.096] (II) NOUVEAU(0): Modeline "832x624"x74.6 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz e)
[ 38.096] (**) NOUVEAU(0): Driver mode "800x600": 50.0 MHz (scaled from 0.0 MHz), 48.1 kHz, 72.2 Hz
[ 38.096] (II) NOUVEAU(0): Modeline "800x600"x72.2 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz e)
[ 38.096] (**) NOUVEAU(0): Driver mode "800x600": 49.5 MHz (scaled from 0.0 MHz), 46.9 kHz, 75.0 Hz
[ 38.096] (II) NOUVEAU(0): Modeline "800x600"x75.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 38.096] (**) NOUVEAU(0): Driver mode "800x600": 40.0 MHz (scaled from 0.0 MHz), 37.9 kHz, 60.3 Hz
[ 38.096] (II) NOUVEAU(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 38.096] (**) NOUVEAU(0): Driver mode "800x600": 36.0 MHz (scaled from 0.0 MHz), 35.2 kHz, 56.2 Hz
[ 38.096] (II) NOUVEAU(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz e)
[ 38.096] (**) NOUVEAU(0): Mode "800x450": 41.8 MHz (scaled from 0.0 MHz), 40.2 kHz, 85.0 Hz
[ 38.096] (II) NOUVEAU(0): Modeline "800x450"x85.0 41.83 800 840 920 1040 450 451 454 473 -hsync +vsync (40.2 kHz)
[ 38.096] (**) NOUVEAU(0): Driver mode "640x480": 31.5 MHz (scaled from 0.0 MHz), 37.9 kHz, 72.8 Hz
[ 38.096] (II) NOUVEAU(0): Modeline "640x480"x72.8 31.50 640 664 704 832 480 489 491 520 -hsync -vsync (37.9 kHz e)
[ 38.096] (**) NOUVEAU(0): Driver mode "640x480": 31.5 MHz (scaled from 0.0 MHz), 37.5 kHz, 75.0 Hz
[ 38.096] (II) NOUVEAU(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 38.096] (**) NOUVEAU(0): Driver mode "640x480": 30.2 MHz (scaled from 0.0 MHz), 35.0 kHz, 66.7 Hz
[ 38.096] (II) NOUVEAU(0): Modeline "640x480"x66.7 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz e)
[ 38.096] (**) NOUVEAU(0): Driver mode "640x480": 25.2 MHz (scaled from 0.0 MHz), 31.5 kHz, 60.0 Hz
[ 38.096] (II) NOUVEAU(0): Modeline "640x480"x60.0 25.20 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 38.096] (**) NOUVEAU(0): Driver mode "720x400": 28.3 MHz (scaled from 0.0 MHz), 31.5 kHz, 70.1 Hz
[ 38.096] (II) NOUVEAU(0): Modeline "720x400"x70.1 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 38.096] (**) NOUVEAU(0): Mode "640x360": 25.8 MHz (scaled from 0.0 MHz), 32.2 kHz, 85.0 Hz
[ 38.096] (II) NOUVEAU(0): Modeline "640x360"x85.0 25.76 640 656 720 800 360 361 364 379 -hsync +vsync (32.2 kHz)
[ 38.096] (**) NOUVEAU(0): Driver mode "1280x1024": 135.0 MHz (scaled from 0.0 MHz), 80.0 kHz, 75.0 Hz
[ 38.096] (II) NOUVEAU(0): Modeline "1280x1024"x75.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 38.096] (**) NOUVEAU(0): Driver mode "1280x768": 69.0 MHz (scaled from 0.0 MHz), 48.5 kHz, 59.7 Hz
[ 38.096] (II) NOUVEAU(0): Modeline "1280x768"x59.7 69.00 1280 1280 1300 1424 768 769 775 812 -hsync -vsync (48.5 kHz e)
[ 38.096] (==) NOUVEAU(0): DPI set to (96, 96)
[ 38.096] (II) Loading sub module "fb"
[ 38.096] (II) LoadModule: "fb"
[ 38.097] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 38.097] (II) Module fb: vendor="X.Org Foundation"
[ 38.097] compiled for 1.13.3, module version = 1.0.0
[ 38.097] ABI class: X.Org ANSI C Emulation, version 0.4
[ 38.097] (II) Loading sub module "exa"
[ 38.097] (II) LoadModule: "exa"
[ 38.097] (II) Loading /usr/lib/xorg/modules/libexa.so
[ 38.097] (II) Module exa: vendor="X.Org Foundation"
[ 38.097] compiled for 1.13.3, module version = 2.6.0
[ 38.097] ABI class: X.Org Video Driver, version 13.1
[ 38.098] (II) Loading sub module "shadowfb"
[ 38.098] (II) LoadModule: "shadowfb"
[ 38.098] (II) Loading /usr/lib/xorg/modules/libshadowfb.so
[ 38.098] (II) Module shadowfb: vendor="X.Org Foundation"
[ 38.098] compiled for 1.13.3, module version = 1.0.0
[ 38.098] ABI class: X.Org ANSI C Emulation, version 0.4
[ 38.098] (II) UnloadModule: "vesa"
[ 38.098] (II) Unloading vesa
[ 38.098] (II) UnloadModule: "modesetting"
[ 38.098] (II) Unloading modesetting
[ 38.098] (II) UnloadModule: "fbdev"
[ 38.098] (II) Unloading fbdev
[ 38.098] (II) UnloadSubModule: "fbdevhw"
[ 38.098] (II) Unloading fbdevhw
[ 38.098] (--) Depth 24 pixmap format is 32 bpp
[ 38.099] (II) NOUVEAU(0): Opened GPU channel 0
[ 38.100] (II) NOUVEAU(0): [DRI2] Setup complete
[ 38.101] (II) NOUVEAU(0): [DRI2] DRI driver: nouveau
[ 38.101] (II) NOUVEAU(0): [DRI2] VDPAU driver: nouveau
[ 38.101] (II) EXA(0): Driver allocated offscreen pixmaps
[ 38.101] (II) EXA(0): Driver registered support for the following operations:
[ 38.101] (II) Solid
[ 38.101] (II) Copy
[ 38.101] (II) Composite (RENDER acceleration)
[ 38.101] (II) UploadToScreen
[ 38.101] (II) DownloadFromScreen
[ 38.101] (==) NOUVEAU(0): Backing store disabled
[ 38.101] (==) NOUVEAU(0): Silken mouse enabled
[ 38.101] (II) NOUVEAU(0): [XvMC] Associated with NV30 texture adapter.
[ 38.101] (II) NOUVEAU(0): [XvMC] Extension initialized.
[ 38.101] (==) NOUVEAU(0): DPMS enabled
[ 38.101] (II) NOUVEAU(0): RandR 1.2 enabled, ignore the following RandR disabled message.
[ 38.102] (--) RandR disabled
[ 38.114] (II) SELinux: Disabled on system
[ 38.467] (II) AIGLX: enabled GLX_MESA_copy_sub_buffer
[ 38.467] (II) AIGLX: enabled GLX_INTEL_swap_event
[ 38.467] (II) AIGLX: enabled GLX_ARB_create_context
[ 38.467] (II) AIGLX: enabled GLX_ARB_create_context_profile
[ 38.467] (II) AIGLX: enabled GLX_EXT_create_context_es2_profile
[ 38.467] (II) AIGLX: enabled GLX_SGI_swap_control and GLX_MESA_swap_control
[ 38.467] (II) AIGLX: GLX_EXT_texture_from_pixmap backed by buffer objects
[ 38.468] (II) AIGLX: Loaded and initialized nouveau
[ 38.468] (II) GLX: Initialized DRI2 GL provider for screen 0
[ 38.471] (II) NOUVEAU(0): NVEnterVT is called.
[ 38.492] (II) NOUVEAU(0): Setting screen physical size to 338 x 190
[ 38.492] resize called 1280 720
[ 38.507] (II) XKB: reuse xkmfile /var/lib/xkb/server-B20D7FC79C7F597315E3E501AEF10E0D866E8E92.xkm
[ 38.512] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 38.512] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 38.512] (II) LoadModule: "evdev"
[ 38.513] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 38.522] (II) Module evdev: vendor="X.Org Foundation"
[ 38.522] compiled for 1.13.3, module version = 2.7.3
[ 38.522] Module class: X.Org XInput Driver
[ 38.522] ABI class: X.Org XInput driver, version 18.0
[ 38.522] (II) Using input driver 'evdev' for 'Power Button'
[ 38.522] (**) Power Button: always reports core events
[ 38.522] (**) evdev: Power Button: Device: "/dev/input/event1"
[ 38.523] (--) evdev: Power Button: Vendor 0 Product 0x1
[ 38.523] (--) evdev: Power Button: Found keys
[ 38.523] (II) evdev: Power Button: Configuring as keyboard
[ 38.523] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
[ 38.523] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 38.523] (**) Option "xkb_rules" "evdev"
[ 38.523] (**) Option "xkb_model" "pc105"
[ 38.523] (**) Option "xkb_layout" "at"
[ 38.527] (II) XKB: reuse xkmfile /var/lib/xkb/server-11CCA49F19D9E93AF6B2C65E09D15B710633D292.xkm
[ 38.528] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[ 38.528] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 38.528] (II) Using input driver 'evdev' for 'Power Button'
[ 38.528] (**) Power Button: always reports core events
[ 38.528] (**) evdev: Power Button: Device: "/dev/input/event0"
[ 38.528] (--) evdev: Power Button: Vendor 0 Product 0x1
[ 38.528] (--) evdev: Power Button: Found keys
[ 38.528] (II) evdev: Power Button: Configuring as keyboard
[ 38.529] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[ 38.529] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[ 38.529] (**) Option "xkb_rules" "evdev"
[ 38.529] (**) Option "xkb_model" "pc105"
[ 38.529] (**) Option "xkb_layout" "at"
[ 38.530] (II) config/udev: Adding input device Microsoft Microsoft® 2.4GHz Transceiver v8.0 (/dev/input/event2)
[ 38.530] (**) Microsoft Microsoft® 2.4GHz Transceiver v8.0: Applying InputClass "evdev keyboard catchall"
[ 38.530] (II) Using input driver 'evdev' for 'Microsoft Microsoft® 2.4GHz Transceiver v8.0'
[ 38.530] (**) Microsoft Microsoft® 2.4GHz Transceiver v8.0: always reports core events
[ 38.530] (**) evdev: Microsoft Microsoft® 2.4GHz Transceiver v8.0: Device: "/dev/input/event2"
[ 38.530] (--) evdev: Microsoft Microsoft® 2.4GHz Transceiver v8.0: Vendor 0x45e Product 0x745
[ 38.530] (--) evdev: Microsoft Microsoft® 2.4GHz Transceiver v8.0: Found keys
[ 38.530] (II) evdev: Microsoft Microsoft® 2.4GHz Transceiver v8.0: Configuring as keyboard
[ 38.530] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:02.0/usb2/2-3/2-3:1.0/input/input2/event2"
[ 38.530] (II) XINPUT: Adding extended input device "Microsoft Microsoft® 2.4GHz Transceiver v8.0" (type: KEYBOARD, id 8)
[ 38.530] (**) Option "xkb_rules" "evdev"
[ 38.530] (**) Option "xkb_model" "pc105"
[ 38.530] (**) Option "xkb_layout" "at"
[ 38.531] (II) config/udev: Adding input device Microsoft Microsoft® 2.4GHz Transceiver v8.0 (/dev/input/event3)
[ 38.531] (**) Microsoft Microsoft® 2.4GHz Transceiver v8.0: Applying InputClass "evdev pointer catchall"
[ 38.531] (**) Microsoft Microsoft® 2.4GHz Transceiver v8.0: Applying InputClass "evdev keyboard catchall"
[ 38.531] (II) Using input driver 'evdev' for 'Microsoft Microsoft® 2.4GHz Transceiver v8.0'
[ 38.531] (**) Microsoft Microsoft® 2.4GHz Transceiver v8.0: always reports core events
[ 38.531] (**) evdev: Microsoft Microsoft® 2.4GHz Transceiver v8.0: Device: "/dev/input/event3"
[ 38.531] (--) evdev: Microsoft Microsoft® 2.4GHz Transceiver v8.0: Vendor 0x45e Product 0x745
[ 38.532] (--) evdev: Microsoft Microsoft® 2.4GHz Transceiver v8.0: Found 9 mouse buttons
[ 38.532] (--) evdev: Microsoft Microsoft® 2.4GHz Transceiver v8.0: Found scroll wheel(s)
[ 38.532] (--) evdev: Microsoft Microsoft® 2.4GHz Transceiver v8.0: Found relative axes
[ 38.532] (--) evdev: Microsoft Microsoft® 2.4GHz Transceiver v8.0: Found x and y relative axes
[ 38.532] (--) evdev: Microsoft Microsoft® 2.4GHz Transceiver v8.0: Found absolute axes
[ 38.532] (II) evdev: Microsoft Microsoft® 2.4GHz Transceiver v8.0: Forcing absolute x/y axes to exist.
[ 38.532] (--) evdev: Microsoft Microsoft® 2.4GHz Transceiver v8.0: Found keys
[ 38.532] (II) evdev: Microsoft Microsoft® 2.4GHz Transceiver v8.0: Configuring as mouse
[ 38.532] (II) evdev: Microsoft Microsoft® 2.4GHz Transceiver v8.0: Configuring as keyboard
[ 38.532] (II) evdev: Microsoft Microsoft® 2.4GHz Transceiver v8.0: Adding scrollwheel support
[ 38.532] (**) evdev: Microsoft Microsoft® 2.4GHz Transceiver v8.0: YAxisMapping: buttons 4 and 5
[ 38.532] (**) evdev: Microsoft Microsoft® 2.4GHz Transceiver v8.0: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 38.532] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:02.0/usb2/2-3/2-3:1.1/input/input3/event3"
[ 38.532] (II) XINPUT: Adding extended input device "Microsoft Microsoft® 2.4GHz Transceiver v8.0" (type: KEYBOARD, id 9)
[ 38.532] (**) Option "xkb_rules" "evdev"
[ 38.532] (**) Option "xkb_model" "pc105"
[ 38.532] (**) Option "xkb_layout" "at"
[ 38.532] (II) evdev: Microsoft Microsoft® 2.4GHz Transceiver v8.0: initialized for relative axes.
[ 38.532] (WW) evdev: Microsoft Microsoft® 2.4GHz Transceiver v8.0: ignoring absolute axes.
[ 38.533] (**) Microsoft Microsoft® 2.4GHz Transceiver v8.0: (accel) keeping acceleration scheme 1
[ 38.533] (**) Microsoft Microsoft® 2.4GHz Transceiver v8.0: (accel) acceleration profile 0
[ 38.533] (**) Microsoft Microsoft® 2.4GHz Transceiver v8.0: (accel) acceleration factor: 2.000
[ 38.533] (**) Microsoft Microsoft® 2.4GHz Transceiver v8.0: (accel) acceleration threshold: 4
[ 38.533] (II) config/udev: Adding input device Microsoft Microsoft® 2.4GHz Transceiver v8.0 (/dev/input/mouse0)
[ 38.533] (II) No input driver specified, ignoring this device.
[ 38.533] (II) This device may have been added with another device file.
[ 38.534] (II) config/udev: Adding input device Microsoft Microsoft® 2.4GHz Transceiver v8.0 (/dev/input/event4)
[ 38.534] (**) Microsoft Microsoft® 2.4GHz Transceiver v8.0: Applying InputClass "evdev keyboard catchall"
[ 38.534] (II) Using input driver 'evdev' for 'Microsoft Microsoft® 2.4GHz Transceiver v8.0'
[ 38.534] (**) Microsoft Microsoft® 2.4GHz Transceiver v8.0: always reports core events
[ 38.534] (**) evdev: Microsoft Microsoft® 2.4GHz Transceiver v8.0: Device: "/dev/input/event4"
[ 38.535] (--) evdev: Microsoft Microsoft® 2.4GHz Transceiver v8.0: Vendor 0x45e Product 0x745
[ 38.535] (--) evdev: Microsoft Microsoft® 2.4GHz Transceiver v8.0: Found 1 mouse buttons
[ 38.535] (--) evdev: Microsoft Microsoft® 2.4GHz Transceiver v8.0: Found scroll wheel(s)
[ 38.535] (--) evdev: Microsoft Microsoft® 2.4GHz Transceiver v8.0: Found relative axes
[ 38.535] (--) evdev: Microsoft Microsoft® 2.4GHz Transceiver v8.0: Found absolute axes
[ 38.535] (--) evdev: Microsoft Microsoft® 2.4GHz Transceiver v8.0: Found absolute multitouch axes
[ 38.535] (--) evdev: Microsoft Microsoft® 2.4GHz Transceiver v8.0: Found x and y absolute axes
[ 38.535] (--) evdev: Microsoft Microsoft® 2.4GHz Transceiver v8.0: Found keys
[ 38.535] (II) evdev: Microsoft Microsoft® 2.4GHz Transceiver v8.0: Forcing relative x/y axes to exist.
[ 38.535] (II) evdev: Microsoft Microsoft® 2.4GHz Transceiver v8.0: Configuring as mouse
[ 38.535] (II) evdev: Microsoft Microsoft® 2.4GHz Transceiver v8.0: Configuring as keyboard
[ 38.535] (II) evdev: Microsoft Microsoft® 2.4GHz Transceiver v8.0: Adding scrollwheel support
[ 38.535] (**) evdev: Microsoft Microsoft® 2.4GHz Transceiver v8.0: YAxisMapping: buttons 4 and 5
[ 38.535] (**) evdev: Microsoft Microsoft® 2.4GHz Transceiver v8.0: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 38.535] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:02.0/usb2/2-3/2-3:1.2/input/input4/event4"
[ 38.535] (II) XINPUT: Adding extended input device "Microsoft Microsoft® 2.4GHz Transceiver v8.0" (type: KEYBOARD, id 10)
[ 38.535] (**) Option "xkb_rules" "evdev"
[ 38.535] (**) Option "xkb_model" "pc105"
[ 38.535] (**) Option "xkb_layout" "at"
[ 38.535] (II) evdev: Microsoft Microsoft® 2.4GHz Transceiver v8.0: initialized for relative axes.
[ 38.535] (WW) evdev: Microsoft Microsoft® 2.4GHz Transceiver v8.0: ignoring absolute axes.
[ 38.536] (**) Microsoft Microsoft® 2.4GHz Transceiver v8.0: (accel) keeping acceleration scheme 1
[ 38.536] (**) Microsoft Microsoft® 2.4GHz Transceiver v8.0: (accel) acceleration profile 0
[ 38.536] (**) Microsoft Microsoft® 2.4GHz Transceiver v8.0: (accel) acceleration factor: 2.000
[ 38.536] (**) Microsoft Microsoft® 2.4GHz Transceiver v8.0: (accel) acceleration threshold: 4
[ 38.536] (II) config/udev: Adding input device Microsoft Microsoft® 2.4GHz Transceiver v8.0 (/dev/input/js0)
[ 38.536] (II) No input driver specified, ignoring this device.
[ 38.536] (II) This device may have been added with another device file.
[ 38.537] (II) config/udev: Adding drm device (/dev/dri/card0) card0 /sys/devices/pci0000:00/0000:00:1e.0/0000:02:00.0/drm/card0
[ 38.537] (II) config/udev: Ignoring already known drm device (/dev/dri/card0)
[ 42.417] (II) NOUVEAU(0): EDID vendor "PHL", prod id 18000
[ 42.417] (II) NOUVEAU(0): Using EDID range info for horizontal sync
[ 42.417] (II) NOUVEAU(0): Using EDID range info for vertical refresh
[ 42.417] (II) NOUVEAU(0): Printing DDC gathered Modelines:
[ 42.417] (II) NOUVEAU(0): Modeline "1280x768"x0.0 69.00 1280 1280 1300 1424 768 769 775 812 -hsync -vsync (48.5 kHz e)
[ 42.417] (II) NOUVEAU(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 42.417] (II) NOUVEAU(0): Modeline "800x600"x0.0 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz e)
[ 42.417] (II) NOUVEAU(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 42.417] (II) NOUVEAU(0): Modeline "640x480"x0.0 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz e)
[ 42.417] (II) NOUVEAU(0): Modeline "640x480"x0.0 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz e)
[ 42.417] (II) NOUVEAU(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 42.417] (II) NOUVEAU(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 42.417] (II) NOUVEAU(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 42.417] (II) NOUVEAU(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 42.417] (II) NOUVEAU(0): Modeline "1024x768"x0.0 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz e)
[ 42.417] (II) NOUVEAU(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 42.417] (II) NOUVEAU(0): Modeline "832x624"x0.0 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz e)
[ 42.417] (II) NOUVEAU(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 42.417] (II) NOUVEAU(0): Modeline "800x600"x0.0 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz e)
[ 42.417] (II) NOUVEAU(0): Modeline "640x360"x85.0 25.77 640 656 720 800 360 361 364 379 -hsync +vsync (32.2 kHz e)
[ 42.417] (II) NOUVEAU(0): Modeline "800x450"x85.0 41.81 800 840 920 1040 450 451 454 473 -hsync +vsync (40.2 kHz e)
[ 42.417] (II) NOUVEAU(0): Modeline "1024x576"x85.0 69.11 1024 1080 1184 1344 576 577 580 605 -hsync +vsync (51.4 kHz e)
[ 42.417] (II) NOUVEAU(0): Modeline "1152x648"x75.0 77.18 1152 1216 1336 1520 648 649 652 677 -hsync +vsync (50.8 kHz e)
[ 42.417] (II) NOUVEAU(0): Modeline "1280x720"x60.0 74.48 1280 1336 1472 1664 720 721 724 746 -hsync +vsync (44.8 kHz e)
[ 42.417] (II) NOUVEAU(0): Modeline "256x144"x61.0 2.34 256 232 256 256 144 145 148 150 -hsync +vsync (9.1 kHz e)
[ 42.518] resize called 1280 720
[ 43.368] (II) XKB: reuse xkmfile /var/lib/xkb/server-C0761131EB9CB35F53F523514E9E15D6FEC0093A.xkm
[ 44.912] (II) NOUVEAU(0): EDID vendor "PHL", prod id 18000
[ 44.912] (II) NOUVEAU(0): Using hsync ranges from config file
[ 44.912] (II) NOUVEAU(0): Using vrefresh ranges from config file
[ 44.912] (II) NOUVEAU(0): Printing DDC gathered Modelines:
[ 44.912] (II) NOUVEAU(0): Modeline "1280x768"x0.0 69.00 1280 1280 1300 1424 768 769 775 812 -hsync -vsync (48.5 kHz e)
[ 44.912] (II) NOUVEAU(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 44.912] (II) NOUVEAU(0): Modeline "800x600"x0.0 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz e)
[ 44.912] (II) NOUVEAU(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 44.912] (II) NOUVEAU(0): Modeline "640x480"x0.0 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz e)
[ 44.912] (II) NOUVEAU(0): Modeline "640x480"x0.0 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz e)
[ 44.912] (II) NOUVEAU(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 44.912] (II) NOUVEAU(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 44.912] (II) NOUVEAU(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 44.912] (II) NOUVEAU(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 44.912] (II) NOUVEAU(0): Modeline "1024x768"x0.0 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz e)
[ 44.912] (II) NOUVEAU(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 44.912] (II) NOUVEAU(0): Modeline "832x624"x0.0 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz e)
[ 44.912] (II) NOUVEAU(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 44.912] (II) NOUVEAU(0): Modeline "800x600"x0.0 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz e)
[ 44.912] (II) NOUVEAU(0): Modeline "640x360"x85.0 25.77 640 656 720 800 360 361 364 379 -hsync +vsync (32.2 kHz e)
[ 44.912] (II) NOUVEAU(0): Modeline "800x450"x85.0 41.81 800 840 920 1040 450 451 454 473 -hsync +vsync (40.2 kHz e)
[ 44.912] (II) NOUVEAU(0): Modeline "1024x576"x85.0 69.11 1024 1080 1184 1344 576 577 580 605 -hsync +vsync (51.4 kHz e)
[ 44.912] (II) NOUVEAU(0): Modeline "1152x648"x75.0 77.18 1152 1216 1336 1520 648 649 652 677 -hsync +vsync (50.8 kHz e)
[ 44.912] (II) NOUVEAU(0): Modeline "1280x720"x60.0 74.48 1280 1336 1472 1664 720 721 724 746 -hsync +vsync (44.8 kHz e)
[ 44.912] (II) NOUVEAU(0): Modeline "256x144"x61.0 2.34 256 232 256 256 144 145 148 150 -hsync +vsync (9.1 kHz e)
[ 45.060] (II) NOUVEAU(0): EDID vendor "PHL", prod id 18000
[ 45.060] (II) NOUVEAU(0): Using hsync ranges from config file
[ 45.060] (II) NOUVEAU(0): Using vrefresh ranges from config file
[ 45.060] (II) NOUVEAU(0): Printing DDC gathered Modelines:
[ 45.060] (II) NOUVEAU(0): Modeline "1280x768"x0.0 69.00 1280 1280 1300 1424 768 769 775 812 -hsync -vsync (48.5 kHz e)
[ 45.060] (II) NOUVEAU(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 45.060] (II) NOUVEAU(0): Modeline "800x600"x0.0 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz e)
[ 45.060] (II) NOUVEAU(0): Modeline "640x480"x0.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 45.060] (II) NOUVEAU(0): Modeline "640x480"x0.0 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz e)
[ 45.060] (II) NOUVEAU(0): Modeline "640x480"x0.0 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz e)
[ 45.060] (II) NOUVEAU(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 45.060] (II) NOUVEAU(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 45.060] (II) NOUVEAU(0): Modeline "1280x1024"x0.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 45.060] (II) NOUVEAU(0): Modeline "1024x768"x0.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 45.060] (II) NOUVEAU(0): Modeline "1024x768"x0.0 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz e)
[ 45.060] (II) NOUVEAU(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 45.060] (II) NOUVEAU(0): Modeline "832x624"x0.0 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz e)
[ 45.060] (II) NOUVEAU(0): Modeline "800x600"x0.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 45.060] (II) NOUVEAU(0): Modeline "800x600"x0.0 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz e)
[ 45.060] (II) NOUVEAU(0): Modeline "640x360"x85.0 25.77 640 656 720 800 360 361 364 379 -hsync +vsync (32.2 kHz e)
[ 45.060] (II) NOUVEAU(0): Modeline "800x450"x85.0 41.81 800 840 920 1040 450 451 454 473 -hsync +vsync (40.2 kHz e)
[ 45.060] (II) NOUVEAU(0): Modeline "1024x576"x85.0 69.11 1024 1080 1184 1344 576 577 580 605 -hsync +vsync (51.4 kHz e)
[ 45.060] (II) NOUVEAU(0): Modeline "1152x648"x75.0 77.18 1152 1216 1336 1520 648 649 652 677 -hsync +vsync (50.8 kHz e)
[ 45.060] (II) NOUVEAU(0): Modeline "1280x720"x60.0 74.48 1280 1336 1472 1664 720 721 724 746 -hsync +vsync (44.8 kHz e)
[ 45.060] (II) NOUVEAU(0): Modeline "256x144"x61.0 2.34 256 232 256 256 144 145 148 150 -hsync +vsync (9.1 kHz e)
