I have no idea what to do with this error, any suggestion would be very appreciated.
I’m running windows xp 32 bits
1>------ Rebuild All started: Project: cppIntegration, Configuration: Debug Win32 ------
1>Deleting intermediate and output files for project ‘cppIntegration’, configuration ‘Debug|Win32’
1>Compiling with CUDA Build Rule…
1>“C:\CUDA\bin\nvcc.exe” -arch sm_10 -ccbin “C:\Program Files\Microsoft Visual Studio 8\VC\bin” -Xcompiler “/EHsc /W3 /nologo /Od /Zi /MTd " -I"C:\CUDA\include” -I"…/…/common/inc" -maxrregcount=32 --compile -o “Debug\cppIntegration.cu.obj” “c:\Documents and Settings\All Users\Application Data\NVIDIA Corporation\NVIDIA GPU Computing SDK\C\src\aes one\cppIntegration.cu”
1>cppIntegration.cu
1>tmpxft_00000c58_00000000-3_cppIntegration.cudafe1.gpu
1>tmpxft_00000c58_00000000-8_cppIntegration.cudafe2.gpu
1>ptxas C:\DOCUME~1\RESEAR~2\LOCALS~1\Temp/tmpxft_00000c58_00000000-4_cppIntegration.ptx, line 312; error : Arguments mismatch for instruction ‘shl’
1>ptxas C:\DOCUME~1\RESEAR~2\LOCALS~1\Temp/tmpxft_00000c58_00000000-4_cppIntegration.ptx, line 313; error : Arguments mismatch for instruction ‘shr’
1>ptxas fatal : Ptx assembly aborted due to errors
1>Compiling…
1>cppIntegration_gold.cpp
1>main.cpp
1>Generating Code…
1>Linking…
1>LINK : fatal error LNK1181: cannot open input file ‘.\Debug\cppIntegration.cu.obj’
1>Build log was saved at “file://c:\Documents and Settings\All Users\Application Data\NVIDIA Corporation\NVIDIA GPU Computing SDK\C\src\aes one\Debug\BuildLog.htm”
1>cppIntegration - 1 error(s), 0 warning(s)
========== Rebuild All: 0 succeeded, 1 failed, 0 skipped ==========
global void criptare_aesctr(unsigned char* TX,unsigned char* IV,unsigned char* RK,unsigned char* SB,unsigned int maxim)
unsigned int i = (blockIdx.y*gridDim.x+blockIdx.x)*blockDim.x+threadIdx.x;
int j,r,ix;
unsigned int cx = i*16;
unsigned char temp[4];
unsigned char state[16];
TX[cx+ix]=state[ix]; //this row generates the error
