Strange screen tearing on small monitor
Hi all,
I’m trying out the jetson with a very small monitor (480x800) and I’m running into some tearing issues
See here: PXL 20230629 080116891 LS - YouTube
One thing the video does not capture well is that there is no tearing where the mouse pointer is (the foreground?) but the screen tears otherwise.
Does anyone have any thoughts on how I could solve this issue?
Is this a pure HDMI interface ?
Hey WayneWWW,
Yes, pure HDMI
This is the product:
Here is some of the DMESG if it helps
[ 2420.447859] tegradc tegradc.0: hdmi: EDID change after HPD bounce, resetting
[ 2420.447919] extcon-disp-state extcon:disp-state: cable 51 state 0
[ 2420.447922] Extcon HDMI: HPD disabled
[ 2420.447942] tegradc tegradc.0: hdmi: plugged
[ 2420.462655] tegradc tegradc.0: blank - powerdown
[ 2420.462668] tegradc tegradc.0: unblank
[ 2420.479400] Reserved SVD code 0
[ 2420.499277] tegradc tegradc.0: nominal-pclk:74250000 parent:74250000 div:1.0 pclk:74250000 73507500~80932500
[ 2420.499362] tegradc tegradc.0: hdmi: tmds rate:74250K prod-setting:prod_c_hdmi_54m_75m
[ 2420.500414] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 2420.532042] Reserved SVD code 0
[ 2420.536399] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 2420.536401] Extcon AUX1(HDMI) enable
[ 2420.543257] tegradc tegradc.0: blank - powerdown
[ 2420.600798] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 2420.600799] Extcon AUX1(HDMI) disable
[ 2420.621186] tegradc tegradc.0: unblank
[ 2420.631421] tegradc tegradc.0: nominal-pclk:38000000 parent:37999453 div:1.0 pclk:37999453 37620000~41420000
[ 2420.631501] tegradc tegradc.0: hdmi: tmds rate:38000K prod-setting:prod_c_hdmi_0m_54m
[ 2420.632934] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 2420.666971] Reserved SVD code 0
[ 2420.670315] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 2420.670318] Extcon AUX1(HDMI) enable
[ 2420.673629] tegradc tegradc.0: unblank
[ 2420.673803] tegradc tegradc.1: blank - powerdown
[ 2420.676076] extcon-disp-state extcon:disp-state: cable 51 state 1
[ 2420.676080] Extcon HDMI: HPD enabled
[ 2420.676114] tegradc tegradc.0: hdmi: plugged
[ 2420.716657] tegradc tegradc.0: blank - powerdown
[ 2420.775630] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 2420.775635] Extcon AUX1(HDMI) disable
[ 2420.795374] tegradc tegradc.0: unblank
[ 2420.806539] tegradc tegradc.0: nominal-pclk:74250000 parent:74250000 div:1.0 pclk:74250000 73507500~80932500
[ 2420.806618] tegradc tegradc.0: hdmi: tmds rate:74250K prod-setting:prod_c_hdmi_54m_75m
[ 2420.807634] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 2420.839584] Reserved SVD code 0
[ 2420.842878] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 2420.842882] Extcon AUX1(HDMI) enable
[ 2420.846374] tegradc tegradc.0: unblank
[ 2420.846416] tegradc tegradc.1: blank - powerdown
[ 2420.944926] tegradc tegradc.0: blank - powerdown
[ 2421.007998] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 2421.008000] Extcon AUX1(HDMI) disable
[ 2421.028413] tegradc tegradc.1: blank - powerdown
[ 2421.057953] tegradc tegradc.0: blank - powerdown
[ 2421.057974] tegradc tegradc.0: unblank
[ 2421.068418] tegradc tegradc.0: nominal-pclk:38000000 parent:37999453 div:1.0 pclk:37999453 37620000~41420000
[ 2421.068505] tegradc tegradc.0: hdmi: tmds rate:38000K prod-setting:prod_c_hdmi_0m_54m
[ 2421.069532] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 2421.101076] Reserved SVD code 0
[ 2421.108389] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 2421.108391] Extcon AUX1(HDMI) enable
[ 2421.112998] tegradc tegradc.0: unblank
[ 2421.113024] tegradc tegradc.1: blank - powerdown
[ 3087.049473] tegradc tegradc.0: blank - powerdown
[ 3087.104421] extcon-disp-state extcon:disp-state: cable 47 state 0
[ 3087.104430] Extcon AUX1(HDMI) disable
[ 3180.669559] tegradc tegradc.0: unblank
[ 3180.674325] tegradc tegradc.0: nominal-pclk:38000000 parent:37999453 div:1.0 pclk:37999453 37620000~41420000
[ 3180.674508] tegradc tegradc.0: hdmi: tmds rate:38000K prod-setting:prod_c_hdmi_0m_54m
[ 3180.676853] tegradc tegradc.0: hdmi: get YCC quant from EDID.
[ 3180.708690] Reserved SVD code 0
[ 3180.712075] extcon-disp-state extcon:disp-state: cable 47 state 1
[ 3180.712077] Extcon AUX1(HDMI) enable
[ 3180.727213] tegradc tegradc.0: unblank
[ 3180.727317] tegradc tegradc.1: blank - powerdown
Do you know what is the required pclk this panel need?
