Continuing the discussion from Free(): invalid pointer while using smart record in deepstream python:
• Hardware Platform (Jetson / GPU) - Jetson Nano
• DeepStream Version - 6.0.1
• JetPack Version (valid for Jetson only) - 4.6.2
• TensorRT Version - 8.2
• NVIDIA GPU Driver Version (valid for GPU only) - 10.2
I am using the deeptream-test3.py code to store clips using smart record with a period of a 5-minute interval. Every 5 minutes, the clips will be stored. However, I encountered the following error while storing the clips:
sys:1: Warning: instance with invalid (NULL) class pointer
sys:1: Warning: g_signal_emit_by_name: assertion ‘G_TYPE_CHECK_INSTANCE (instance)’ failed
When running the deeptream-test3.py code with smart recording for two RTSP streams, the clips will be stored at 5-minute intervals. The code initiates the record event using the probe function upon startup and stops after 5 minutes. The process then repeats, starting the recording event again.
could you help me to resolve this issue?
