• Hardware Platform (Jetson / GPU) Jetson Orin • DeepStream Version 6.1 • JetPack Version (valid for Jetson only) 5.0.1 • TensorRT Version • NVIDIA GPU Driver Version (valid for GPU only)
I am trying to link an camera through the aravissrc plugin available to them.
This source if connected with the EGL works fine. I need to do infer and so I need to have a stream mux. The following is the pipeline without the streammux
When link the streammux before the egl sink it just dosent link
This is a command use streammux, infer and nveglglessink.
You can refer this document got more infomation.
