Strata-Jetson-Orin
I have successfully ported Strata, the Qwen MoE-aware inference engine that parks non-active experts in slower RAM or SSD, to the Orin AGX platform.
I’ve tested it against Qwen3.8-Flash-Next (125B/A6B) on Orin AGX 32GB running JP6.2 with CUDA 12.6.
For 32k context windows performance is ~20tps, with 64k context windows about ~18tps. Context windows up to 256k are supported, but performance fall-off after 64k is significant.
Performance is described fully at https://github.com/calvinvette/strata-inference-orin/blob/main/bench/results/2026-10-08-jetson-orin/README.md
Updates for JP7.x will be forthcoming.
Thanks for the sharing.
Will be standing by for JP 7.x update. And I have the 64gb version, still good to use your fork?
You’ll be able to use a higher quant (slightly more accurate) or use more KV cache (larger contexts, or more simultaneusly).
I’m also currently vetting a strata + ninfer combination - integrating the lessons from my ninfer port to Strata (also still JP6.2).
(Once that’s done I’ll do the JP7.x updates.)
