strange io errors
I am trying to run CCSM3 and get errors, while it tries to read data from the binary files (restart files).
With the compiler version 6.1-2:
PGFIO/stdio: No such file or directory
PGFIO-F-/unformatted read/unit=10/error code returned by host stdio - 2.
File name = b30.031.cpl6.r.0821-01-01-00000 unformatted, sequential access record = 2
In source file /home/veremeev/ccsm3_0/models/csm_share/cpl/cpl_iobin_mod.F90, at line number 233
With the compiler version 6.1-4:
PGFIO/stdio: Success
PGFIO-F-/unformatted read/unit=10/error code returned by host stdio - 0.
The errors occur only on the files, downloaded from the NCAR.
They do not occur with the files, produced locally.
More details on the errors are here.
http://bb.cgd.ucar.edu/showthread.php?p=802#post802
The restart files are plain binary files.
The failing code is:
231:   open(fid,file=fName,form="UNFORMATTED",status="OLD")
232:   read(fid) format     ! string len=256
233:   read(fid) name       ! string len=256
234:   read(fid) dstr,tstr  ! string len=256 * 2
235:   read(fid) comment    ! string len=256
236:   read(fid) cvsID      ! string len=256
I have added line numbers on the left, actually there are no line numbers in the file.
I have put the write statements after the line 232, and they gave the following.
Variable values before execution of this fragment:
fid=10
fName=b30.031.cpl6.r.0821-01-01-00000
The file is situated in the current working directory, getcwd confirms this.
Hi Vladimir,
It looks like a byte-swaping problem. Did you compile with “-byteswapio”? If not, can you try adding this flag?
  • Mat
Thank you, it worked!
I have also answered in the other my topic, about ‘save’`d variables, the compiler upgrade didn’t help, the variables are still not saved.
