i have a strange issue with PyCuda.
When i use my Python IDLE, i have this message error when i launch the program :
Python 3.6.9 (default, Apr 18 2020, 01:56:04)
[GCC 8.4.0] on linux
Type “help”, “copyright”, “credits” or “license()” for more information.
======= RESTART: /home/alain/Work/Python/JetsonSky/JetsonSky_V1_01.py =======
File “/home/alain/.local/lib/python3.6/site-packages/pytools/init.py”, line 555, in _deco
return func._memoize_dic[args] # pylint: disable=protected-access
AttributeError: ‘function’ object has no attribute ‘_memoize_dic’
During handling of the above exception, another exception occurred:
File “/home/alain/.local/lib/python3.6/site-packages/pytools/prefork.py”, line 50, in call_capture_output
stderr=PIPE)
File “/usr/lib/python3.6/subprocess.py”, line 729, in init
restore_signals, start_new_session)
File “/usr/lib/python3.6/subprocess.py”, line 1364, in _execute_child
raise child_exception_type(errno_num, err_msg, err_filename)
FileNotFoundError: [Errno 2] No such file or directory: ‘nvcc’: ‘nvcc’
File “/home/alain/Work/Python/JetsonSky/JetsonSky_V1_01.py”, line 200, in
File “/home/alain/.local/lib/python3.6/site-packages/pycuda/compiler.py”, line 291, in init
arch, code, cache_dir, include_dirs)
File “/home/alain/.local/lib/python3.6/site-packages/pycuda/compiler.py”, line 254, in compile
return compile_plain(source, options, keep, nvcc, cache_dir, target)
File “/home/alain/.local/lib/python3.6/site-packages/pycuda/compiler.py”, line 84, in compile_plain
checksum.update(get_nvcc_version(nvcc).encode(“utf-8”))
File “”, line 2, in get_nvcc_version
File “/home/alain/.local/lib/python3.6/site-packages/pytools/init.py”, line 558, in _deco
result = func(*args)
File “/home/alain/.local/lib/python3.6/site-packages/pycuda/compiler.py”, line 16, in get_nvcc_version
result, stdout, stderr = call_capture_output(cmdline)
File “/home/alain/.local/lib/python3.6/site-packages/pytools/prefork.py”, line 227, in call_capture_output
return forker.call_capture_output(cmdline, cwd, error_on_nonzero)
File “/home/alain/.local/lib/python3.6/site-packages/pytools/prefork.py”, line 61, in call_capture_output
% (” ".join(cmdline), e))
pytools.prefork.ExecError: error invoking ‘nvcc --version’: [Errno 2] No such file or directory: ‘nvcc’: ‘nvcc’
When i launch my program with a terminal (“python3 JetsonSky_V1_01.py”), everything runs fine.
I also tried to Thonny IDE but i have the same problem.
Any idea about this issue ?
Many thanks in advance.
Have a nice day.
Alain
