We’re experience an issue where occasionally the VIDIOC_STREAMON ioctl call returns a large negative value and errno is 0. This is on jetpack 4.6. For example:
[ 8091.299611] video1: VIDIOC_STREAMON: error -970440680: type=vid-cap
[ 8091.299686] video1: VIDIOC_STREAMOFF: type=vid-cap
Looking through capture_vi_channel.c it seems like it’s failing in vi_channel_open_ex() at this point (it’s gets past the vi_channel_power_on_vi_device call just before this):
mutex_lock(&chan_drv->lock);
if (rcu_access_pointer(chan_drv->channels[channel]) != NULL) {
mutex_unlock(&chan_drv->lock);
err = -EBUSY;
goto rcu_err;
And the return value would come from PTR_ERR(chan) here:
chan->tegra_vi_channel[vi_port] = vi_channel_open_ex(chan->id + vi_port, false);
if (IS_ERR(chan->tegra_vi_channel[vi_port])) {
ret = PTR_ERR(chan);
goto err_open_ex;
I’m adding dev_err calls in vi_channel_open_ex to confirm, but was wondering why this might be happening? It looks like chan_drv->channels[channel] is cleared in vi_channel_close_ex. Is it possible that’s not happening for some reason?
